질문게시판 > 답변 : Atmega128 CLCD와 블루투스 통신 문제
TODAY431 TOTAL3,162,707
BASIC4MCU | 질문게시판 | 답변 : Atmega128 CLCD와 블루투스 통신 문제
작성자 master 작성일2023-12-07 16:55 조회845회 댓글3건
#define F_CPU 16000000UL
#define __DELAY_BACKWARD_COMPATIBLE__
#define STATE_0 0
#define STATE_1 1
#define STATE_2 2
#define STATE_3 3
#define NULL    0x00
#define BIT4_LINE2_DOT58      0x28
#define DISPON_CUROFF_BLKOFF  0x0C
#define DISPOFF_CUROFF_BLKOFF 0x08
#define INC_NOSHIFT           0x06
#define DISPCLEAR             0x01
#define CUR1LINE              0x80
#define CUR2LINE              0xC0
#define CURHOME               0x02
#define E_BIT                 0x04
#define RW_BIT                0x03
#define RS_BIT                0x02
#define STOP_SPEED    0
#define LOW_SPEED     77
#define MID_SPEED     153
#define HIGH_SPEED    230
#define MOTOR_CW      0xb0
#define MOTOR_CCW     0x70
#define MOTOR_BRAKE   0xd0
#define MOTOR_STOP    0x30
#define MOTOR_STANDBY 0x00
char Fan_name[]="Good Fan";
char START_LCD[]="Put the number!";
char STOP_SPEED1[]="Turn Off!";
char LOW_SPEED1[]="Speed State 1";
char MID_SPEED1[]="Speed State 2";
char HIGH_SPEED1[]="Speed State 3";
char ERROR[]="Put 1 or 2 or 3";
int motor_speed[4]={STOP_SPEED, LOW_SPEED, MID_SPEED, HIGH_SPEED};
unsigned char c=STATE_0;
char available0(){ if(UCSR0A&0x80)return(1); else return(0); }
char getchar0(){ while(!(UCSR1A&0x80)); return(UDR0); }
void putchar0(char c){ while(!(UCSR0A&0x20)); UDR0=c; }
void puts0(char *s){ while(*s)putchar0(*s++); }
void CLCD_data(char data){
  PORTD=0x04; _delay_us(1); PORTD=0x14; PORTC=data & 0xf0;
  PORTD=0x04; _delay_us(2); PORTD=0x14; PORTC=(data << 4) & 0xf0;
  PORTD=0x04; _delay_ms(1);
void CLCD_cmd(char cmd){
  PORTD=0x00; _delay_us(1); PORTD=0x10; PORTC=cmd & 0xf0;
  PORTD=0x00; _delay_us(2); PORTD=0x10; PORTC=(cmd << 4) & 0xf0;
  PORTD=0x00; _delay_ms(1);
void CLCD_puts(char *ptr){ while(*ptr !=NULL)CLCD_data(*ptr++); }
void init_CLCD(){
  DDRC=0xff; DDRD=0xff;
  _delay_ms(50);
  CLCD_cmd(BIT4_LINE2_DOT58);
  CLCD_cmd(DISPON_CUROFF_BLKOFF);
  CLCD_cmd(INC_NOSHIFT);
  CLCD_cmd(DISPCLEAR);
  _delay_ms(2);
int main(void){
  char c;
  DDRB=0xf0; PORTB=MOTOR_STANDBY;
  TCCR2=0x6b; OCR2=0;
  init_CLCD();
  _delay_ms(500);
  UCSR0B=0x18; UBRR0L=8;
    if(!available0()){
      c=getchar0();
      putchar0(c);
      CLCD_cmd(CUR1LINE); CLCD_puts(Fan_name);
      CLCD_cmd(CUR2LINE); CLCD_puts(START_LCD);
      switch(c){
        case '0' :
              CLCD_cmd(DISPCLEAR); CLCD_cmd(CUR1LINE); CLCD_puts(Fan_name);
              CLCD_cmd(CUR2LINE);  CLCD_puts(STOP_SPEED1);
              PORTB=MOTOR_STOP;  OCR2=motor_speed[0];
        case '1' :
              CLCD_cmd(CUR2LINE);  CLCD_puts(LOW_SPEED1);
