BASIC4MCU | 질문게시판 | 아두이노로 물주기(스마트 화분) 질문
작성자 master 작성일2018-08-14 11:21 조회5,728회 댓글0건본문
키트를 구매해서 만들었는데 워터펌프 작동이 안됨미다ㅏ..
코드도 그대로 넣었는데 뭐가 문제일까요?ㅠㅠ
// set all moisture sensors PIN ID
int moisture1 = A0;
int moisture2 = A1;
int moisture3 = A2;
int moisture4 = A3;// declare moisture values
int moisture1_value = 0;
int moisture2_value = 0;
int moisture3_value = 0;
int moisture4_value = 0;// set water relays
int relay1 = 3;
int relay2 = 4;
int relay3 = 5;
int relay4 = 6;// set water pump
int pump = 2;void setup() {
// declare relay as output
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
pinMode(relay3, OUTPUT);
pinMode(relay4, OUTPUT);
// declare pump as output
pinMode(pump, OUTPUT);
// declare the ledPin as an OUTPUT:
}void loop() {
// read the value from the moisture sensors:
moisture1_value = analogRead(moisture1);
moisture2_value = analogRead(moisture2);
moisture3_value = analogRead(moisture3);
moisture4_value = analogRead(moisture4);
// check which plant need water
// and open the switch for that specific plant
if(moisture1_value<=450){
digitalWrite(relay1, HIGH);
if(moisture2_value<=450){
digitalWrite(relay2, HIGH);
if(moisture3_value<=450){
digitalWrite(relay3, HIGH);
if(moisture4_value<=450){
digitalWrite(relay4, HIGH);
// make sure there is at least one plant that needs water
// if there is, open the motor
if(moisture1_value<=450 || moisture2_value<=450 || moisture3_value<=450 || moisture4_value<=450){
digitalWrite(pump, HIGH);
// let it water the plant for 5 seconds
delay(5000);
// turn the pump off
digitalWrite(pump, LOW);
// go each switch and turn them off
digitalWrite(relay1, LOW);
digitalWrite(relay2, LOW);
digitalWrite(relay3, LOW);
digitalWrite(relay4, LOW);
// wait 5 seconds and repeat the process
delay(30000);
혹시 몰라서 연결한 사진도
보드 및 모듈의 판매처 링크를 적어보세요
조회수 5,728등록된 댓글이 없습니다.
