질문게시판 > 아두이노 라인트레이서 질문 있습니다.
TODAY680 TOTAL3,245,090
BASIC4MCU | 질문게시판 | 아두이노 라인트레이서 질문 있습니다.
작성자 99999 작성일2023-12-14 18:45 조회330회 댓글0건
#define motor1EnablePin 9
#define motor1_1 4
#define motor1_2 7
#define motor2EnablePin 10
#define motor2_1 8
#define motor2_2 12
int bluetoothTx = 2;
int bluetoothRx = 3;
int infrared1 = 13;
int infrared2 = 5;
int infrared3 = 11;
int infrared4 = 6;
int motor1Speed = 0;
int motor2Speed = 0;
SoftwareSerial bluetooth(bluetoothTx, bluetoothRx);
  bluetooth.begin(9600);
  pinMode(motor1_1, OUTPUT);
  pinMode(motor1_2, OUTPUT);
  pinMode(motor2_1, OUTPUT);
  pinMode(motor2_2, OUTPUT);
  pinMode(motor1EnablePin, OUTPUT);
  pinMode(motor2EnablePin, OUTPUT);
  pinMode(infrared1, INPUT);
  pinMode(infrared2, INPUT);
  pinMode(infrared3, INPUT);
  pinMode(infrared4, INPUT);
  char cmd=' ';
  int state1 = digitalRead(infrared1);
    int state2 = digitalRead(infrared2);
    int state3 = digitalRead(infrared3);
    int state4 = digitalRead(infrared4);
    motor1Speed = constrain(motor1Speed, -255, 255);
    motor2Speed = constrain(motor2Speed, -255, 255);
/*if (bluetooth.available())
  cmd = (char)bluetooth.read();
  while(cmd=='w')
    if (state1 == 0 && state2 == 0 && state3 == 0 && state4 == 0)
       do{
        motor1Speed = 130;
        motor2Speed = 130;
        Serial.println("w");
       }while (state1 == 0 && state2 == 0 && state3 == 0 && state4 == 0);
    else if (state1 == 0 && state2 == 0 && state3 == 0 && state4 == 1)
     do{
        Serial.println("6");
        motor1Speed = 10;
        motor2Speed = 130;
      }while (!(state1== 1 && state2 == 0 && state3 == 0 && state4 == 0));
      else if (state1 == 0 && state2 == 1 && state3 == 0 && state4 == 0)
      do{
        Serial.println("0");
        motor1Speed = 10;
        motor2Speed = 130;
      }while (!(state1== 0 && state2 == 0 && state3 == 0 && state4 == 0));
    else if (state1 == 0 && state2 == 1 && state3 == 0 && state4 == 1)
      do{
        motor1Speed = 10;
        motor2Speed = 130;
        Serial.println("1");
    else if (state1 == 1 && state2 == 0 && state3 == 1 && state4 == 0)
      do{
        motor1Speed = 130;
        motor2Speed = 10;
        Serial.println("2");
      }while (!(state1== 0 && state2 == 1 && state3 == 0 && state4 == 0));
    else if (state1 == 0 && state2 == 0 && state3 == 1 && state4 == 0)
      do{
        motor1Speed = 130;
        motor2Speed = 10;
        Serial.println("3");
    else if (state1 == 1 && state2 == 0 && state3 == 0 && state4 == 0)
      do{
        motor1Speed = 130;
        motor2Speed = 10;
        Serial.println("4");
     else if (state1 == 1 && state2 == 1 && state3 == 1 && state4 == 1)
       do{
        motor1Speed = 0;
        motor2Speed = 0;
       }while (state1 == 1 && state2 == 1 && state3 == 1 && state4 == 1);
       motor1Speed = 0;
        motor2Speed = 0
    if (motor1Speed > 0) {
      digitalWrite(motor1_1, HIGH);
      digitalWrite(motor1_2, LOW);
    } else if (motor1Speed < 0) {
      digitalWrite(motor1_1, LOW);
      digitalWrite(motor1_2, HIGH);
    } else {
    analogWrite(motor1EnablePin, abs(motor1Speed));
    if (motor2Speed > 0) {
      digitalWrite(motor2_1, HIGH);
      digitalWrite(motor2_2, LOW);
    } else if (motor2Speed < 0) {
      digitalWrite(motor2_1, LOW);
      digitalWrite(motor2_2, HIGH);
    } else {
    analogWrite(motor2EnablePin, abs(motor2Speed));
적외선 센서 4개를 이용하여 라인트레이서를 제작하였는데 실제 주행을 해보면 0000일때 회전을 하는 등의 문제가 생기는데 어디서 문제가 있는 지 모르겟습니다
0100좌회전
1000우회전
0001 1000이 될때까지  좌회전
0010 0100이 될때까지 우회전
0101 1000이 될때까지  좌회전
1010 0100이 될때까지 우회전
0000 직진입니다.
