질문게시판 > 답변2 : 74HC245
TODAY77 TOTAL2,325,734
BASIC4MCU | 질문게시판 | 답변2 : 74HC245
작성자 master 작성일2018-03-09 16:34 조회6,623회 댓글0건
// CONFIG1
#pragma config FOSC=HS   // Oscillator Selection bits(HS oscillator: High-speed crystal/resonator on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN)
#pragma config WDTE=OFF  // Watchdog Timer Enable bit(WDT enabled)
#pragma config PWRTE=ON  // Power-up Timer Enable bit(PWRT disabled)
#pragma config MCLRE=ON  // RE3/MCLR pin function select bit(RE3/MCLR pin function is MCLR)
#pragma config CP=OFF    // Code Protection bit(Program memory code protection is disabled)
#pragma config CPD=OFF   // Data Code Protection bit(Data memory code protection is disabled)
#pragma config BOREN=OFF // Brown Out Reset Selection bits(BOR enabled)
#pragma config IESO=ON   // Internal External Switchover bit(Internal/External Switchover mode is enabled)
#pragma config FCMEN=ON  // Fail-Safe Clock Monitor Enabled bit(Fail-Safe Clock Monitor is enabled)
#pragma config LVP=ON    // Low Voltage Programming Enable bit(RB3/PGM pin has PGM function,low voltage programming enabled)
// CONFIG2
#pragma config BOR4V=BOR40V // Brown-out Reset Selection bit(Brown-out Reset set to 4.0V)
#pragma config WRT=OFF      // Flash Program Memory Self Write Enable bits(Write protection off)
#include
#define FND_C_EN   PORTBbits.RB0
#define KEY_EN     PORTBbits.RB1
#define FND_D_EN   PORTCbits.RC2
#define _XTAL_FREQ 20000000
#define COM_EN     {FND_C_EN=1;  FND_C_EN=0;}
#define SEG_EN     {FND_D_EN=1;  FND_D_EN=0;}
unsigned char seg[13]={
  0b11101011,0b00101000,0b10110011,0b10111010,0b01111000,// 0~4
  0b11011010,0b11011011,0b11101000,0b11111011,0b11111010,// 5~9
  0x10,0x00,0x02 //-, ,_
char key_buf=0xFF;
unsigned int num=0;
void key_input(void){ TRISD=0x00KEY_EN=0key_buf=PORTDKEY_EN=1TRISD=0xFF; }
void fnd_999(void){
  PORTD=8COM_ENPORTD=seg[num/1000  ]; SEG_EN__delay_ms(5);
  PORTD=2COM_ENPORTD=seg[num/100%10]; SEG_EN__delay_ms(5);
  PORTD=4COM_ENPORTD=seg[num/10 %10]; SEG_EN__delay_ms(5);
  PORTD=1COM_ENPORTD=seg[num    %10]; SEG_EN__delay_ms(5);
void main(){
  TRISBbits.TRISB1=1// key_IN/
  TRISBbits.TRISB0=0// FND_C_E
  TRISCbits.TRISC2=0// FND_D_EN
  TRISEbits.TRISE0=0;
  ANSELH=0x00;
    key_buf=key_input();
    fnd_999();
    if(++num>9999)num=0;
void key_input(void){ TRISD=0x00KEY_EN=0    key_buf=PORTDKEY_EN=1TRISD=0xFF; }
포트를 입력으로 변경하고
입력 받을 때 약간의 딜레이를 줘야하는 경우도 있습니다.
