질문게시판 > 답변2 : 74HC245
TODAY4,842 TOTAL7,751,168
BASIC4MCU | 질문게시판 | 답변2 : 74HC245
작성자 master 작성일2018-03-09 16:34 조회14,191회 댓글0건
// CONFIG1
#pragma config FOSC=HS   // Oscillator Selection bits(HS oscillator: High-speed crystal/resonator on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN)
#pragma config WDTE=OFF  // Watchdog Timer Enable bit(WDT enabled)
#pragma config PWRTE=ON  // Power-up Timer Enable bit(PWRT disabled)
#pragma config MCLRE=ON  // RE3/MCLR pin function select bit(RE3/MCLR pin function is MCLR)
#pragma config CP=OFF    // Code Protection bit(Program memory code protection is disabled)
#pragma config CPD=OFF   // Data Code Protection bit(Data memory code protection is disabled)
#pragma config BOREN=OFF // Brown Out Reset Selection bits(BOR enabled)
#pragma config IESO=ON   // Internal External Switchover bit(Internal/External Switchover mode is enabled)
#pragma config FCMEN=ON  // Fail-Safe Clock Monitor Enabled bit(Fail-Safe Clock Monitor is enabled)
#pragma config LVP=ON    // Low Voltage Programming Enable bit(RB3/PGM pin has PGM function,low voltage programming enabled)
// CONFIG2
#pragma config BOR4V=BOR40V // Brown-out Reset Selection bit(Brown-out Reset set to 4.0V)
#pragma config WRT=OFF      // Flash Program Memory Self Write Enable bits(Write protection off)
#include
#define FND_C_EN   PORTBbits.RB0
#define KEY_EN     PORTBbits.RB1
#define FND_D_EN   PORTCbits.RC2
#define _XTAL_FREQ 20000000
#define COM_EN     {FND_C_EN=1;  FND_C_EN=0;}
#define SEG_EN     {FND_D_EN=1;  FND_D_EN=0;}
unsigned char seg[13]={
  0b11101011,0b00101000,0b10110011,0b10111010,0b01111000,// 0~4
  0b11011010,0b11011011,0b11101000,0b11111011,0b11111010,// 5~9
  0x10,0x00,0x02 //-, ,_
char key_buf=0xFF;
unsigned int num=0;
void key_input(void){ TRISD=0x00KEY_EN=0key_buf=PORTDKEY_EN=1TRISD=0xFF; }
void fnd_999(void){
  PORTD=8COM_ENPORTD=seg[num/1000  ]; SEG_EN__delay_ms(5);
  PORTD=2COM_ENPORTD=seg[num/100%10]; SEG_EN__delay_ms(5);
  PORTD=4COM_ENPORTD=seg[num/10 %10]; SEG_EN__delay_ms(5);
  PORTD=1COM_ENPORTD=seg[num    %10]; SEG_EN__delay_ms(5);
void main(){
  TRISBbits.TRISB1=1// key_IN/
  TRISBbits.TRISB0=0// FND_C_E
  TRISCbits.TRISC2=0// FND_D_EN
  TRISEbits.TRISE0=0;
  ANSELH=0x00;
    key_buf=key_input();
    fnd_999();
    if(++num>9999)num=0;
void key_input(void){ TRISD=0x00KEY_EN=0    key_buf=PORTDKEY_EN=1TRISD=0xFF; }
포트를 입력으로 변경하고
입력 받을 때 약간의 딜레이를 줘야하는 경우도 있습니다.
문제가 생기면 적색 색칠한 곳에 수us 정도의 딜레이를 준 후에 읽어보세요
만약 윗자리의 숫자가 아랫자리에 영향을 끼치는 경우에는
void fnd_999(void){
  PORTD=seg[num/1000  ]; SEG_ENPORTD=8COM_EN__delay_ms(5); PORTD=0COM_EN
  PORTD=seg[num/100%10]; SEG_ENPORTD=2COM_EN__delay_ms(5); PORTD=0COM_EN
  PORTD=seg[num/10 %10]; SEG_ENPORTD=4COM_EN__delay_ms(5); PORTD=0COM_EN
  PORTD=seg[num    %10]; SEG_ENPORTD=1COM_EN__delay_ms(5); PORTD=0COM_EN
딜레이 후에 FND COMMON 핀을 clear 시키면 도움이 됩니다.
