BASIC4MCU | 질문게시판 | 아두이노 소스코드 해석 질문
작성자 master 작성일2018-09-14 08:45 조회24,180회 댓글0건본문
이해가 너무 안가네요..... 해석좀 해주세요
#include <Servo.h>
#include <SPI.h>
#include <EEPROM.h>
#include <boards.h>
#include <RBL_nRF8001.h>
#include "Boards.h"#define PROTOCOL_MAJOR_VERSION 0 //
#define PROTOCOL_MINOR_VERSION 0 //
#define PROTOCOL_BUGFIX_VERSION 2 // bugfix#define PIN_CAPABILITY_NONE 0x00
#define PIN_CAPABILITY_DIGITAL 0x01
#define PIN_CAPABILITY_ANALOG 0x02
#define PIN_CAPABILITY_PWM 0x04
#define PIN_CAPABILITY_SERVO 0x08
#define PIN_CAPABILITY_I2C 0x10// pin modes
//#define INPUT 0x00 // defined in wiring.h
//#define OUTPUT 0x01 // defined in wiring.h
#define ANALOG 0x02 // analog pin in analogInput mode
#define PWM 0x03 // digital pin in PWM output mode
#define SERVO 0x04 // digital pin in Servo output modebyte pin_mode[TOTAL_PINS];
byte pin_state[TOTAL_PINS];
byte pin_pwm[TOTAL_PINS];
byte pin_servo[TOTAL_PINS];Servo servos[MAX_SERVOS];
Serial.begin(57600);
Serial.println("BLE Arduino Slave");
/* Default all to digital input */
for (int pin = 0; pin < TOTAL_PINS; pin++)
// Set pin to input with internal pull up
pinMode(pin, INPUT);
digitalWrite(pin, HIGH);// Save pin mode and state
pin_mode[pin] = INPUT;
pin_state[pin] = LOW;
}// Default pins set to 9 and 8 for REQN and RDYN
// Set your REQN and RDYN here before ble_begin() if you need
//ble_set_pins(3, 2);
// Set your BLE Shield name here, max. length 10
//ble_set_name("My Name");
// Init. and start BLE library.
ble_begin();
}static byte buf_len = 0;
void ble_write_string(byte *bytes, uint8_t len)
if (buf_len + len > 20)
for (int j = 0; j < 15000; j++)
ble_do_events();
buf_len = 0;
for (int j = 0; j < len; j++)
ble_write(bytes[j]);
buf_len++;
if (buf_len == 20)
ble_do_events();
buf_len = 0;
}byte reportDigitalInput()
if (!ble_connected())
return 0;static byte pin = 0;
byte report = 0;
if (!IS_PIN_DIGITAL(pin))
pin++;
if (pin >= TOTAL_PINS)
pin = 0;
return 0;
if (pin_mode[pin] == INPUT)
byte current_state = digitalRead(pin);
if (pin_state[pin] != current_state)
pin_state[pin] = current_state;
byte buf[] = {'G', pin, INPUT, current_state};
ble_write_string(buf, 4);
report = 1;
pin++;
pin = 0;
return report;
}void reportPinCapability(byte pin)
byte buf[] = {'P', pin, 0x00};
byte pin_cap = 0;
if (IS_PIN_DIGITAL(pin))
pin_cap |= PIN_CAPABILITY_DIGITAL;
if (IS_PIN_ANALOG(pin))
pin_cap |= PIN_CAPABILITY_ANALOG;if (IS_PIN_PWM(pin))
pin_cap |= PIN_CAPABILITY_PWM;if (IS_PIN_SERVO(pin))
pin_cap |= PIN_CAPABILITY_SERVO;buf[2] = pin_cap;
ble_write_string(buf, 3);
}void reportPinServoData(byte pin)
// if (IS_PIN_SERVO(pin))
// servos[PIN_TO_SERVO(pin)].write(value);
// pin_servo[pin] = value;
byte value = pin_servo[pin];
byte mode = pin_mode[pin];
byte buf[] = {'G', pin, mode, value};
}byte reportPinAnalogData()
return 0;
byte report = 0;
pin++;
pin = 0;
return 0;
if (pin_mode[pin] == ANALOG)
uint16_t value = analogRead(pin);
byte value_lo = value;
