질문게시판 > 아두이노 오류 확인좀 해주세요
TODAY2,003 TOTAL817,461
BASIC4MCU | 질문게시판 | 아두이노 오류 확인좀 해주세요
작성자 S대학생 작성일2018-10-01 15:32 조회1,134회 댓글1건
// DateTime : 2018-10-01 오후 3:30:08
#include <IRremote.h>
int pinLB = 2; // L298N IN1
int pinLF = 3; // L298N IN2
int pinRB = 4; // L298N IN3
int pinRF = 5; // L298N IN4
int Lled = 8;
int Rled = 9;
long advence = 0x00FF18E7;
long back   = 0x00FF4AB5;
long stop   = 0x00FF38C7;
long left   = 0x00FF10EF;
long right  = 0x00FF5AA5;
long leftled = 0x00FF30CF;
long rightled = 0x00FF7A85;
int RECV_PIN = A0;
IRrecv irrecv(RECV_PIN);
decode_results results;
unsigned long last = millis();
unsigned long Llast, Rlast;
int mode = 0;
void M_stop() {
  digitalWrite(pinRB, 1);
  digitalWrite(pinRF, 1);
  digitalWrite(pinLB, 1);
  digitalWrite(pinLF, 1);
void M_fwd()  {
  digitalWrite(pinRB, 0);
  digitalWrite(pinLB, 0);
void M_back() {
  digitalWrite(pinRF, 0);
  digitalWrite(pinLF, 0);
void M_left() {
void M_right() {
void dump(decode_results*results) {
  int count = results->rawlen;
  if (results->decode_type == UNKNOWN) {
    Serial.println("Could not decode message");
  else {
    if     (results->decode_type == NEC ) {
      Serial.print("Decoded NEC: ");
    else if (results->decode_type == SONY) {
      Serial.print("Decoded SONY: ");
    else if (results->decode_type == RC5 ) {
      Serial.print("Decoded RC5: ");
    else if (results->decode_type == RC6 ) {
      Serial.print("Decoded RC6: ");
    Serial.print(results->value, HEX); Serial.print("(");
    Serial.print(results->bits , DEC); Serial.println(" bits)");
  Serial.print("Raw("); Serial.print(count, DEC); Serial.print("): ");
  for (int i = 0; i < count; i++) {
    if (i % 2) {
      Serial.print(      results->rawbuf[i]*USECPERTICK, DEC);
    else   {
      Serial.print(-(int)results->rawbuf[i]*USECPERTICK, DEC);
    Serial.print(" ");
  Serial.println("");
  pinMode(pinLB, OUTPUT); pinMode(pinLF, OUTPUT); pinMode(pinRB, OUTPUT); pinMode(pinRF, OUTPUT);
  pinMode(13, OUTPUT);    pinMode(Lled, OUTPUT);  pinMode(Rled, OUTPUT);
  pinMode(RECV_PIN, INPUT);
  irrecv.enableIRIn();
  if (irrecv.decode(&results)) {
    if (millis() - last > 250) {
      last = millis();
      digitalWrite(13, !digitalRead(13); dump(&results));
    if (results.value == advence) {
      mode = 0;
      M_fwd();
      Serial.print("advance");
    if (results.value == back   ) {
      mode = 0;
      M_back();
    if (results.value == stop   ) {
      mode = 0;
      M_stop();
    if (results.value == left   ) {
      mode = 'L';
      M_left();
      digitalWrite(Lled, 1);
      Llast = millis();
    if (results.value == right  ) {
      mode = 'R';
      M_right();
      digitalWrite(Rled, 1);
      Rlast = millis();
    irrecv.resume();
  if (mode == 'L') {
    if (millis() - Llast > 250) {
      Llast = millis();
      digitalWrite(Lled, !digitalRead(Lled));
  if (mode == 'R') {
    if (millis() - Rlast > 250) {
      Rlast = millis();
      digitalWrite(Rled, !digitalRead(Rled));
오류내용:
C:\Users\SAU\Downloads\IRremote2WDRC\IRremote2WDRC.ino: In function 'void loop()':
IRremote2WDRC:107: error: invalid use of void expression
       digitalWrite(13, !digitalRead(13), dump(&results));
exit status 1
조회수 1,134
digitalWrite(13, !digitalRead(13)); dump(&results);
괄호에 문제가 있습니다.
아래에서도 동일한 문제가 2군데 더 있습니다.
답글로 소스를 다시 올려드리죠
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 1008
공지 사이트 이용 안내댓글[10] master 17-10-29 8995
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 3409
질문 아두이노 MPU6050과 LED를 이용한 밝기조절 이미지새글첨부파일 초보아두 03:26 3
질문 서보모터 질문 새글 알씨알씨 19-12-15 7
질문 서보모터 속도댓글[1] 새글 알씨알씨 19-12-15 9
질문 초기화 어떻게 하나요?댓글[1] 새글 끵끵끵 19-12-15 13
질문 미세먼지센서 GP2Y1023AU0F 코드 질문드립니다! 새글첨부파일 덕덕덕 19-12-15 11
질문 질문 하나만 더하겠습니다!! 새글 Leos 19-12-15 15
답변 답변글 답변 : 질문 하나만 더하겠습니다!! 새글 master 19-12-15 7
질문 아두이노 자동차 소스 작성중 어려움이 있어 질문 드립니다.댓글[1] 새글 쿤싼 19-12-15 13
질문 atmega 128에서 인터럽트가 적용이 되질 않습니다. 새글 메가콜라 19-12-14 10
답변 답변글 답변 : atmega 128에서 인터럽트가 적용이 되질 않습니다.댓글[1] 새글 master 19-12-14 16
질문 온도센서 질문입니다.댓글[1] 새글 오기 19-12-14 16
질문 ATMEGA128 노래 속도 새글 Leos 19-12-14 18
답변 답변글 답변 : ATMEGA128 노래 속도 새글 master 19-12-14 15
질문 초기화 어떻게 하나요?댓글[2] 새글 끵끵끵 19-12-14 17
답변 답변글 답변 : 초기화 어떻게 하나요? 새글 master 19-12-14 5
질문 서보모터 이용 자율주행 관련 질문 klohs 19-12-13 13
답변 답변글 답변 : 서보모터 이용 자율주행 관련 질문 master 19-12-13 12
질문 atmega128 / bldc모터 구동 질문입니다.댓글[1] 이미지첨부파일 조셉 19-12-13 19
질문 블루투스(HM-10) 비콘 관련 질문댓글[2] 으앙 19-12-12 17
질문 모터가 이상합니다.댓글[3] 첨부파일 이즈미 19-12-12 23
질문 아두이노 코딩 질문이요 나비힛 19-12-12 25
답변 답변글 답변 : 아두이노 코딩 질문이요 master 19-12-12 20
질문 앱인벤터에 값을 표기하는데 앞에 ( 가 붙는데 떼고 싶습니다. 이미지첨부파일 어려운AVR 19-12-11 12
답변 답변글 답변 : 앱인벤터에 값을 표기하는데 앞에 ( 가 붙는데 떼고 싶습니다.댓글[3] master 19-12-11 16
질문 아두이노 스텝모터 멈추기댓글[1] 이즈미 19-12-11 23
질문 avr atmega128 숫자야구게임댓글[1] 첨부파일 주냥몬 19-12-11 37
MCU BASIC ⓒ 2019
