질문게시판 > 아두이노 메가로 lcd글자 띄우는 법 질문
TODAY752 TOTAL2,584,924
BASIC4MCU | 질문게시판 | 아두이노 메가로 lcd글자 띄우는 법 질문
작성자 master 작성일2018-09-20 21:55 조회9,127회 댓글0건
안녕하세요 아두이노 초보자입니다. 코딩도 하나도 모릅니다
어쩌다가 아두이노 메가2560을 얻었고
240 x 320 lcd를 얻었는데요 (ITDB02-2.4E)
코딩을 할 줄 몰라서 lcd에 글자를 못 띄우고있습니다.
혹시 코딩좀 알려주실수있나요
2.4 TFT LCD Touch Shield V2
Overview
첨부 이미지
첨부 이미지
Arduino 2.4" TFT LCD Touch shield V2 is an Arduino UNO/ Mega compatible, multicolored TFT display with touch-screen and SD card socket as well. It is available in an Arduino shield compatible pinout for attachment. The TFT driver is based on ILI9341 with 8bit data and 4bit control interface.
The Arduino 2.4" TFT LCD Touch shield can work with both 3.3V and 5V. Therefore, it can dispaly on Chipkit UNO32 and Simplecortex as well.
NOTE: this screen adopts new driver IC, thus the old library is not applicable. New library will be updated soon, stay tuned!
Go shopping 2.4 TFT LCD Touch shield V2(IM160418001)
Features
  • Compatible with 3.3/5V operation voltage level
  • Compatible with new UTFT library
  • With SD Card Socket
Specifications
PCB size60.2mm X 50.8mm X 1.6mm
Indicators
Power supply5V
Communication Protocol
RoSHYes
Electrical Characteristics
ParameterMin.TypicalMax.Unit
Power voltage4.555.5VDC
Input voltage VH35.5V
Input voltage VL-0.300.5V
Hardware
첨부 이미지
Figure 1 Bottom View
Pin map of Arduino 2.4” TFT Touch Shield:
Arduino PINDescription
D0DB8
D1DB9
D2DB10
D3DB11
D4DB12
D5DB13
D6DB14
D7DB15
D8Touch_Dout
D9Touch_IRQ
D10SD_CS
D11SD_MOSI
D12SD_MISO
D13SD_SCK
A0Touch_Din
A1Touch_CLK
A2-
A3TFT_CS
A4TFT_WR
A5TFT_RS
The Arduino 2.4“E TFT Touch shield uses the ILI9341 controller,it support 8bit data interface. The touch IC is TSC2046.
Operation voltage level setting switch
When using the Arduino 2.4”E TFT Touch shield with 5V operation level development board – like the Arduino UNO, Arduino MEGA and so on, set the operation voltage level switch to 5V side.
When using the Arduino 2.4“E TFT Touch shield with 3.3V operation level development board – like the Iteaduino BT, leaf maple, chipKit UNO and so on, set the operation voltage level switch to 3.3V side.
Note
Note: This shiled is 100% compatible with ITeaduino, Simplecortex. But not 100% compatible with Arduino UNO because of its big USB connecter socket.
첨부 이미지
Download
Schematic for 2.4 TFT LCD Touch shield
Demo Code for 2.4 TFT LCD Touch shield
첨부 이미지
Arduino 2.4" TFT LCD Touch shield for Arduino UNO/ Mega
Arduino 2.4" TFT LCD Touch shield is an Arduino UNO/ Mega compatible multicolored TFT display with touch-screen and SD card socket. It is available in an Arduino shield compatible pinout for attachment. The TFT driver is based on S6D112 with 8bit data and 4bit control interface.
The Arduino 2.4" TFT LCD Touch shield can work with both 3.3V and 5V, so it can dispaly on Chipkit UNO32 and Simplecortex as well.
Features
  • Arduino UNO Rev3 / Mega Shield compatible footprint
  • Arduino library UTFT support
  • TFTResolution : 240 x 320 pixels
  • Size : 2.4"
  • Colors : 262K
  • Backlight : LED
  • Driver IC: S6D112
Specification
Version1.0
Compatible Mainboard
  • Arduino MEGA
  • Iteaduino
  • Iteaduino BT
  • Iteaduino ADK
  • Iteaduino MEGA 2560
  • Iteadmaple
  • Simple Cortex
  • ChipKit UNO32
  • ChipKit MAX32
  • FEZ Panda II
  • Freeduino
  • Leaf maple
  • Seeeduino
  • Seeduino MEGA
Shield Functions
  • Storage
  • Display
Board Size61mm x 51mm
Operation Level
  • Digital 3.3V
  • Digital 5V
StackableNo
ModelIM120417012
AccessoriesN/A
Weight45.00g
Documents
Datasheet (S6D1121)
Datasheet (IM120417012_2.4e TFT Touchshield)
Demo Code
Schematic
2.4 TFT LCD Touch Shield V1
Overview
첨부 이미지
첨부 이미지
Arduino 2.4" TFT LCD Touch shield V1 is an Arduino UNO/ Mega compatible, multicolored TFT display with touch-screen and SD card socket as well. It is available in an Arduino shield compatible pinout for attachment. The TFT driver is based on ILI9325D with 8bit data and 4bit control interface.
Go shopping 2.4 TFT LCD Touch shield V1 (IM120417012)
Features
  • Compatible with UTFT library
Specifications
Indicators
Power supply5V
RoSHYes
Hardware
첨부 이미지
D0DB8
D1DB9
D2DB10
D3DB11
D4DB12
D5DB13
D6DB14
D7DB15
D8Touch_Dout
D9Touch_IRQ
D10SD_CS
D11SD_MOSI
D12SD_MISO
D13SD_SCK
A0Touch_Din
A1Touch_CLK
A2-
A3TFT_CS
A4TFT_WR
A5TFT_RS
The Arduino 2.4“E TFT Touch shield uses the ILI9325D controller,it support 8bit data interface. The touch IC is TSC2046.
Software
This shield is compatible with UTFT library for Arduino, chipKit and their compatible boards. You can down load the library here: http://www.rinkydinkelectronics.com/library.php?id=51
Note
첨부 이미지
Download
Datasheet for S6D1121
Datasheet for 2.4 TFT LCD Touch shield
https://www.itead.cc/wiki/2.4_TFT_LCD_Touch_Shield_V1​
조회수 9,127
공지 사이트 이용 안내댓글[28] master 17-10-29 33559
질문 자율주행 로봇을 만드는데 질문있습니다.댓글[2] 뉴비에오 23-02-18 176