byte value_hi = value>>8;
mode = (value_hi << 4) | mode;
byte buf[] = {'G', pin, mode, value_lo};
pin++;
pin = 0;
return report;
}void reportPinDigitalData(byte pin)
byte state = digitalRead(pin);
byte buf[] = {'G', pin, mode, state};
}void reportPinPWMData(byte pin)
byte value = pin_pwm[pin];
}void sendCustomData(uint8_t *buf, uint8_t len)
uint8_t data[20] = "Z";
memcpy(&data[1], buf, len);
ble_write_string(data, len+1);
}byte queryDone = false;
while(ble_available())
byte cmd;
cmd = ble_read();
Serial.write(cmd);
// Parse data here
switch (cmd)
case 'V': // query protocol version
byte buf[] = {'V', 0x00, 0x00, 0x01};
case 'C': // query board total pin count
byte buf[2];
buf[0] = 'C';
buf[1] = TOTAL_PINS;
ble_write_string(buf, 2);
case 'M': // query pin mode
byte pin = ble_read();
byte buf[] = {'M', pin, pin_mode[pin]}; // report pin mode
case 'S': // set pin mode
byte mode = ble_read();
if (IS_PIN_SERVO(pin) && mode != SERVO && servos[PIN_TO_SERVO(pin)].attached())
servos[PIN_TO_SERVO(pin)].detach();
/* ToDo: check the mode is in its capability or not */
/* assume always ok */
if (mode != pin_mode[pin])
pinMode(pin, mode);
pin_mode[pin] = mode;
if (mode == OUTPUT)
digitalWrite(pin, LOW);
else if (mode == INPUT)
pin_state[pin] = HIGH;
else if (mode == ANALOG)
if (IS_PIN_ANALOG(pin)) {
if (IS_PIN_DIGITAL(pin)) {
pinMode(PIN_TO_DIGITAL(pin), LOW);
else if (mode == PWM)
pinMode(PIN_TO_PWM(pin), OUTPUT);
analogWrite(PIN_TO_PWM(pin), 0);
pin_pwm[pin] = 0;
pin_mode[pin] = PWM;
else if (mode == SERVO)
pin_servo[pin] = 0;
pin_mode[pin] = SERVO;
if (!servos[PIN_TO_SERVO(pin)].attached())
servos[PIN_TO_SERVO(pin)].attach(PIN_TO_DIGITAL(pin));
// if (mode == ANALOG)
// reportPinAnalogData(pin);
if ( (mode == INPUT) || (mode == OUTPUT) )
reportPinDigitalData(pin);
reportPinPWMData(pin);
reportPinServoData(pin);
break;case 'G': // query pin data
case 'T': // set pin digital state
byte state = ble_read();
digitalWrite(pin, state);
case 'N': // set PWM
byte value = ble_read();
analogWrite(PIN_TO_PWM(pin), value);
pin_pwm[pin] = value;
case 'O': // set Servo
byte value = ble_read();if (IS_PIN_SERVO(pin))
case 'A': // query all pin status
reportPinCapability(pin);
if ( (pin_mode[pin] == INPUT) || (pin_mode[pin] == OUTPUT) )
else if (pin_mode[pin] == PWM)
else if (pin_mode[pin] == SERVO)
queryDone = true;
uint8_t str[] = "ABC";
sendCustomData(str, 3);
case 'P': // query pin capability
case 'Z':
byte len = ble_read();
byte buf[len];
for (int i=0;i<len;i++)
buf[i] = ble_read();
Serial.println("->");
Serial.print("Received: ");
Serial.print(len);
Serial.println(" byte(s)");
Serial.print(" Hex: ");
Serial.print(buf[i], HEX);
Serial.println();
}// send out any outstanding data
ble_do_events();
buf_len = 0;
return; // only do this task in this loop
}// process text data
if (Serial.available())
byte d = 'Z';
ble_write(d);delay(5);
while(Serial.available())
d = Serial.read();
