질문게시판 > Atmega128 CLCD와 블루투스 통신 문제
TODAY4,481 TOTAL4,843,175
BASIC4MCU | 질문게시판 | Atmega128 CLCD와 블루투스 통신 문제
작성자 fanfan 작성일2023-12-07 16:11 조회1,458회 댓글1건
#define F_CPU 16000000UL
#define __DELAY_BACKWARD_COMPATIBLE__
#define STATE_0 0
#define STATE_1 1
#define STATE_2 2
#define STATE_3 3
#define NULL    0x00
#define BIT4_LINE2_DOT58      0x28
#define DISPON_CUROFF_BLKOFF  0x0C
#define DISPOFF_CUROFF_BLKOFF 0x08
#define INC_NOSHIFT           0x06
#define DISPCLEAR             0x01
#define CUR1LINE              0x80
#define CUR2LINE              0xC0
#define CURHOME               0x02
#define E_BIT                 0x04
#define RW_BIT                0x03
#define RS_BIT                0x02
#define STOP_SPEED    0
#define LOW_SPEED     77
#define MID_SPEED     153
#define HIGH_SPEED    230
#define MOTOR_CW      0xb0
#define MOTOR_CCW     0x70
#define MOTOR_BRAKE   0xd0
#define MOTOR_STOP    0x30
#define MOTOR_STANDBY 0x00
char Fan_name[]="Good Fan";
char START_LCD[]="Put the number!";
char STOP_SPEED1[]="Turn Off!";
char LOW_SPEED1[]="Speed State 1";
char MID_SPEED1[]="Speed State 2";
char HIGH_SPEED1[]="Speed State 3";
char ERROR[]="Put 1 or 2 or 3";
int motor_speed[4]={STOP_SPEED, LOW_SPEED, MID_SPEED, HIGH_SPEED};
unsigned char c=STATE_0;
void putchar1(char c){ while(!(UCSR1A & (1<<UDRE1))); UDR1=c; }
void puts1(char *ptr){ while(*ptr !=NULL)putchar1(*ptr++); }
char available1(){
  if(UCSR1A & (1<<RXC1))return(1); else return(0);
char getchar1(){ while(!(UCSR1A & (1<<RXC1))); return(UDR1); }
void init_uart1(){
  DDRE |= (1 <<PE0);
  DDRE |= (1 << PE1);
  UCSR1B=0x18;//(1 << RXEN0) | (1 << TXEN0); //0x18;///   ->  이 부분을 UCSR1B = (1 << RXEN1) | (1 << TXEN1); 으로
  UCSR1C=0x06;//(1 << UCSZ11) | (1 << UCSZ10); //0x06;////    -> 이 부분을 UCSR1C = (1 << UCSZ11) | (1 << UCSZ10); 으로
  UBRR1H=0;
  UBRR1L=8;
void CLCD_data(char data){
  PORTD=0x04; _delay_us(1); PORTD=0x14; PORTC=data & 0xf0;
  PORTD=0x04; _delay_us(2); PORTD=0x14; PORTC=(data << 4) & 0xf0;
  PORTD=0x04; _delay_ms(1);
void CLCD_cmd(char cmd){
  PORTD=0x00; _delay_us(1); PORTD=0x10; PORTC=cmd & 0xf0;
  PORTD=0x00; _delay_us(2); PORTD=0x10; PORTC=(cmd << 4) & 0xf0;
  PORTD=0x00; _delay_ms(1);
void CLCD_puts(char *ptr){ while(*ptr !=NULL)CLCD_data(*ptr++); }
void init_CLCD(){
  DDRC=0xff; DDRD=0xff;
  _delay_ms(50);
  CLCD_cmd(BIT4_LINE2_DOT58);
  CLCD_cmd(DISPON_CUROFF_BLKOFF);
  CLCD_cmd(INC_NOSHIFT);
  CLCD_cmd(DISPCLEAR);
  _delay_ms(2);
int main(void){
  char c;
  DDRB=0xf0; PORTB=MOTOR_STANDBY;
  TCCR2=0x6b; OCR2=0;
  init_CLCD();
  _delay_ms(500);
  init_uart1();
    if(!available1()){
      CLCD_cmd(CUR1LINE);
      CLCD_puts(Fan_name);
      CLCD_cmd(CUR2LINE);
      CLCD_puts(START_LCD);
    c=getchar1();
    putchar1(c);
    switch(c){
      case '0' :
            CLCD_cmd(DISPCLEAR); CLCD_cmd(CUR1LINE); CLCD_puts(Fan_name);
            CLCD_cmd(CUR2LINE);  CLCD_puts(STOP_SPEED1);
            PORTB=MOTOR_STOP;  OCR2=motor_speed[0];
      case '1' :
            CLCD_cmd(CUR2LINE);  CLCD_puts(LOW_SPEED1);
            PORTB=MOTOR_CW;    OCR2=motor_speed[1];
      case '2' :
            CLCD_cmd(CUR2LINE);  CLCD_puts(MID_SPEED1);
            PORTB=MOTOR_CW;    OCR2=motor_speed[2];
      case '3' :
            CLCD_cmd(CUR1LINE);
            CLCD_cmd(CUR2LINE);
            CLCD_puts(HIGH_SPEED1);
            PORTB=MOTOR_CW;            OCR2=motor_speed[3];
      default :
            //CLCD_cmd(DISPCLEAR);
            //CLCD_cmd(CUR1LINE);
            //CLCD_puts(Fan_name);
            //CLCD_cmd(CUR2LINE);
            //CLCD_puts(ERROR);
밑에 질문 했던 것처럼 블루투스 포트를 E 포트로 변경도 해보고,
블루투스 포트를 D 포트로 사용하면, LCD에서 사용하는 포트를 C로 전부 옮겨봤는데도 실패하였습니다...
