질문게시판 > switch case문으로 변경하고 싶습니다 도와주세요....
TODAY7,116 TOTAL7,737,235
BASIC4MCU | 질문게시판 | switch case문으로 변경하고 싶습니다 도와주세요....
작성자 ktg8213 작성일2018-10-04 11:48 조회11,199회 댓글0건
switch case문으로 변경하고 리모컨 1,3번버튼을  다시 누르면 점멸등이 꺼질수있게 도와주세요...
#include <IRremote.h>
int RECV_PIN = A0;
int pinLB=2;// L298N IN1
int pinLF=3;// L298N IN2
int pinRB=4;// L298N IN3
int pinRF=5;// L298N IN4
int Lled=8;
int Rled=9;
//적선 제부
long advence = 0x00FF18E7;
long back = 0x00FF4AB5;
long stop = 0x00FF38C7;
long left = 0x00FF10EF;
long right = 0x00FF5AA5;
long leftled = 0x00FF30CF;
long Rled = 0x00FF7A85;
IRrecv irrecv(RECV_PIN);
decode_results results;
void dump(decode_results *results) {
  int count = results->rawlen;
  if (results->decode_type == UNKNOWN)
     Serial.println("Could not decode message");
    if (results->decode_type == NEC)
       Serial.print("Decoded NEC: ");
    else if (results->decode_type == SONY)
       Serial.print("Decoded SONY: ");
    else if (results->decode_type == RC5)
       Serial.print("Decoded RC5: ");
    else if (results->decode_type == RC6)
       Serial.print("Decoded RC6: ");
     Serial.print(results->value, HEX);
     Serial.print(" (");
     Serial.print(results->bits, DEC);
     Serial.println(" bits)");
     Serial.print("Raw (");
     Serial.print(count, DEC);
     Serial.print("): ");
  for (int i = 0; i <count; i++)
      if ((i % 2) == 1) {
      Serial.print(results->rawbuf[i]*USECPERTICK, DEC);
      Serial.print(-(int)results->rawbuf[i]*USECPERTICK, DEC);
    Serial.print(" ");
      Serial.println("");
void setup()
  pinMode(RECV_PIN, INPUT);
  pinMode(pinLB,OUTPUT);
  pinMode(pinLF,OUTPUT);
  pinMode(pinRB,OUTPUT);
  pinMode(pinRF,OUTPUT);
  irrecv.enableIRIn(); // 수기 작
int on = 0;
unsigned long last = millis();
void loop()
  if (irrecv.decode(&results))
    // If it's been at least 1/4 second since the last
    // IR received, toggle the relay
    if (millis() - last >250)
       on = !on;
//       digitalWrite(8, on ? HIGH : LOW);
       digitalWrite(13, on ? HIGH : LOW);
       dump(&results);
    if (results.value == advence )
       digitalWrite(pinRB,LOW);//DC right
       digitalWrite(pinRF,HIGH);
       digitalWrite(pinLB,LOW);//DC left
       digitalWrite(pinLF,HIGH);
       Serial.print("advance");
    if (results.value == back )
     {digitalWrite(pinRB,HIGH);//
     digitalWrite(pinRF,LOW);
      digitalWrite(pinLB,HIGH);//
    digitalWrite(pinLF,LOW);}
    if (results.value == left )
    { digitalWrite(pinRB,LOW);//
     digitalWrite(pinLF,HIGH);}
    if (results.value == right )
    { digitalWrite(pinRB,HIGH);//
    if (results.value == stop )
    last = millis();
    irrecv.resume(); // Receive the next value
조회수 11,199
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 24369
공지 사이트 이용 안내댓글[31] master 17-10-29 39054
질문 DLM-64DCAA 고장나서 수리하고 싶습니다댓글[2] 이미지첨부파일 공부하고싶은콩 25-03-11 47
질문 로봇 얼굴 제작에 대하여 질문드립니다.댓글[4] 카모킹스 25-03-03 272
질문 모터와 모터드라이브 질문있습니다댓글[1] ponyo 25-02-19 140
질문 공통음극형 FND를 9V로 동작하게 하고 싶어요.댓글[7] 멘토 25-01-21 1572
질문 oled 모듈 연결 질문입니다!댓글[1] 펌린이 24-12-17 299
질문 Atmega 128 타이머 질문있습니다댓글[1] ednda 24-12-11 319
답변 답변글 답변 : Atmega 128 타이머 질문있습니다 master 24-12-11 234
질문 ATmega128 2개로 hc-05,hc-06블루트수 통신 동콩이 24-12-04 294
답변 답변글 답변 : ATmega128 2개로 hc-05,hc-06블루트수 통신댓글[4] master 24-12-04 2272
질문 lm75a 온도센서 관련 질문입니다.댓글[6] 이미지첨부파일 hanmw0707 24-12-01 5186
질문 리얼타임클락 질문이요 ㅠㅠ댓글[1] 이미지 팬케이크 24-11-22 394
질문 가속도센서 2개를 강아지 2마리에 각각 달아서 스마트폰으로 움직임을 보고 싶은데요댓글[1] gainomax 24-11-21 564
질문 라즈베리파이 4B 사용 중 막히는 부분 질문합니다댓글[1] 한마바키 24-11-12 6687
질문 스위치로 PI 모터 제어 바밤 24-11-11 288
답변 답변글 답변 : 스위치로 PI 모터 제어 master 24-11-12 283
질문 아트메가128 마이크로프로세서댓글[3] 옹심이 24-11-05 1104
질문 초음파 센서로 장애물 인식댓글[1] 나난ㄴ 24-10-31 445
질문 이런 투명 LCD는 뭐라고 부르나요?댓글[2] 이미지 펌린이 24-10-29 656
질문 모터제어 중 RPM 계산 질문입니다.댓글[3] suuuuuuuh 24-10-24 955
질문 아트메가 128과 블루투스 모듈(HC-06) 연결 질문댓글[1] 메가아트 24-10-24 449
질문 ATmega128 질문 DFplayer mini댓글[1] Miin 24-10-18 7038
질문 스탭모터 3개 회로도 질문.. 삉삉이 24-10-11 428
답변 답변글 답변 : 스탭모터 3개 회로도 질문.. 이미지 master 24-10-12 442
질문 수분수위센서와 멀티플렉서댓글[3] 김고래쓰 24-10-10 1197
질문 ATmegq128 PI 제어기 추가댓글[1] 바밤 24-10-08 459
답변 답변글 답변 : ATmegq128 PI 제어기 추가댓글[1] master 24-10-08 616
질문 아두이노 ide 네오픽셀 각 셀 각자 코드 현수 24-09-29 298
질문 아두이노 IDE 프로마이크로 네오픽셀 현수 24-09-29 340
