질문게시판 > 답변 2: 아트메가 서보모터 구동 질문
TODAY113 TOTAL2,582,192
BASIC4MCU | 질문게시판 | 답변 2: 아트메가 서보모터 구동 질문
작성자 master 작성일2018-09-02 10:49 조회6,313회 댓글0건
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#include <stdio.h>
#define BV(bit)       (1<<(bit))/*bit processing*/
#define cbi(reg,bit)  reg&=~(BV(bit))
#define sbi(reg,bit)  reg|=(BV(bit))
#define MOTOR_ON      sbi(PORTG,0)
#define MOTOR_OFF     cbi(PORTG,0)
volatile unsigned int  value,wg,wg2,H,M,L,HC,MC,LC;
volatile unsigned char j=0,count,i,step,en,str[21];
volatile unsigned char lcd_flag=0;
void LCD_cmd(char c) { PORTC=1PORTA=cPORTC=0_delay_us(1); PORTC=1_delay_us(50); }
void LCD_data(char d){ PORTC=3PORTA=dPORTC=2_delay_us(1); PORTC=3_delay_us(50); }
void LCD_str(char c,char *s){ LCD_cmd(c); while(*s)LCD_data(*s++); }
void LCD_initialize(void){
  _delay_ms(50);
  PORTC=0x03PORTC=0x02_delay_ms(2); // E=1,Rs=1(dummy write)// E=0,Rs=1
  LCD_cmd(0x38); // function set(8 bit,2 line,5x7 dot)
  LCD_cmd(0x0C); // display control(display ON,cursor OFF)
  LCD_cmd(0x06); // entry mode set(increment,not shift)
  LCD_cmd(0x01); // clear display
  _delay_ms(2);
#define  SV1_1  PORTB|=1
#define  SV1_0  PORTB&=~1
void rc1_f(void){ for(i=0;i<50;i++){ SV1_1_delay_us700); SV1_0_delay_us(19300); } }
void rc1_b(void){ for(i=0;i<50;i++){ SV1_1_delay_us(2300); SV1_0_delay_us(17700); } }
#define  SV2_1  PORTB|=0x20
#define  SV2_0  PORTB&=~0x20
void rc2_f(void){ for(i=0;i<50;i++){ SV2_1_delay_us700); SV2_0_delay_us(19300); } }
void rc2_b(void){ for(i=0;i<50;i++){ SV2_1_delay_us(2300); SV2_0_delay_us(17700); } }
#define  SV3_1  PORTB|=0x40
#define  SV3_0  PORTB&=~0x40
void rc3_f(void){ for(i=0;i<50;i++){ SV3_1_delay_us700); SV3_0_delay_us(19300); } }
void rc3_b(void){ for(i=0;i<50;i++){ SV3_1_delay_us(2300); SV3_0_delay_us(17700); } }
#define  SV4_1  PORTB|=0x80
#define  SV4_0  PORTB&=~0x80
void rc4_f(void){ for(i=0;i<50;i++){ SV4_1_delay_us700); SV4_0_delay_us(19300); } }
void rc4_b(void){ for(i=0;i<50;i++){ SV4_1_delay_us(2300); SV4_0_delay_us(17700); } }
/*ISR(INT0_vect){}*/
//---------------------------------------수신-------------------------------------------
// W  2  .  2
//57 32 2E 32 0D 0A
ISR(USART1_RX_vect){ // 수신인터럽트 함수
  static char r,k=0,cmd_f=0;
  static int  tpW=0;
  r=UDR1;
  if(r=='W'){ tpW=0cmd_f=0// 0x57 헤더?
  else if(r==0x2E){ cmd_f=1; }    // 0x2E '.'
  else if(r==0x0D){}
  else if(r==0x0A){ // 종료문자
    wg=tpW;
    lcd_flag=1;
    tpW=0cmd_f=0;
    if(cmd_f==0){ tpW*=10tpW+=r&0x0F; }
int main(void){
  MCUCR=0x00// enable external memory and I/O
  XMCRA=0x44// 0x1100-0x7FFF=1 wait,0x8000-0xFFFF=0 wait
  XMCRB=0x80// enable bus keeper,use PC0-PC7 as address
  DDRA=0xFF;
  PORTB=0xFFDDRB=0xFF;
  DDRC=0xFF;  // PC7-PC4=output
  DDRE=0x80;  // PE5-PE0=output,PE7-PE6=input
  PORTG=0x02DDRG=0xff// PORTG=output
  //-----통신 설정--------------------------------------------------------
  UBRR1L=103UCSR1B=0x98// 9600 baud // 수신 완료 인터럽트 허용
  //--------PWM 설정 타이머 0를 사용---------------좌우 스피드
  TCCR0=0x61OCR0=180;
  LCD_initialize();
  //------기준 무게 설정---------------------------
  H=150M=100L=50;
  sprintf(str,"H=%4d  M=%4d  ",H,M); LCD_str(0x80,str);
  sprintf(str,"L=%4d          ",L);  LCD_str(0xC0,str);
  rc1_b(); rc2_b(); rc3_b(); rc4_b();
  _delay_ms(3000);
  HC=0MC=0LC=0;
  sprintf(str,"H=%3d M=%3d L=%2d",HC,MC,LC); LCD_str(0x80,str);
  sprintf(str,"weight=    0g   ",L);         LCD_str(0xC0,str);
  wg=0step=0;
  sei();
    //--- 중량 수신 ------------------------------
    if(lcd_flag){ lcd_flag=0sprintf(str,"weight= %4d g",wg); LCD_str(0xC0,str); }
    if(step==0){ // 무게 감지 단계
      if(wg>10){ // 10그람 이상되어야 함
        if(++count>30){
          if     (wg<= 50){ step=1; } // L 이송단계로 이동
          else if(wg<=100){ step=2; } // M 이송단계로 이동
        //else if(wg<=150){ step=3; } // H 이송단계로 이동
          else            { step=3; } // H 이송단계로 이동
          rc1_f(); _delay_ms(1000); rc1_b();
          MOTOR_ON;
      elsecount=0; }
    if(step==1){ // L 이송단계
      if(!(PIND&0x10)){ step=0
        MOTOR_OFF_delay_ms(1000); rc2_f(); _delay_ms(1000); rc2_b();
        LC++; sprintf(str,"H=%3d M=%3d L=%2d",HC,MC,LC); LCD_str(0x80,str);
    if(step==2){ // M 이송단계
      if(!(PIND&0x20)){ step=0;
        MOTOR_OFF_delay_ms(1000); rc3_f(); _delay_ms(1000); rc3_b();
        MC++; sprintf(str,"H=%3d M=%3d L=%2d",HC,MC,LC); LCD_str(0x80,str);
    if(step==3){ // H 이송단계
      if(!(PIND&0x40)){ step=0;
        MOTOR_OFF_delay_ms(1000); rc4_f(); _delay_ms(1000); rc4_b();
        HC++; sprintf(str,"H=%3d M=%3d L=%2d",HC,MC,LC); LCD_str(0x80,str);
    if(!(PIND&0x01)){ MOTOR_OFFwhile(1); }
    _delay_ms(100);
타이머1과 타이머3을 사용하고 있지 않는데요
타이머1과 타이머3의 PWM을 사용해서 RC 서보모터를 구동하면 편합니다.
조회수 6,313
질문 아두이노 블루투스 관련 질문입니다. 생물공학도 23-02-21 99
