질문게시판 > 답변 : 아두이노 리모콘 RC CAR
TODAY831 TOTAL605,460
BASIC4MCU | 질문게시판 | 답변 : 아두이노 리모콘 RC CAR
작성자 master 작성일2018-10-01 15:53 조회767회 댓글0건
// DateTime : 2018-10-01 오후 3:57:43
#include <IRremote.h>
int pinLB=2// L298N IN1
int pinLF=3// L298N IN2
int pinRB=4// L298N IN3
int pinRF=5// L298N IN4
int Lled=8;
int Rled=9;
long advence =0x00FF18E7;
long back    =0x00FF4AB5;
long stop    =0x00FF38C7;
long left    =0x00FF10EF;
long right   =0x00FF5AA5;
long leftled =0x00FF30CF;
long rightled=0x00FF7A85;
int RECV_PIN=A0;
IRrecv irrecv(RECV_PIN);
decode_results results;
unsigned long last=millis();
unsigned long Llast,Rlast;
int mode=0;
void M_stop() { digitalWrite(pinRB,1); digitalWrite(pinRF,1); digitalWrite(pinLB,1); digitalWrite(pinLF,1); }
void M_fwd()  { digitalWrite(pinRB,0); digitalWrite(pinRF,1); digitalWrite(pinLB,0); digitalWrite(pinLF,1); }
void M_back() { digitalWrite(pinRB,1); digitalWrite(pinRF,0); digitalWrite(pinLB,1); digitalWrite(pinLF,0); }
void M_left() { digitalWrite(pinRB,0); digitalWrite(pinRF,1); digitalWrite(pinLB,1); digitalWrite(pinLF,1); }
void M_right(){ digitalWrite(pinRB,1); digitalWrite(pinRF,1); digitalWrite(pinLB,0); digitalWrite(pinLF,1); }
void dump(decode_results *results){
  int count=results->rawlen;
  if(results->decode_type==UNKNOWN){ Serial.println("Could not decode message"); }
    if     (results->decode_type==NEC ){ Serial.print("Decoded NEC: "); }
    else if(results->decode_type==SONY){ Serial.print("Decoded SONY: "); }
    else if(results->decode_type==RC5 ){ Serial.print("Decoded RC5: "); }
    else if(results->decode_type==RC6 ){ Serial.print("Decoded RC6: "); }
    Serial.print(results->value,HEX); Serial.print("(");
    Serial.print(results->bits ,DEC); Serial.println(" bits)");
  Serial.print("Raw("); Serial.print(count,DEC); Serial.print("): ");
  for(int i=0i<counti++){
    if(i%2){ Serial.print(      results->rawbuf[i]*USECPERTICK,DEC); }
    else   { Serial.print(-(int)results->rawbuf[i]*USECPERTICK,DEC); }
    Serial.print(" ");
  Serial.println("");
  pinMode(pinLB,OUTPUT); pinMode(pinLF,OUTPUT); pinMode(pinRB,OUTPUT); pinMode(pinRF,OUTPUT);
  pinMode(13,OUTPUT);    pinMode(Lled,OUTPUT);  pinMode(Rled,OUTPUT);
  pinMode(RECV_PIN,INPUT);
  irrecv.enableIRIn();
  if(irrecv.decode(&results)){
    if(millis()-last>250){ last=millis(); digitalWrite(13,!digitalRead(13)); dump(&results); }
    if(results.value==advence){ mode=0;   M_fwd();  Serial.print("advance"); }
    if(results.value==back   ){ mode=0;   M_back();  }
