BASIC4MCU | 질문게시판 | 아두이노 메가로 lcd글자 띄우는 법 질문
작성자 master 작성일2018-09-20 21:55 조회10,903회 댓글0건본문
안녕하세요 아두이노 초보자입니다. 코딩도 하나도 모릅니다
어쩌다가 아두이노 메가2560을 얻었고
240 x 320 lcd를 얻었는데요 (ITDB02-2.4E)
코딩을 할 줄 몰라서 lcd에 글자를 못 띄우고있습니다.
혹시 코딩좀 알려주실수있나요
2.4 TFT LCD Touch Shield V2
Overview
Arduino 2.4" TFT LCD Touch shield V2 is an Arduino UNO/ Mega compatible, multicolored TFT display with touch-screen and SD card socket as well. It is available in an Arduino shield compatible pinout for attachment. The TFT driver is based on ILI9341 with 8bit data and 4bit control interface.
The Arduino 2.4" TFT LCD Touch shield can work with both 3.3V and 5V. Therefore, it can dispaly on Chipkit UNO32 and Simplecortex as well.
NOTE: this screen adopts new driver IC, thus the old library is not applicable. New library will be updated soon, stay tuned!
Go shopping 2.4 TFT LCD Touch shield V2(IM160418001)
Features
- Compatible with 3.3/5V operation voltage level
- Compatible with new UTFT library
- With SD Card Socket
Specifications
PCB size 60.2mm X 50.8mm X 1.6mm Indicators Power supply 5V Communication Protocol RoSH Yes Electrical Characteristics
Parameter Min. Typical Max. Unit Power voltage 4.5 5 5.5 VDC Input voltage VH 3 5.5 V Input voltage VL -0.3 0 0.5 V Hardware
Figure 1 Bottom View
Pin map of Arduino 2.4” TFT Touch Shield:
Arduino PIN Description D0 DB8 D1 DB9 D2 DB10 D3 DB11 D4 DB12 D5 DB13 D6 DB14 D7 DB15 D8 Touch_Dout D9 Touch_IRQ D10 SD_CS D11 SD_MOSI D12 SD_MISO D13 SD_SCK A0 Touch_Din A1 Touch_CLK A2 - A3 TFT_CS A4 TFT_WR A5 TFT_RS The Arduino 2.4“E TFT Touch shield uses the ILI9341 controller,it support 8bit data interface. The touch IC is TSC2046.
Operation voltage level setting switch
When using the Arduino 2.4”E TFT Touch shield with 5V operation level development board – like the Arduino UNO, Arduino MEGA and so on, set the operation voltage level switch to 5V side.
When using the Arduino 2.4“E TFT Touch shield with 3.3V operation level development board – like the Iteaduino BT, leaf maple, chipKit UNO and so on, set the operation voltage level switch to 3.3V side.
Note
Note: This shiled is 100% compatible with ITeaduino, Simplecortex. But not 100% compatible with Arduino UNO because of its big USB connecter socket.
Download
Arduino 2.4" TFT LCD Touch shield for Arduino UNO/ Mega
Arduino 2.4" TFT LCD Touch shield is an Arduino UNO/ Mega compatible multicolored TFT display with touch-screen and SD card socket. It is available in an Arduino shield compatible pinout for attachment. The TFT driver is based on S6D112 with 8bit data and 4bit control interface.
The Arduino 2.4" TFT LCD Touch shield can work with both 3.3V and 5V, so it can dispaly on Chipkit UNO32 and Simplecortex as well.
Features
- Arduino UNO Rev3 / Mega Shield compatible footprint
- Arduino library UTFT support
- TFTResolution : 240 x 320 pixels
- Size : 2.4"
- Colors : 262K
- Backlight : LED
- Driver IC: S6D112
Specification
Version 1.0 Compatible Mainboard
- Arduino MEGA
- Iteaduino
- Iteaduino BT
- Iteaduino ADK
- Iteaduino MEGA 2560
- Iteadmaple
- Simple Cortex
- ChipKit UNO32
- ChipKit MAX32
- FEZ Panda II
- Freeduino
- Leaf maple
- Seeeduino
- Seeduino MEGA
Shield Functions
- Storage
- Display
Board Size 61mm x 51mm Operation Level
- Digital 3.3V
- Digital 5V
Stackable No Model IM120417012 Accessories N/A Weight 45.00g
Documents
2.4 TFT LCD Touch Shield V1
Overview
Arduino 2.4" TFT LCD Touch shield V1 is an Arduino UNO/ Mega compatible, multicolored TFT display with touch-screen and SD card socket as well. It is available in an Arduino shield compatible pinout for attachment. The TFT driver is based on ILI9325D with 8bit data and 4bit control interface.
Go shopping 2.4 TFT LCD Touch shield V1 (IM120417012)
Features
- Compatible with UTFT library
Specifications
Arduino PIN Description D0 DB8 D1 DB9 D2 DB10 D3 DB11 D4 DB12 D5 DB13 D6 DB14 D7 DB15 D8 Touch_Dout D9 Touch_IRQ D10 SD_CS D11 SD_MOSI D12 SD_MISO D13 SD_SCK A0 Touch_Din A1 Touch_CLK A2 - A3 TFT_CS A4 TFT_WR A5 TFT_RS The Arduino 2.4“E TFT Touch shield uses the ILI9325D controller,it support 8bit data interface. The touch IC is TSC2046.
Software
This shield is compatible with UTFT library for Arduino, chipKit and their compatible boards. You can down load the library here: http://www.rinkydinkelectronics.com/library.php?id=51
Note
Download
Datasheet for 2.4 TFT LCD Touch shield
https://www.itead.cc/wiki/2.4_TFT_LCD_Touch_Shield_V1
조회수 10,903등록된 댓글이 없습니다.