              PORTB=MOTOR_CW;    OCR2=motor_speed[1];
        case '2' :
              CLCD_cmd(CUR2LINE);  CLCD_puts(MID_SPEED1);
              PORTB=MOTOR_CW;    OCR2=motor_speed[2];
        case '3' :
              CLCD_cmd(CUR2LINE); CLCD_puts(HIGH_SPEED1);
              PORTB=MOTOR_CW;            OCR2=motor_speed[3];
        default :
              //CLCD_cmd(DISPCLEAR);
              //CLCD_cmd(CUR1LINE); CLCD_puts(Fan_name);
              //CLCD_cmd(CUR2LINE); CLCD_puts(ERROR);
댓글 3
조회수 845
fanfan님의 댓글
fanfan 작성일
#define STATE_0 0
#define STATE_1 1
#define STATE_2 2
#define STATE_3 3
#define NULL 0x00
unsigned char c = STATE_0;
#define E_BIT 0x04
#define RW_BIT 0x03
#define RS_BIT 0x02
void CLCD_cmd(char);
void CLCD_data(char);
void CLCD_puts(char *);
void display_fnd(unsigned int value);
void init_CLCD();
void init_uart0();
char Fan_name[] = "Good Fan";
char START_LCD[] = "Put the number!";
char STOP_SPEED1[] = "Turn Off!";
char LOW_SPEED1[] = "Speed State 1";
char MID_SPEED1[] = "Speed State 2";
char HIGH_SPEED1[] = "Speed State 3";
char ERROR[] = "Put 1 or 2 or 3";
int motor_speed[4] = {STOP_SPEED, LOW_SPEED, MID_SPEED, HIGH_SPEED};
while(!(UCSR0A & 0x20))
UDR0 = c;
void puts0(char *ptr)
while(*ptr != NULL)
putchar0(*ptr++);
char available0()
if(UCSR0A & 0x80)
return(1);
return(0);
char getchar0()
while(!(UCSR0A & 0x80))
return(UDR0);
void init_uart0()
UCSR0B = 0x18;
UCSR0C = 0x06;
UBRR0H = 0;
UBRR0L = 8;
char c;
DDRB = 0xf0;
PORTB = MOTOR_STANDBY;
TCCR2 = 0x6b;
OCR2 = 0;
init_CLCD();
_delay_ms(500);
init_uart0();
if(!available0()){
CLCD_cmd(CUR1LINE);
CLCD_cmd(CUR2LINE);
c = getchar0();
putchar0(c);
switch(c)
case '0' :
CLCD_cmd(CUR1LINE);
CLCD_cmd(CUR2LINE);
PORTB = MOTOR_STOP;
OCR2 = motor_speed[0];
case '1' :
CLCD_cmd(CUR1LINE);
CLCD_cmd(CUR2LINE);
PORTB = MOTOR_CW;
OCR2 = motor_speed[1];
case '2' :
CLCD_cmd(CUR1LINE);
CLCD_cmd(CUR2LINE);
PORTB = MOTOR_CW;
OCR2 = motor_speed[2];
case '3' :
CLCD_cmd(CUR1LINE);
CLCD_cmd(CUR2LINE);
PORTB = MOTOR_CW;
OCR2 = motor_speed[3];
default :
//CLCD_puts(Fan_name);
//CLCD_puts(ERROR);
void init_CLCD()
DDRC = 0xff;
DDRD = 0xff;
_delay_ms(50);
PORTC = 0x00;
_delay_ms(2);
while(*ptr != NULL)
CLCD_data(*ptr++);
PORTD = 0x04;
_delay_us(1);
PORTD = 0x14;
PORTC = data & 0xf0;
PORTD = 0x04;
_delay_us(2);
PORTD = 0x14;
PORTC = (data << 4) & 0xf0;
PORTD = 0x04;
_delay_ms(1);
PORTD = 0x00;
_delay_us(1);
PORTD = 0x10;
PORTC = cmd & 0xf0;
PORTD = 0x00;
_delay_us(2);
PORTD = 0x10;
PORTC = (cmd << 4) & 0xf0;
PORTD = 0x00;
_delay_ms(1);
위와 같이 수정된 코드로 실행을 하면, 통신과 LCD와 모터가 작동을 하질 않습니다..  어느 부분이 잘못된 부분일까요? 답변을 통해서 알려주신 부분이 정확하게 이해도 되고 실행을 했지만, 작동 자체를 하질 않습니다..
