질문게시판 > 답변 : 답변 : avreeprom 질문입니다
TODAY823 TOTAL506,470
BASIC4MCU | 질문게시판 | 답변 : 답변 : avreeprom 질문입니다
작성자 master 작성일2018-10-17 15:16 조회25,804회 댓글15건
// DateTime : 2018-10-17 오후 3:20:54
// 수정 사항  2016.12.31 TIMER INTERR 0  Routine
// 080709: 입력 접점이 붙었을때부터 10초 딜레이
#include <mega8.h>
#include <delay.h>
//#define LED_AC           PORTC.0 // 교류입력에 대한 출력 포트
#define LED_M1_ERROR     PORTC.1
#define LED_EQUALITY     PORTC.2
#define LED_NO_EQUALITY  PORTC.3
#define OUT_M1_PLAY      PORTC.4
#define OUT_R1_PLAY      PORTC.5
#define IN_M2_PLAY       PINB.1
#define IN_M2_FAIL       PINB.0
#define IN_AC            PIND.7 // 교류입력연결 확인 변수
#define IN_EQUALITY      PIND.6
#define IN_AUTO          PIND.5
#define IN_PLAY          PINB.7
#define IN_M1_FAIL       PINB.6
#define ON               0 //변수 값 지정
#define OFF              1
#define RUN              1
#define STOP             0
#define FAIL             0
#define normal           1
eeprom   char EE_r,EE_m;
         char r,m;
unsigned char r1_play_Cnt=0;
// 타이머 1 CTC 비교매치 인터럽트 함수
interrupt [TIM1_COMPAvoid timer1_compa_isr(void){ // 100ms
  flag=1;
  if(OUT_R1_PLAY==OFF){
    if(IN_M2_PLAY==STOP)r1_play_Cnt++;
    else                r1_play_Cnt=0;
void main(void){ ///풀업저항 사용
  DDRC=0xff;
  TCCR1B=0x0BOCR1A=12499TIMSK=0x10TCNT1=12498// 100ms
  #pragma optsize-
  WDTCR=0b00011000WDTCR=0b00001111//WATCHDOG setting // WDTCR=0x1F; WDTCR=0x0F;
  #ifdef _OPTIMIZE_SIZE_
    #pragma optsize+
  #endif
  r=EE_rif(r>1){ r=0EE_r=r; } OUT_R1_PLAY=r;
  m=EE_mif(m>1){ m=0EE_m=m; } OUT_M1_PLAY=m;
  SREG|=0x80;
    #asm("wdr")
    if(flag){ flag=0;
      LED_M1_ERROR=~IN_M1_FAIL;
      if(IN_EQUALITY){ LED_EQUALITY=1LED_NO_EQUALITY=0; } // 균등시 1 부동시 0
      else           { LED_EQUALITY=0LED_NO_EQUALITY=1; }
      if(OUT_R1_PLAY==OFF){ LED_M1_ERROR=0LED_EQUALITY=0LED_NO_EQUALITY=0; }
      if(IN_PLAY==STOP){      // 작동 정지시
        if(eeprom_save_on==1){ eeprom_save_on=0;
          if(r!=OUT_R1_PLAY)EE_r=r=OUT_R1_PLAY;
          if(m!=OUT_M1_PLAY)EE_m=m=OUT_M1_PLAY;
        OUT_R1_PLAY=OFFOUT_M1_PLAY=OFF;
      else{                  // 작동중
        if(IN_AUTO==0){      // 오토모드
          eeprom_save_on=1;
          if(IN_M1_FAIL==FAIL)OUT_M1_PLAY=OFF;
          else                OUT_M1_PLAY=ON;
          //-----------------------------------------------------------// 수정 한부분  2016.12.31
            if((r1_play_Cnt>=7)&&(IN_M2_PLAY==STOP)){ OUT_R1_PLAY=ONr1_play_Cnt=0; } // 7=700ms
            else                                    { OUT_R1_PLAY=OFF;               }
          if(IN_M2_FAIL==normal){ OUT_R1_PLAY=OFF; }
        elseOUT_R1_PLAY=ONOUT_M1_PLAY=ON; } // 오토모드 아닐 때
댓글 15
조회수 25,804
율이님의 댓글
율이 작성일
감사합니다. 혹수 추가적으로 간단한 주석으로 이해하는데 힌트를 주실수 없을까요???
제가 궁금했던건 답이 아닌 소스에 대한 내용을 통해서 iar로 직접 스스로 변환해보려고 했었습니다.
사이트 왼쪽 메뉴 중 아래에서 12번째에 보면 <AVR 따라하기>가 있습니다.
클릭하면 <2015년 강좌>가 있는데요
8페이지
63 2015년 강좌 001 - 데이터형  이미지
이 강좌글부터 차근차근 공부해보세요
쉬운 예제를 많이 공부해야지 포기하지 않고 초보자를 벗어날 수 있습니다.
율이님의 댓글
율이 댓글의 댓글 작성일
혹시 죄송하지만 위의 프로그램 순서도를 받을 수 있겠습니까??
프로그램 순서도는 본인이 그리셔야지요..