ble_write(d);
ble_do_events();
buf_len = 0;
return;
}// No input data, no commands, process analog data
queryDone = false; // reset query state
if (queryDone) // only report data after the query state
byte input_data_pending = reportDigitalInput();
if (input_data_pending)
ble_do_events();
buf_len = 0;
reportPinAnalogData();
ble_do_events();
buf_len = 0;
return;
ble_do_events();
buf_len = 0;
// MCU BASIC: https://www.basic4mcu.com// DateTime : 2018-08-30 오전 6:40:07// by Ok-Hyun Park//#include <Servo.h>#include <SPI.h>#include <EEPROM.h>#include <boards.h>#include <RBL_nRF8001.h>#include "Boards.h"#define PROTOCOL_MAJOR_VERSION 0 //#define PROTOCOL_MINOR_VERSION 0 //#define PROTOCOL_BUGFIX_VERSION 2 // bugfix#define PIN_CAPABILITY_NONE 0x00#define PIN_CAPABILITY_DIGITAL 0x01#define PIN_CAPABILITY_ANALOG 0x02#define PIN_CAPABILITY_PWM 0x04#define PIN_CAPABILITY_SERVO 0x08#define PIN_CAPABILITY_I2C 0x10// pin modes//#define INPUT 0x00 // defined in wiring.h//#define OUTPUT 0x01 // defined in wiring.h#define ANALOG 0x02 // analog pin in analogInput mode#define PWM 0x03 // digital pin in PWM output mode#define SERVO 0x04 // digital pin in Servo output modebyte pin_mode[TOTAL_PINS];byte pin_state[TOTAL_PINS];byte pin_pwm[TOTAL_PINS];byte pin_servo[TOTAL_PINS];Servo servos[MAX_SERVOS];//void setup(){Serial.begin(57600);Serial.println("BLE Arduino Slave");/*Default all to digital input*/for(int pin=0;pin<TOTAL_PINS;pin++){pinMode(pin,INPUT); digitalWrite(pin,HIGH); // Set pin to input with internal pull uppin_mode[pin]=INPUT; pin_state[pin]=LOW; // Save pin mode and state}// Default pins set to 9 and 8 for REQN and RDYN// Set your REQN and RDYN here before ble_begin()if you need//ble_set_pins(3,2);// Set your BLE Shield name here,max.length 10//ble_set_name("My Name");// Init.and start BLE library.ble_begin();}//static byte buf_len=0;//void ble_write_string(byte *bytes,uint8_t len){if(buf_len+len>20){ for(int j=0;j<15000;j++)ble_do_events(); buf_len=0; }for(int j=0;j<len;j++){ ble_write(bytes[j]); buf_len++; }if(buf_len==20){ for(int j=0;j<15000;j++)ble_do_events(); buf_len=0; }}//byte reportDigitalInput(){if(!ble_connected())return 0;static byte pin=0; byte report=0;if(!IS_PIN_DIGITAL(pin)){ if(++pin>=TOTAL_PINS)pin=0; return 0; }if(pin_mode[pin]==INPUT){byte current_state=digitalRead(pin);if(pin_state[pin]!=current_state){pin_state[pin]=current_state; byte buf[]={'G',pin,INPUT,current_state}; ble_write_string(buf,4); report=1;}}if(++pin>=TOTAL_PINS)pin=0;return report;}//void reportPinCapability(byte pin){byte buf[]={'P',pin,0x00}; byte pin_cap=0;if(IS_PIN_DIGITAL(pin))pin_cap|=PIN_CAPABILITY_DIGITAL;if(IS_PIN_ANALOG(pin) )pin_cap|=PIN_CAPABILITY_ANALOG;if(IS_PIN_PWM(pin) )pin_cap|=PIN_CAPABILITY_PWM;if(IS_PIN_SERVO(pin) )pin_cap|=PIN_CAPABILITY_SERVO;buf[2]=pin_cap;ble_write_string(buf,3);}//void reportPinServoData(byte pin){// if(IS_PIN_SERVO(pin))servos[PIN_TO_SERVO(pin)].write(value);// pin_servo[pin]=value;byte