질문게시판 > 안녕하세요 STM32F103 HSE 관련해서 질문드립니다.
TODAY8,306 TOTAL4,428,836
BASIC4MCU | 질문게시판 | 안녕하세요 STM32F103 HSE 관련해서 질문드립니다.
작성자 27315co 작성일2018-08-02 19:09 조회15,993회 댓글2건
안녕하세요 제가 STM32F103 을하면서 궁금한점이 생겼는데요
다름이아니고 시스템 클록을 최대치인 72MHZ로 설정을 하려고합니다. 설정하는 방법중 하나로써 HSE 와 PLL 을 사용하여서 HSE의 OSC_IN OSC_OUT 단자에 16 MHZ의 크리스털을 접속시킨뒤 PLL 을 사용해 4.5배로 체배해서 72MHZ의 CLK 을 시스템 클럭으로 사용하려고 하는데요
제가사용하고있는 보드에서 (NUCLEO-F103RB) Datasheet를 참고해보니 OSC_IN 과 OSC_OUT에 기본적으로 16MHZ 의 크리스털이 연결되있지가 않아서 제가 직접 외부 핀헤더로 연결을 시키려고해보니 외부핀헤더에 OSC_IN 과 OSC_OUT 핀이 없는것 같습니다. 그래서 주파수와 관련된 사항들을 읽어보니까
OSC clock supply
There are four ways to configure the pins corresponding to external high-speed clock (HSE):
• MCO from ST-LINK: MCO output of ST-LINK MCU is used as input clock. This
frequency cannot be changed, it is fixed at 8 MHz and connected to
PF0/PD0/PH0-OSC_IN of the STM32 microcontroller.
The following configuration is needed:
– SB55 OFF and SB54 ON
– SB16 and SB50 ON
– R35 and R37 removed
• HSE oscillator on-board from X3 crystal (not provided): for typical frequencies and
its capacitors and resistors, refer to STM32 microcontroller datasheet. Refer to the
AN2867 Application note for oscillator design guide for STM32 microcontrollers.The X3
crystal has the following characteristics: 8 MHz, 16 pF, 20 ppm, and DIP footprint. It is
recommended to use 9SL8000016AFXHF0 manufactured by Hong Kong X'tals
Limited.
– SB54 and SB55 OFF
– R35 and R37 soldered
– C33 and C34 soldered with 20 pF capacitors
– SB16 and SB50 OFF
• Oscillator from external PF0/PD0/PH0: from an external oscillator through pin 29 of
the CN7 connector.
– SB55 ON
– SB50 OFF
• HSE not used: PF0/PD0/PH0 and PF1/PD1/PH1 are used as GPIO instead of clock
– SB54 and SB55 ON
– SB16 and SB50 (MCO) OFF
There are two possible default configurations of the HSE pins, depending on the version of the STM32 Nucleo board hardware.
The board version MB1136 C-01 or MB1136 C-02 is mentioned on the sticker, placed on the bottom side of the PCB.
The board marking MB1136 C-01 corresponds to a board, configured as HSE not used.
The board marking MB1136 C-02 (or higher) corresponds to a board, configured to use
ST-LINK MCO as clock input.
다음과같이 HSE를 사용하려면 보드에 soldering 이 되지않은 부분에 soldering 을 하고 저항이 붙지않은부분에 저항또한 soldering을 하라는것같은데 제가 직접 보드에 알맞는 저항이나 커패시터를 구입을해서 직접 땜을해야되는것인가요?? 아니면 SYSTEMCLK 을 72MHZ로 설정할수있는 다른 방법이 있는지 여쭈어봅니다.
조회수 15,993
설정은 CUBEMX로 하면 편할테고요
외부 x-tal을 사용한다면 8MHz X-TAL을 사용하세요
회로도 잘 체크하시고
SB(솔더 브릿지) 설정 맞추세요
https://m.blog.naver.com/PostView.nhn?blogId=thumbdown&logNo=220277447906&proxyReferer=https%3A%2F%2Fwww.google.co.kr%2F
이 글도 참고하시고요
질문 아두이노 온습도센서 코딩 오류 질문 master 18-08-09 13985
질문 아두이노 메인보드 고장 질문 master 18-08-09 12066
질문 ATMEGA128을 이용한 DC모터 제어 질문 master 18-08-09 10170
질문 컴퓨터 10진수로 만들면 안되나요? master 18-08-09 13164
질문 아두이노 시리얼 통신 질문 master 18-08-09 10630
질문 아두이노 블루투스 통신. HC-06 질문 master 18-08-09 10334
질문 속도감지센서,초음파센서,서보모터 질문입니다. 첨부파일 비공개 18-08-09 10043
답변 답변글 답변 : 속도감지센서,초음파센서,서보모터 질문입니다. master 18-08-09 13134
질문 아두이노 신호등 질문 master 18-08-08 12212
질문 디지털 인풋회로 설계 관련 질문 master 18-08-08 12303
질문 sla7078mpr 스탭모터 제어댓글[3] 이미지첨부파일 비공개 18-08-07 22442
질문 스텝모터 제어댓글[1] 비공개 18-08-07 12651
답변 답변글 답변 : 스텝모터 제어 master 18-08-07 11175
질문 아두이노 온습도 , 조도센서 led 질문 master 18-08-07 11901
질문 Panasonic IC에 F/W 입력 질문 master 18-08-07 11808
질문 이런 논리회로는 어떻게 해석 하나요? master 18-08-07 12867
질문 아두이노 i/o 확장핀댓글[2] 이미지첨부파일 hwanga 18-08-07 13175
질문 MAX DC 125V 측정 회로댓글[8] 이미지 비공개 18-08-07 45314
답변 답변글 다시 질문 드려요댓글[3] 이미지 비공개 18-08-07 13789
질문 sla7078mr 스태핑모터 제어 질문댓글[1] uln2 18-08-06 10382
질문 아두이노 i/o 확장쉴드댓글[1] 이미지첨부파일 hwanga 18-08-06 11331
질문 8051 사운드 센서 회로댓글[3] 디코랩 18-08-06 15811
답변 답변글 답변 : 8051 사운드 센서 회로 이미지 master 18-08-06 11889
질문 8051 적외선 센서댓글[7] rohyunge 18-08-06 33020
답변 답변글 답변 : 8051 적외선 센서댓글[3] master 18-08-06 16771
질문 스텝모터 C코드댓글[6] 이미지 rohyunge 18-08-06 29249
질문 아두이노 컴파일오류댓글[3] 이미지 나나 18-08-06 14776
답변 답변글 답변 : 아두이노 컴파일오류- 아직 미해결댓글[1] 이미지첨부파일 나나 18-08-06 12971
질문 8051 모터제어 회로문제 있는지댓글[5] 이미지 rohyunge 18-08-06 30912
질문 아두이노 스텝모터 제어 질문 이미지 master 18-08-04 13574