이래도 잔상이 남는다면 라인 제일 마지막에 수us~수십us 정도의 딜레이를 추가하세요
보통 12V 구동의 큰 FND를 구동 할 때 TR의 turn off time이 길어지면서 문제가 많이 생깁니다.
조회수 14,191
답변 답변글 답변 : 건설장비에 필요한 운반기 모터선정 master 18-03-11 14653
답변 답변글 답변2 : 무선조종기 master 18-03-11 18389
질문 74HC573을 응용한 PIC 입출력 동시 제어 이미지첨부파일 비공개 18-03-09 15235
답변 답변글 답변 : 74HC573을 응용한 PIC 입출력 동시 제어 master 18-03-09 12001
현재글 답변글 답변2 : 74HC245 이미지 master 18-03-09 14192
답변 답변글 답변3 : 74HC573 고장나는 이유 이미지 master 18-03-10 15099
질문 안녕하세요 졸업작품관련해서 아두이노 질문이 있습니다 비공개 18-03-08 17052
답변 답변글 답변 : RFID 태그 or 블루투스댓글[1] master 18-03-09 21358
답변 답변글 답변2 : 블루투스 + 인체감지센서 + 초음파스피커댓글[1] 이미지 master 18-03-09 23589
질문 FB155BC와 USB MINI DONGLE 을 이용한 노트북 연결 질문드립니다. 승후 18-03-02 14319
답변 답변글 답변 : FB155BC와 USB MINI DONGLE 을 이용한 노트북 연결 질문드립니다. master 18-03-03 11985
질문 여러분들께 도움 부탁드립니다 Songyon 18-02-28 10713
답변 답변글 답변 : 칩저항 및 칩커패시터 게시판 링크댓글[1] master 18-03-03 20563
질문 ifttt sms서비스댓글[1] 도도리 18-02-26 15820
답변 답변글 답변 : ifttt sms서비스댓글[1] 이미지첨부파일 도도리 18-02-27 15333
질문 http request, at command댓글[1] 이미지첨부파일 도도리 18-02-26 15384
질문 AVR 블루투스 데이터 전송댓글[1] 빠박이빠박 18-02-26 19726
질문 실수형 환산 문의.댓글[4] 이미지첨부파일 도도리 18-02-24 35557
질문 uart 송수신 문의드립니다, 도도리 18-02-21 15402
답변 답변글 답변 : uart 송수신 문의드립니다,(정수,문자,믄자열)댓글[1] master 18-02-21 15509
답변 답변글 답변2 : uart 송수신 문의드립니다,(232통신의 기초)댓글[1] master 18-02-21 13737
답변 답변글 답변3 : uart 송수신 문의드립니다,(문자열 수신 예제)댓글[1] master 18-02-21 16992
답변 답변글 답변 : 답변3 : uart 송수신 문의드립니다,(문자열 수신 예제)댓글[3] 도도리 18-02-21 31474
답변 답변글 답변 : uart 송수신 문의드립니다,댓글[2] 도도리 18-02-21 18979
답변 답변글 답변 : 답변 : uart 송수신 문의드립니다,댓글[1] master 18-02-21 17197
질문 cc2530 ADC read 방법댓글[10] 보랑이 18-02-19 121710
질문 안녕하세요 8051 포토커플러 관련 회로에대해서 질문드립니다. 27315co 18-02-18 13194
답변 답변글 답변 : 8051 포토커플러 관련 회로에대해서 질문드립니다. master 18-02-18 12957
답변 답변글 답변2 : 8051 포토커플러 관련 회로에대해서 질문드립니다.(하강엣지 검출) master 18-02-18 12704
답변 답변글 답변3 : 8051 포토커플러 관련 회로에대해서 질문드립니다.(하강엣지 + 상승엣지 검출)댓글[1] master 18-02-18 14475