통신을 UART1(포트D)에 연결한 것은 아닌가요?
일부 오류를 발견했으니 다시 복사해서 돌려보세요
int main(void){
  char c;
  TCCR2=0x6b; OCR2=0;
  init_CLCD();
  _delay_ms(500);
  UCSR1B=0x18; UBRR1L=8;
      _delay_ms(1000);
기능체크는 간단한 코드로 테스트 하세요
LCD 체크는 이 코드로 돌려보면 됩니다.
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 23430
공지 사이트 이용 안내댓글[30] master 17-10-29 36693
질문 분주비와 업/업다운 카운트 관련 질문 드립니다.댓글[1] 412904 24-02-18 13
질문 stm32의 task댓글[1] 라칸 24-02-07 20
질문 stm32에서 ping 같은걸 해볼수 있나요?댓글[1] 라칸 24-01-23 67
질문 (초보)atmega128 led 제어 질문드립니다댓글[1] aaa123 24-01-22 94
질문 UART 통신을 하는데댓글[4] 라칸 24-01-10 272
질문 트랜지스터를 2개 쓰는이유댓글[2] 이미지첨부파일 소정이 24-01-10 174
질문 ,아두이노 서보모터 블루투스 연결댓글[4] 비누 23-12-22 972
질문 arduino 코드를 armega 128로 변환댓글[1] 이모저모 23-12-20 216
질문 MTP 주소 지정 방법댓글[1] adoui 23-12-19 207
질문 All-in-one air quality sensor Fosen 23-12-18 119
질문 Atmega128 PORTB에서 서보모터와 부저 사용 관련 질문 ynbus 23-12-17 254
답변 답변글 답변 : Atmega128 PORTB에서 서보모터와 부저 사용 관련 질문댓글[1] master 23-12-17 502
질문 ATmega128에 MQ-3 센서를 사용하는 방법을 찾고 있습니다.댓글[1] 첨부파일 c언어초보 23-12-16 270
질문 3축 자이로센서로 진동값 계산하는 방법좀댓글[1] 라칸 23-12-15 222
질문 avr codevision에 led 교차하면서 소리나게 하는 법을 알고싶습니다.댓글[1] 주넘 23-12-14 266
질문 방금 글쓴 사람입니다!댓글[5] 이미지 범뚱 23-12-14 567
질문 이 코드에서 절대 7세그먼트 디스플레이에 불이 들어오지 않는데 왜 그럴까요?댓글[2] 범뚱 23-12-14 322
질문 아두이노 라인트레이서 질문 있습니다. 99999 23-12-14 191
답변 답변글 답변 : 아두이노 라인트레이서 질문 있습니다. master 23-12-14 179
질문 우노는 되는데 메가가 안됩니다(초음파)댓글[3] 초두이노 23-12-13 312
질문 atmega128 dht11 온도 센서 데이터출력댓글[4] 재효김 23-12-13 792
질문 ATMega128a 사용한 디지털 시계 질문입니다.댓글[3] 첨부파일 moon99 23-12-13 565
질문 서보모터 드라이버 관련 질문입니다.댓글[1] 뚱보개 23-12-13 219
질문 Atmega128 USART 질문입니다.댓글[1] dnjsjj 23-12-13 275
질문 codevision avr atmega128a 사용중입니다 범뚱 23-12-12 327
답변 답변글 답변 : codevision avr atmega128a 사용중입니다 master 23-12-13 236
질문 아두이노 주파수 변경하는법댓글[1] 파란하늘 23-12-12 288
질문 atmega 128 timer interrupt에 관한 질문 atmemem 23-12-12 269
