질문게시판 > 아두이노 NFC카드 질문
TODAY764 TOTAL2,584,936
BASIC4MCU | 질문게시판 | 아두이노 NFC카드 질문
작성자 master 작성일2018-09-23 18:19 조회8,349회 댓글0건
아두이노 프로그램이 두가지가있습니다.
1번째
#include <Wire.h>
#include <Keypad.h>
#include <Servo.h>
Servo locker;
LiquidCrystal_I2C lcd(0x27,16,2);  // set the LCD address to 0x27 for a 16 chars and 2 line display
char secretCode[4] = {'1', '2', '5', '4'};
char door;
char input[4];
char key;
char light;
int wrong = 0;
int i = 0;
int j = 0;
int a=0;
const byte rows = 4;
const byte cols = 4;
boolean c=false;
char keys[rows][cols] =
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
byte rowPins[rows] = {8, 7, 6, 5};
byte colPins[cols] = {4, 3, 2, 1};
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, rows, cols);
  lcd.begin(16, 2);
  locker.attach(A3);
  locker.write(90);
  lcd.init();                      // initialize the lcd
  while(a==0)
    light=keypad.waitForKey();
    if(light == '*')
    // Print a message to the LCD.
    lcd.backlight();
    input_key();            // Password Input Mode
    password();             // Confirm Password
    password_check();       // Display current state
  while(a==1)
    lcd.print("if you wanna clo");
    lcd.setCursor(0,1);
    lcd.print("se,press '*'key");
    door = keypad.waitForKey();
    if(door == '*')
    { locker.write(90);
      lcd.clear();
      lcd.noBacklight();
     a=0;
void input_key()
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print("    Password");
  for (i = 0; i < 4; i++)
    key = keypad.waitForKey();
    input[i] = key;
    lcd.setCursor(i + 6, 1);
    lcd.print("*");
void password()
  wrong = 0;
  for (j = 0; j < 4; j++)
    if (secretCode[j] == input[j])
    else if (secretCode[j] != input[j])
      wrong += 1;
void password_check()
  if (wrong == 0)
    lcd.clear();
    lcd.print("      PASS");
    delay(2000);
    lcd.clear();
    locker.write(180);      // OPENING
    a=1;
  else if (wrong != 0)
    lcd.clear();
    lcd.print("     wrong");
    delay(2000);
    a=0;
    lcd.clear();
    wrong = 0;
두번째로
#include <Servo.h>  // 서보 라이브러리
#include <SPI.h>    // RFID를 위한 SPI 라이브러
#include <MFRC522.h>// RFID 라이브러
#define SERVO_PIN 6 //서보 PIN
Servo myservo;      //서보 라이브러리
#define SS_PIN 10   //RFID SS(SDA:ChipSelect) PIN
#define RST_PIN 9   //RFID Reset PIN
MFRC522 rfid(SS_PIN, RST_PIN); //RFID 라이브러리
/* 등록된 RF CARD ID */
#define PICC_0 0xE9
#define PICC_1 0x5D
#define PICC_2 0x3D
#define PICC_3 0x2B
  //시리얼 모니터 시작
  SPI.begin(); // SPI 시작
  rfid.PCD_Init(); // RF 모듈 시작
  myservo.attach(SERVO_PIN); //서보 시작
  myservo.write(0); //초기 서보 모터를 0도로 위치 시킴
  //카드가 인식 안되었다면 더이상 진행하지 말고 빠져나감
  if ( ! rfid.PICC_IsNewCardPresent())
    return;
  //RF카드의 ID가 인식 안되었다면 더이상 진행하지 말고 빠져나감
  if ( ! rfid.PICC_ReadCardSerial())
    return;
  Serial.print(F("PICC type: "));
  //PICC 타입 읽어오기
  MFRC522::PICC_Type piccType = rfid.PICC_GetType(rfid.uid.sak);
  Serial.println(rfid.PICC_GetTypeName(piccType));
  //MIFARE 방식이 아니라면 더이상 진행하지 말고 빠져나감
  if (piccType != MFRC522::PICC_TYPE_MIFARE_MINI &&
    piccType != MFRC522::PICC_TYPE_MIFARE_1K &&
    piccType != MFRC522::PICC_TYPE_MIFARE_4K) {
    Serial.println(F("Your tag is not of type MIFARE Classic."));
    return;
  //ID가 등록된 ID와 동일하다면
  if (rfid.uid.uidByte[0] != PICC_0 ||
      rfid.uid.uidByte[1] != PICC_1 ||
      rfid.uid.uidByte[2] != PICC_2 ||
      rfid.uid.uidByte[3] != PICC_3 ) {
    //등록된 카드가 아니라면 시리얼 모니터로 ID 표시
    Serial.println(F("This is an unconfirmed Card."));
    Serial.print(F("In hex: "));
    printHex(rfid.uid.uidByte, rfid.uid.size);
  }else{
    Serial.println(F("This is a confirmed Card."));
    Serial.println(F("Motor On!!"));
    //서보 90도로 이동
    myservo.write(90);
    //1초 대기
    //서보 0도로 되돌림
    myservo.write(0);
  //종료
  rfid.PICC_HaltA();
  rfid.PCD_StopCrypto1();
  //다시 시작!