value=pin_servo[pin]; byte mode=pin_mode[pin]; byte buf[]={'G',pin,mode,value}; ble_write_string(buf,4);}//byte reportPinAnalogData(){if(!ble_connected())return 0;static byte pin=0; byte report=0;if(!IS_PIN_DIGITAL(pin)){ if(++pin>=TOTAL_PINS)pin=0; return 0; }if(pin_mode[pin]==ANALOG){uint16_t value=analogRead(pin);byte value_lo=value; byte value_hi=value>>8; byte mode=pin_mode[pin];mode=(value_hi<<4)|mode;byte buf[]={'G',pin,mode,value_lo};ble_write_string(buf,4);}if(++pin>=TOTAL_PINS)pin=0;return report;}//void reportPinDigitalData(byte pin){byte state=digitalRead(pin); byte mode=pin_mode[pin]; byte buf[]={'G',pin,mode,state}; ble_write_string(buf,4);}//void reportPinPWMData(byte pin){byte value=pin_pwm[pin]; byte mode=pin_mode[pin]; byte buf[]={'G',pin,mode,value}; ble_write_string(buf,4);}//void sendCustomData(uint8_t *buf,uint8_t len){uint8_t data[20]="Z"; memcpy(&data[1],buf,len); ble_write_string(data,len+1);}//byte queryDone=false;//void loop(){while(ble_available()){byte cmd;cmd=ble_read();Serial.write(cmd);// Parse data hereswitch(cmd){case 'V': byte buf[]={'V',0x00,0x00,0x01};ble_write_string(buf,4); break; // query protocol versioncase 'C': byte buf[2]; buf[0]='C'; buf[1]=TOTAL_PINS; ble_write_string(buf,2); break; // query board total pin countcase 'M': byte pin=ble_read(); byte buf[]={'M',pin,pin_mode[pin]}; ble_write_string(buf,3); break; // query pin modecase 'S':{ // set pin modebyte pin=ble_read(); byte mode=ble_read();if(IS_PIN_SERVO(pin)&&mode!=SERVO&&servos[PIN_TO_SERVO(pin)].attached())servos[PIN_TO_SERVO(pin)].detach();/*ToDo: check the mode is in its capability or not*//*assume always ok*/if(mode!=pin_mode[pin]){pinMode(pin,mode); pin_mode[pin]=mode;if (mode==OUTPUT){ digitalWrite(pin,LOW ); pin_state[pin]=LOW; }else if(mode==INPUT ){ digitalWrite(pin,HIGH); pin_state[pin]=HIGH; }else if(mode==ANALOG){if(IS_PIN_ANALOG(pin)){if(IS_PIN_DIGITAL(pin))pinMode(PIN_TO_DIGITAL(pin),LOW);}}else if(mode==PWM){if(IS_PIN_PWM(pin)){pinMode(PIN_TO_PWM(pin),OUTPUT); analogWrite(PIN_TO_PWM(pin),0); pin_pwm[pin]=0; pin_mode[pin]=PWM;}}else if(mode==SERVO){if(IS_PIN_SERVO(pin)){pin_servo[pin]=0; pin_mode[pin]=SERVO;if(!servos[PIN_TO_SERVO(pin)].attached())servos[PIN_TO_SERVO(pin)].attach(PIN_TO_DIGITAL(pin));}}}//if(mode==ANALOG)reportPinAnalogData(pin);if ((mode==INPUT)||(mode==OUTPUT))reportPinDigitalData(pin);else if(mode==PWM)reportPinPWMData(pin);else if(mode==SERVO)reportPinServoData(pin);break;}case 'G': byte pin=ble_read(); reportPinDigitalData(pin); break; // query pin datacase 'T': byte pin=ble_read(); byte state=ble_read(); digitalWrite(pin,state); reportPinDigitalData(pin); break; // set pin digital statecase 'N':{ // set PWMbyte pin=ble_read(); byte value=ble_read();analogWrite(PIN_TO_PWM(pin),value);pin_pwm[pin]=value; reportPinPWMData(pin); break;}case 'O':{ // set Servobyte pin=ble_read(); byte