조회수 330
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 23599
공지 사이트 이용 안내댓글[30] master 17-10-29 37229
질문 초음파센서에 아무것도 잡히지 않을 시 그래프를 비워놓는 방법 질문드립니다. 새글 idghte 24-04-14 19
답변 답변글 답변 : 초음파센서에 아무것도 잡히지 않을 시 그래프를 비워놓는 방법 질문드립니다. 새글 master 24-04-14 18
질문 심박 및 산소포화도 센서 오류댓글[3] 별dl 24-04-10 101
질문 ATmega128 출력비교인터럽트 질문댓글[2] Dkliekeun 24-04-09 91
질문 smt32405 타이머질문댓글[4] stm32 24-04-08 110
질문 초음파센서 3개 동시 동작 기능구현 도와주세요,,,,댓글[5] hmkim 24-04-08 132
질문 이 부품은 뭔가요?댓글[1] 이미지첨부파일 아두이노초보보 24-04-08 78
질문 아두이노 코딩 문제 도움주시면 감사하겠습니다. 제발요 24-04-05 78
답변 답변글 답변 : 아두이노 코딩 문제 도움주시면 감사하겠습니다.댓글[1] master 24-04-06 87
질문 atmega128 srf-05 초음파 센서 코딩에 FQ-041 능동 DC부저 코딩 연결 해야하는데 도움 주시…댓글[3] 도움필요 24-04-04 105
질문 (초보)알파벳 A만들고 행 제어하기댓글[3] SKYUN 24-04-02 85
질문 CUBE Progrmammer 설정 변경 에러 해결법좀댓글[1] 이미지 라칸 24-03-29 89
질문 atmega128로 압력센서를 사용하려고 합니다댓글[2] vbn667766 24-03-28 119
질문 stm32f405오류 질문댓글[2] stm32 24-03-27 95
질문 안녕하세요 세그먼트 질문입니다댓글[4] stm32 24-03-21 197
질문 No source available for "<signal handler called>() at 0xffff…댓글[2] 라칸 24-03-20 137
질문 QA6P 압력센서를 이용한 모터제어 질문댓글[2] 이미지첨부파일 IMAZ 24-03-17 159
질문 아두이노와 앱인벤터 관련 질문드립니다.. 이미지첨부파일 쏘니 24-03-12 139
답변 답변글 답변 : 아두이노와 앱인벤터 관련 질문드립니다.. 이미지 master 24-03-12 137
질문 Atmega128A 초음파 3개로 led3개를 각각 제어하고 싶은데 안됩니다 도와주세요..댓글[2] 밍토리 24-03-11 237
질문 서보 모터 제어댓글[1] 제발요 24-03-07 173
질문 스텝모터 아두이노 제어 질무드립니다댓글[4] 제발요 24-03-04 289
질문 분주비와 업/업다운 카운트 관련 질문 드립니다.댓글[3] 412904 24-02-18 199
질문 stm32의 task댓글[1] 라칸 24-02-07 187
질문 stm32에서 ping 같은걸 해볼수 있나요?댓글[1] 라칸 24-01-23 238
질문 (초보)atmega128 led 제어 질문드립니다댓글[1] aaa123 24-01-22 312
질문 UART 통신을 하는데댓글[4] 라칸 24-01-10 494
질문 트랜지스터를 2개 쓰는이유댓글[2] 이미지첨부파일 소정이 24-01-10 361
