질문게시판 > atmega128 4bit lcd 질문
TODAY200 TOTAL2,582,279
BASIC4MCU | 질문게시판 | atmega128 4bit lcd 질문
작성자 master 작성일2018-09-21 06:17 조회8,138회 댓글0건
  1. #include <mega128.h>
  2. // Alphanumeric LCD functions
  3. #asm
  4. .equ __lcd_port=0x12;
  5. #endasm
  6. #include <lcd.h>
  7. #include <delay.h>
  8. // Declare your global variables here
  9. unsigned int count = 0,num = 0, four , three , two , one;
  10. void main(void
  11.    DDRD = 0xff;
  12.    lcd_init(16);
  13.    do
  14.       EIMSK = 0b01110000;
  15.       EICRB = 0b00101010;
  16.       if(num >9999)
  17.       num <= 0;
  18.       four = (num/1000)%10;
  19.       three = (num/100)%10;
  20.       two = (num/10)%10;
  21.       one = num%10;
  22.       lcd_gotoxy(0,0);
  23.       lcd_putchar(four);
  24.       lcd_putchar(three);
  25.       lcd_putchar(two);
  26.       lcd_putchar(one);
  27.    }while(1);
  28.    SREG = 0x80;
  29. }
  30. interrupt [EXT_INT4] void external_int4(void
  31.    num++;
  32. interrupt [EXT_INT5] void external_int5(void
  33.    num--;
  34. interrupt [EXT_INT6] void external_int6(void
  35.    num = 0;
이런식으로 코드를 짯는데 4bit용 lcd에는 아무것도 안뜨네요
// DateTime : 2018-09-09 오후 5:15:35
#include <delay.h>
#asm
#endasm
#include <lcd.h>
int num=0;
unsigned int four,three,two,one;
interrupt[EXT_INT4]void external_int4(void){ if(++num>9999)num=0; }
interrupt[EXT_INT5]void external_int5(void){ if(--num<0)num=9999; }
interrupt[EXT_INT6]void external_int6(void){ num=0; }
void main(void){
  DDRD=0xff;
  lcd_init(16);
  EICRB=0xAAEIFR=0xFFEIMSK=0x70SREG=0x80;
    four=num/1000%10+'0';
    three=num/100%10+'0';
    two=num/10%10+'0';
    one=num%10+'0';
    lcd_gotoxy(0,0); lcd_putchar(); lcd_putchar(three); lcd_putchar(two); lcd_putchar(one);
    delay_ms(250);
Table of ASCII Characters
binary
MSN
0000
0001
0010
0011
0100
0101
0110
0111
LSN
hex
0
1
2
3
4
5
6
7
0000
0
NUL
00
DLE
16
10
SP
32
20
0
48
30
64
40
P
80
50
96
60
p
112
70
0001
1
SOH
01
XON
(DC1)
17
11
33
21
1
49
31
A
65
41
Q
81
51
a
97
61
q
113
71
0010
2
STX
02
DC2
18
12
34
22
2
50
32
B
66
42
R
82
52
b
98
62
r
114
72
0011
3
ETX
03
XOFF (DC2)
19
13
35
23
3
51
33
C
67
43
S
83
53
c
99
63
s
115
73
0100
4
EOT
04
DC4
20
14
36
24
4
52
34
D
68
44
T
84
54
d
100
64
t
116
74
0101
5
ENQ
05
NAK
21
15
37
25
5
53
35
E
69
45
U
85
55
e
101
65
u
117
75
0110
6
ACK
06
SYN
22
16
38
26
6
54
36
F
70
46
V
86
56
f
102
66
v
118
76
0111
7
BEL
07
ETB
23
17
39
27
7
55
37
G
71
47
W
87
57
g
103
67
w
119
77
1000
8
BS
08
CAN
24
18
40
28
8
56
38
H
72
48
X
88
58
h
104
68
x
120
78
1001
9
HT
09
EM
25
19
41
29
9
57
39
I
73
49
Y
89
59
i
105
69
y
121
79
1010
A
LF
10
0A
SUB
26
1A
42
2A
58
3A
J
74
4A
Z
90
5A
j
106
6A
z
122
7A
1011
B
VT
11
0B
ESC
27
1B
43
2B
59
3B
K
75
4B
91
5B
k
107
6B
123
7B
1100
C
FF
12
0C
FS
28
1C
44
2C
60
3C
L
76
4C
92
5C
l
108
6C
124
7C
1101
D
CR
13
0D
GS
29
1D
45
2D
61
3D
M
77
4D
93
5D
m
109
6D
125
7D
1110
E
SO
14
0E
RS
30
1E
46
2E
62
3E
N
78
4E
94
5E
n
110
6E
126
7E
1111
F
SI
15
0F
US
31
1F
47
2F
63
3F
O
79
4F
_
95
5F
o
111
6F
DEL
127
7F
LCD는 정수를 출력하면 안되고 문자를 사용해서 출력하세요
'0'=0x30
'1'=0x31
'2'=0x32
0
48
30
9
57
39
// DateTime : 2018-09-09 오후 5:18:48
#include <delay.h>
#include <stdio.h>
#asm
#endasm
#include <lcd.h>
int num=0;
unsigned int count=0,four,three,two,one;
char str[21];
void main(void){
  DDRD=0xff;
  lcd_init(16);
    sprintf(str,"%04d",num); lcd_gotoxy(0,0); lcd_puts(str);
    delay_ms(250);
 sprintf를 사용한 예제입니다.
조회수 8,138
질문 아두이노 제어하기댓글[3] 매드닥터 23-03-19 45
질문 아두이노 스텝모터 각도제어 질문댓글[3] master 23-03-17 59
질문 아두이노와 파이썬(중점좌표) 시리얼 통신 질문드립니다.댓글[1] 이미지첨부파일 아두이노어렵잖아 23-03-16 42
질문 아두이노 3LED 버튼 관련 질문댓글[1] 이츤 23-03-16 43
질문 아두이노 나노33 IOT 의 BLE 연결 문제 이미지 가루밀 23-02-24 73
질문 HM-10 모듈 사용하는데 질문있습니다.댓글[2] 뉴비에오 23-02-21 129