그래서 블루투스 포트를 E 포트(PE0, PE1) (RXD0, TXD0)으로 하려고 하는데도 동작이 되질 않습니다...
블루투스를 E포트로 사용하려면 코드를 수정해야 하는지 도와주시면 감사하겠습니다..
조회수 1,458
void init_uart1(){
  UCSR1B=0x18; UBRR1L=8;
UART0을 사용하려면 UART1을 설정하지말고 UART0을 설정해야겠죠?
void init_uart0(){
  UCSR0B=0x18; UBRR0L=8;
나머지 함수들도 UART0으로 변경합니다.
char available0(){ if(UCSR0A&0x80)return(1); else return(0); }
char getchar0(){ while(!(UCSR1A&0x80)); return(UDR0); }
void putchar0(char c){ while(!(UCSR0A&0x20)); UDR0=c; }
void puts0(char *s){ while(*s)putchar0(*s++); }
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 24091
공지 사이트 이용 안내댓글[31] master 17-10-29 38331
질문 스탭모터 3개 회로도 질문.. 삉삉이 24-10-11 19
답변 답변글 답변 : 스탭모터 3개 회로도 질문.. 이미지새글 master 24-10-12 51
질문 수분수위센서와 멀티플렉서댓글[1] 김고래쓰 24-10-10 51
질문 ATmegq128 PI 제어기 추가댓글[1] 바밤 24-10-08 37
답변 답변글 답변 : ATmegq128 PI 제어기 추가댓글[1] master 24-10-08 54
질문 아두이노 ide 네오픽셀 각 셀 각자 코드 현수 24-09-29 72
질문 아두이노 IDE 프로마이크로 네오픽셀 현수 24-09-29 63
답변 답변글 답변 : 아두이노 IDE 프로마이크로 네오픽셀 master 24-09-29 77
질문 아두이노 프로마이크로 ide 현수 24-09-28 74
답변 답변글 답변 : 아두이노 프로마이크로 ide master 24-09-28 208
질문 ATmega128로 압력센서댓글[1] 이미지첨부파일 바밤 24-09-27 146
질문 아두이노 회로 배선 질문드립니다댓글[3] 이미지 아브 24-09-23 169
질문 아두이노 및 전기배선 작동이 안되어 해결 부탁드립니다 첨부파일 호떡아 24-09-14 198
답변 답변글 답변 : 아두이노 및 전기배선 작동이 안되어 해결 부탁드립니다 master 24-09-14 187
질문 USB host하고 Stop모드를 같이 쓰려는데댓글[1] 이미지 라칸 24-09-12 267
질문 아두이노 압력 센서로 LED 불빛 들어오게 할려고 하는데... 이미지첨부파일 윤시기 24-09-12 430
답변 답변글 답변 : 아두이노 압력 센서로 LED 불빛 들어오게 할려고 하는데... 이미지 master 24-09-12 302
질문 esp32 배터리 잔량 공부중입니다..댓글[6] 펌린이 24-09-06 1168
답변 답변글 답변 : esp32 배터리 잔량 공부중입니다.. 이미지 master 24-09-07 122
질문 ads로 adc값을 읽는데댓글[1] 라칸 24-09-05 180
질문 stm32 절전모드에 대해서댓글[2] 라칸 24-08-29 221
질문 아두이노 우노보드로 스마트팜 만들려고 하는데 문제가 있어요댓글[4] 부러진명검 24-08-28 678
질문 아두이노 블루투스 통신댓글[3] 이미지첨부파일 찌릿공돌이 24-08-27 425
질문 stm32에서 USB에 파일 생성 및 저장을 하려는데댓글[1] 이미지 라칸 24-08-23 296
질문 STM32 1개의 핀으로 ADC, DAC 사용 가능 여부댓글[4] aaahhhj 24-08-21 620
질문 회로 수정 질문..댓글[3] 이미지 소정이 24-08-21 377
질문 아두이노에서 stm32 그래프 파형 보려고 하는데 발생하는 오류댓글[1] aaahhhj 24-08-19 250
질문 님들 센서를 사용해서 adc값을 읽으려는데댓글[1] 라칸 24-08-13 267