    if(results.value==stop   ){ mode=0;   M_stop();  }
    if(results.value==left   ){ mode='L'M_left();  digitalWrite(Lled,1); Llast=millis(); }
    if(results.value==right  ){ mode='R'M_right(); digitalWrite(Rled,1); Rlast=millis(); }
    irrecv.resume();
  if(mode=='L'){
    if(millis()-Llast>250){ Llast=millis(); digitalWrite(Lled,!digitalRead(Lled)); }
  if(mode=='R'){
    if(millis()-Rlast>250){ Rlast=millis(); digitalWrite(Rled,!digitalRead(Rled)); }
깜박이를 별도로 구동하고 싶으면 아래 소스로 구동하세요
// DateTime : 2018-10-01 오후 4:01:55
int Lled=8;
int Rled=9;
long rightled =0x00FF7A85;
int RECV_PIN=A0;
int mode=0;
void dump(decode_results*results){
    Serial.print(" ");
  Serial.println("");
    if(results.value==advence ){ mode=0;   M_fwd();  Serial.print("advance"); }
    if(results.value==left    ){ mode=0;   M_left();  }
    if(results.value==right   ){ mode=0;   M_right(); }
    if(results.value==leftled ){ mode='L'digitalWrite(Lled,1); Llast=millis(); }
    if(results.value==rightled){ mode='R'digitalWrite(Rled,1); Rlast=millis(); }
    irrecv.resume();
  if(mode=='L'){
  if(mode=='R'){
조회수 767
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 595
공지 사이트 이용 안내댓글[8] master 17-10-29 7621
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 2843
질문 atmega128a 카운터/타이머 출력비교 질문이요댓글[1] 새글 초짜 19-08-17 10
질문 모터드라이버 병렬 연결댓글[3] 새글 박준2 19-08-16 17
질문 서로 다른전원(5v 12v) 제어방법 질문 master 19-08-16 10
질문 모터드라이버 관련 질문 드립니다.댓글[4] 박준이 19-08-15 20
질문 Atmega128, 초음파센서 ,부저 gksl 19-08-14 16
답변 답변글 답변 : Atmega128, 초음파센서 ,부저댓글[1] master 19-08-15 18
질문 led 전력소모에 관하여,,,댓글[9] 슬레a 19-08-14 43
질문 알고리즘 문의댓글[1] 벅바 19-08-13 19
질문 블루투스가 한번 작동하고 그 다음부터 작동을 하지 않습니다.댓글[1] 아야어여 19-08-13 21
질문 아두이노 코딩 질문입니다 너무 급해요 ㅠㅠ댓글[3] 전민결 19-08-12 45
질문 코딩 작성좀 부탁드립니다. 너무 급합니다 ㅠㅠ댓글[1] 아두이노보초 19-08-10 63
질문 stm32f1 계열에서 USB로 스마트폰 연결 방법(CDC)댓글[2] 에르테르 19-08-08 38
질문 코딩을 합치고 싶습니다.. 알려주세요 19-08-08 40
답변 답변글 답변 : 코딩을 합치고 싶습니다.. master 19-08-08 40
질문 금속센서를 이용한 서보모터 돌리기댓글[1] 후우 19-08-07 49
질문 아두이노로 빛 파장 계산하기 이미지 master 19-08-07 36
질문 ISP 질문이요댓글[2] 초짜 19-08-06 32
질문 atmega128a 다시 질문이요~댓글[4] 이미지첨부파일 초짜 19-08-05 53
질문 atmega128a SCK 질문이요댓글[1] 초짜 19-08-04 39
답변 답변글 답변 : atmega128a SCK 질문이요 master 19-08-04 30
질문 A4988 모터드라이버 발열에 대해...댓글[1] 이미지첨부파일 눈티이 19-07-30 64
질문 아두이노 코딩 질문댓글[1] 119min 19-07-27 75
질문 아두이노 코딩질문 붕붕 19-07-26 63
답변 답변글 답변 : 아두이노 코딩질문댓글[6] master 19-07-26 148
질문 적외선 센서 송수신 코딩 알려주세요댓글[3] 이미지첨부파일 뱀비 19-07-22 110
질문 BLDC 모터 정역회전 알고리즘대로 코딩 이미지첨부파일 CIE18 19-07-21 73
답변 답변글 답변 : BLDC 모터 정역회전 알고리즘대로 코딩 master 19-07-21 69