value=ble_read();if(IS_PIN_SERVO(pin))servos[PIN_TO_SERVO(pin)].write(value);pin_servo[pin]=value; reportPinServoData(pin); break;}case 'A':{ // query all pin statusfor(int pin=0;pin<TOTAL_PINS;pin++){reportPinCapability(pin);if ((pin_mode[pin]==INPUT)||(pin_mode[pin]==OUTPUT))reportPinDigitalData(pin);else if(pin_mode[pin]==PWM)reportPinPWMData(pin);else if(pin_mode[pin]==SERVO)reportPinServoData(pin);}queryDone=true; uint8_t str[]="ABC"; sendCustomData(str,3);break;}case 'P':{ byte pin=ble_read(); reportPinCapability(pin); break; } // query pin capabilitycase 'Z':{byte len=ble_read(); byte buf[len];for(int i=0;i<len;i++)buf[i]=ble_read();Serial.println("->");Serial.print("Received: "); Serial.print(len); Serial.println(" byte(s)");Serial.print(" Hex: "); for(int i=0;i<len;i++)Serial.println(buf[i],HEX);}}// send out any outstanding datable_do_events(); buf_len=0; return; // only do this task in this loop}// process text dataif(Serial.available()){byte d='Z'; ble_write(d); delay(5);while(Serial.available()){ d=Serial.read(); ble_write(d); }ble_do_events(); buf_len=0; return;}// No input data,no commands,process analog dataif(!ble_connected())queryDone=false; // reset query stateif(queryDone){byte input_data_pending=reportDigitalInput();if(input_data_pending){ ble_do_events(); buf_len=0; return; }reportPinAnalogData();ble_do_events(); buf_len=0; return;}ble_do_events();buf_len=0;}
프로토콜을 먼저 구하고
무슨 기능을 사용하고 있는지 리스트를 만들고
보드 스펙을 놓고서
소스코드를 분석하셔야합니다.
자료가 부족해서 분석이 어려우므로 타인에게 설명을 해달라는 것은 불가능에 가깝습니다.
하나만 분석해드리죠
// process text dataif(Serial.available()){ // 시리얼 데이터가 있으면byte d='Z'; ble_write(d); delay(5); // 'Z' 컴맨드를 ble로 전송한 후while(Serial.available()){ d=Serial.read(); ble_write(d); } // 시리얼 수신데이터를 ble로 전송ble_do_events(); buf_len=0; return;}//case 'A':{ // query all pin statusfor(int pin=0;pin<TOTAL_PINS;pin++){reportPinCapability(pin);if((pin_mode[pin]==INPUT)||(pin_mode[pin]==OUTPUT))reportPinDigitalData(pin);else if(pin_mode[pin]==PWM)reportPinPWMData(pin);else if(pin_mode[pin]==SERVO)reportPinServoData(pin);}queryDone=true; uint8_t str[]="ABC"; sendCustomData(str,3);break;}queryDone은 'A' 컴맨드에서 true로 설정됩니다.아래 if()문은 'A' 컴맨드에 대한 응답으로 보시면 됩니다.if(queryDone){ // queryDone가 True면byte input_data_pending=reportDigitalInput(); // 디지털핀 mode 상태를 보고하고if(input_data_pending){ ble_do_events(); buf_len=0; return; }reportPinAnalogData(); // 아나로그 mode 상태도 보고함ble_do_events(); buf_len=0; return;}//시리얼 모니터 입력내용을 'Z' 컴맨드로 ble로 출력했으니ble의 'Z'컴맨드도 시리얼모니터로 출력하겠죠?case 'Z':{ // ble 'Z'컴맨드 수신byte len=ble_read(); byte buf[len]; // len(길이) 수신for(int i=0;i<len;i++)buf[i]=ble_read(); // len 갯수만큼 읽어서 버퍼에 저장Serial.println("->");Serial.print("Received: "); Serial.print(len); Serial.println(" byte(s)"); // len 출력Serial.print(" Hex: "); for(int i=0;i<len;i++)Serial.println(buf[i],HEX); // 16진ASC로 출력}ble에서 오는 데이터는 컴맨드 다음에 len가 붙는 점이 다릅니다.시리얼모니터의 데이터는 몇바이트를 입력하는지 알 수가 없으므로 len를 붙이고 있지 않습니다.
조회수 24,180등록된 댓글이 없습니다.