//16진수 표시
void printHex(byte *buffer, byte bufferSize) {
  for (byte i = 0; i < bufferSize; i++) {
    Serial.print(buffer[i] < 0x10 ? " 0" : " ");
    Serial.print(buffer[i], HEX);
위에 이 2가지의 프로그램을 합쳐서 NFC카드를 대도 문이열리고 비밀번호를 쳐서도 문을열리게 해야합니다. 각각의 동작은 되지만 합치는것을 OR IF문을 써서 하라는데 잘모르겠습니다.
// DateTime : 2018-09-14 오후 8:45:23
#include <Wire.h>
#include <Keypad.h>
#include <Servo.h>
#include <SPI.h>
Servo locker;
char secretCode[4]={'1','2','5','4'};
char input[4];
char key,door,light;
int wrong=0,i=0,j=0,a=0;
const byte rows=4,cols=4;
boolean c=false;
char keys[rows][cols]={
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[rows]={8,7,6,5};
byte colPins[cols]={4,3,2,1};
Keypad keypad=Keypad(makeKeymap(keys),rowPins,colPins,rows,cols);
#define SS_PIN    10          //RFID SS(SDA: ChipSelect)PIN
MFRC522 rfid(SS_PIN,RST_PIN); //RFID 라이브러리
/*등록된 RF CARD ID*/
#define PICC_0   0xE9
#define PICC_1   0x5D
#define PICC_2   0x3D
#define PICC_3   0x2B
  locker.attach(A3); locker.write(0);
  lcd.begin(16,2); lcd.init();
  SPI.begin();
  rfid.PCD_Init();
  while(a==0){
    if(light=='*'){ lcd.backlight(); }
    input_key();
    password();
    password_check();
  while(a==1){
    lcd.setCursor(0,1); lcd.print("se,press '*'key");
    door=keypad.waitForKey();
    if(door=='*'){ locker.write(90); lcd.clear(); lcd.noBacklight(); a=0; }
  if(!rfid.PICC_IsNewCardPresent())return//카드가 인식 안되었다면
  if(!rfid.PICC_ReadCardSerial())return;
  Serial.print(F("PICC type: ")); //PICC 타입 읽어오기
  MFRC522::PICC_Type piccType=rfid.PICC_GetType(rfid.uid.sak);
  if(piccType!=MFRC522::PICC_TYPE_MIFARE_MINI&&
     piccType!=MFRC522::PICC_TYPE_MIFARE_1K&&
     piccType!=MFRC522::PICC_TYPE_MIFARE_4K){
    return;
  if(rfid.uid.uidByte[0]!=PICC_0||rfid.uid.uidByte[1]!=PICC_1||
     rfid.uid.uidByte[2]!=PICC_2||rfid.uid.uidByte[3]!=PICC_3){ // 등록된 ID 아니면
    Serial.println(F("This is an unconfirmed Card.")); Serial.print(F("In hex: "));
    printHex(rfid.uid.uidByte,rfid.uid.size);
  else// 등록된 ID
    Serial.println(F("This is a confirmed Card.")); Serial.println(F("Motor On!!"));
    locker.write(90); delay(1000); locker.write(0);
  rfid.PICC_HaltA(); rfid.PCD_StopCrypto1();
//16진수 표시
void printHex(byte*buffer,byte bufferSize){
  for(byte i=0i<bufferSizei++){
    Serial.print(buffer[i]<0x10?" 0"" ");
    Serial.print(buffer[i],HEX);
void input_key(){
  lcd.clear(); lcd.setCursor(0,0); lcd.print("    Password");
  for(i=0;i<4;i++){
    key=keypad.waitForKey();
    input[i]=key;
    lcd.setCursor(i+6,1); lcd.print("*");
void password(){
  wrong=0;
  for(j=0;j<4;j++){
    if(secretCode[j]==input[j]){}
    else if(secretCode[j]!=input[j]){ wrong+=1; }
void password_check(){
  if(wrong==0){
    lcd.clear(); lcd.setCursor(0,0); lcd.print("      PASS"); delay(2000);
    lcd.clear(); lcd.setCursor(0,0); locker.write(180); // OPENING
    a=1;
  else if(wrong!=0){
    lcd.clear(); lcd.setCursor(0,0); lcd.print("     wrong"); delay(2000); lcd.clear();
    a=0wrong=0;
합치는 것은 어렵지 않지만 매끄럽게 돌아가도록 디버깅은 직접 하셔야합니다.
조회수 8,349
공지 사이트 이용 안내댓글[28] master 17-10-29 33559
질문 자율주행 로봇을 만드는데 질문있습니다.댓글[2] 뉴비에오 23-02-18 176