문제가 생기면 적색 색칠한 곳에 수us 정도의 딜레이를 준 후에 읽어보세요
만약 윗자리의 숫자가 아랫자리에 영향을 끼치는 경우에는
void fnd_999(void){
  PORTD=seg[num/1000  ]; SEG_ENPORTD=8COM_EN__delay_ms(5); PORTD=0COM_EN
  PORTD=seg[num/100%10]; SEG_ENPORTD=2COM_EN__delay_ms(5); PORTD=0COM_EN
  PORTD=seg[num/10 %10]; SEG_ENPORTD=4COM_EN__delay_ms(5); PORTD=0COM_EN
  PORTD=seg[num    %10]; SEG_ENPORTD=1COM_EN__delay_ms(5); PORTD=0COM_EN
딜레이 후에 FND COMMON 핀을 clear 시키면 도움이 됩니다.
이래도 잔상이 남는다면 라인 제일 마지막에 수us~수십us 정도의 딜레이를 추가하세요
보통 12V 구동의 큰 FND를 구동 할 때 TR의 turn off time이 길어지면서 문제가 많이 생깁니다.
조회수 6,623
질문 질문드립니다. 이호 18-04-06 6447
답변 답변글 답변 : 아두이노 시리얼 입력으로 FND 구동댓글[2] master 18-04-06 9795
질문 블루투스 신호 세기를 측정하려면 어떻게 해야하나요?? 노동 18-04-04 6995
답변 답변글 답변 : 블루투스 신호 세기를 측정하려면 어떻게 해야하나요?? master 18-04-04 8971
질문 아두이노 우노 및 ESP8266 와이파이 모듈 관련 질문 exia 18-04-04 6594
답변 답변글 답변 : 아두이노 우노 및 ESP8266 와이파이 모듈 관련 질문 이미지 master 18-04-04 5869
질문 AVR 4 질문요~ 비공개 18-04-04 5832
답변 답변글 답변 : AVR 4 질문요~ master 18-04-04 6153
질문 AVR atmaga128댓글[1] 첨부파일 비공개 18-04-03 7363
답변 답변글 답변 : AVR atmaga128 1개의 파일로 합침댓글[4] master 18-04-03 15190
답변 답변글 답변 : AVR atmaga128 소스코드 정리 master 18-04-03 6411
답변 답변글 답변 : 답변 : AVR atmaga128 소스코드 정리댓글[3] 첨부파일 턴업 18-04-04 11605
질문 웜기어 추가질문 드립니다!댓글[1] 까스활명 18-04-02 7622
질문 DMA 송수신 관련 질문 드립니다. 몽규 18-04-02 6942
답변 답변글 답변 : DMA 송수신 관련 질문 드립니다. master 18-04-02 6063
답변 답변글 답변2 : DMA 송수신 관련 질문 드립니다.댓글[1] master 18-04-02 6923
질문 웜기어를사용 한 스텝모터 제어댓글[3] 비공개 18-04-01 12786
답변 답변글 답변 : 웜기어를 사용 한 DC모터 이미지 master 18-04-02 7078
질문 왕초보가 질문 하나 또 드립니다댓글[1] Songyoun 18-03-31 7019
질문 자이로가속도 센서 제어댓글[2] 빠박이빠박 18-03-31 9054
질문 PWM관련 질문 드립니다 Songyoun 18-03-29 6252
답변 답변글 답변 : PWM 디지털제어 = 전력제어 master 18-03-29 5856
질문 ATmega128 USART 통신 관련해서 질문드립니다.댓글[1] 27315co 18-03-28 8655
답변 답변글 답변 : ATmega128 USART 통신 관련해서 질문드립니다.댓글[1] master 18-03-28 7732
질문 아두이노 프로그램 시리얼모니터에 나타내는건데요 cimi 18-03-28 5986
답변 답변글 답변 : 소스코드 실행 결과를 적어주세요 master 18-03-28 6128
질문 아두이노 아키텍처 질문댓글[1] 뭘보노옹 18-03-27 8841
질문 밑에 질문 관련 다시 올립니다. exia 18-03-27 6441
답변 답변글 답변 : 소스코드 오류 몇개 수정했습니다.댓글[1] master 18-03-27 6660
질문 아두이노 우노 dht11 센서 두개 동작 질문드립니다. exia 18-03-27 5734