율이님의 댓글
율이 댓글의 댓글 작성일
r=EE_r; if(r>1){ r=0; EE_r=r; } OUT_R1_PLAY=r;
  m=EE_m; if(m>1){ m=0; EE_m=m; } OUT_M1_PLAY=m;
부분에 대한 저장값을 통하여 두개의 보드가 어떻게 서로 확인되어지는지가 모르겠습니다. eeprom은 그냥 초기에 초기화시키는 것만 조심하란 말밖에 없어서 이떻게 구동되는지를 모르겠습니다
두개의 보드가 어떻게 서로 확인되어지는지가 모르겠습니다. <-- 보드가 두개인가요? 무슨 뜻인지 모르겠습니다.
eeprom에 저장하는 이유는
출력중이라면 (정전등의 이유로) 전원을 껏다 키더라도 출력을 계속 하겠다는 뜻이겠죠
율이님의 댓글
율이 댓글의 댓글 작성일
좀더 자세히 설명하겠습니다. 제가 설명이 부족했던거 같습니다.
일단 두개의 파워서플라이가 작동을 하는데 A,B라고 칭하면
일단 각각에 파워서플라이에는 보드가 하나씩 내장되어 있고
출력하던 A가 이상이 생겨서 파워가 약해지거나 하면 B서플라이가 대신 작동되는 소스라고 전해 들었습니다.
저에게 설명을 들으시려면 회로도부터 첨부하셔야합니다.
소스코드는 몇라인 안되고
c문법적으로 어려운 것은 없으며
장비의 기능을 구현한 것이 대부분입니다.
장비 기능은 알고 계실테고, c문법이 부족하면 c언어만 조금 공부하면 되겠죠?
남에게 물어볼 내용은 아닌 것 같습니다.
율이님의 댓글
율이 댓글의 댓글 작성일
문법적으로는 거의다 이해했습니다.
제가 궁금했던 것은 A파워서플라이에서 IN_M1_FAIL값이 들어와서 출력으로 내보내주는데 반대쪽 B서플라이가 작동을 하게 되는데 어떻게 값이 전달 되는지 궁금했습니다 많은 답변 감사합니다
입력 받아서 LED 표시하고
OUT_M1_PLAY 출력
문법을 다 이해 했는데 이렇게 쉬운 내용이 분석 안되던가요?
이 두 라인도 한라인으로 줄일 수 있습니다.
  OUT_M1_PLAY=~IN_M1_FAIL;
율이님의 댓글
율이 댓글의 댓글 작성일
TCCR1B=0x0B; OCR1A=12499; TIMSK=0x10; TCNT1=12498;        // 100ms
  #pragma optsize-
  WDTCR=0b00011000; WDTCR=0b00001111; //WATCHDOG setting // WDTCR=0x1F; WDTCR=0x0F;
    #pragma optsize+
  #endif
이부분에대한 적용하는 값이 달라진것도 궁금합니다.
인터럽트를 이용하여 원래 1ms를 만들기위해서 계산하여 131을 구한건데 어떻게 변경하신건지 궁금합니다.
16비트 타이머를 사용해서 100ms 주기로 바꿨습니다.
16비트 타이머는 (16MHz 클럭에서) 최대 4초까지 가능합니다.
질문 보드는 8MHz를 사용하는 것 같으니 최대 8초까지 가능하겠죠
율이님의 댓글
율이 댓글의 댓글 작성일
위의 코딩에서 혹시 OUT_R1_PLAY값이 초기에 어떻게 되는지 알수있을까요??
전원 키지마자 0V
잠시 후 EEPROM에서 읽어서 출력 합니다.
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 329
공지 사이트 이용 안내댓글[7] master 17-10-29 6423
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 2504
질문 아두이노 질문댓글[1] 새글 리싸 10:30 8
질문 아두이노 알람시계 질문합니다!!댓글[3] 새글 쥬스 10:02 7
질문 블루투스 1대1 연결 질문입니다. 새글 hm02087 01:15 7
답변 답변글 답변 : 블루투스 1대1 연결 질문입니다. 새글 master 10:32 5
질문 마스터님 codevision에서 atmel studio로 변환 여쭤봅니다.댓글[1] 새글첨부파일 whwo0 19-05-24 7
질문 압력센서의 샘플링 값 응용에 관해 질문있습니다..댓글[1] 새글 매난국죽 19-05-24 11
질문 마그네틱 센서 질문드립니다. 새글 화무란 19-05-24 10
답변 답변글 답변 : 마그네틱 센서 질문드립니다. 새글 master 19-05-24 9
질문 master님 질문합니다!댓글[4] 새글 동스타 19-05-24 30
질문 아두이노 코드 합치는 것 질문이요!!!댓글[3] 새글 아야어여 19-05-24 24
질문 정수값을 블루투스로 읽기댓글[1] 새글 상오 19-05-24 13
질문 아두이노 레오나르도와 hc-06 블루투스 모듈 질문드립니다 새글 아야어여 19-05-24 12
답변 답변글 답변 : 아두이노 레오나르도와 hc-06 블루투스 모듈 질문드립니다 새글 master 19-05-24 13
질문 블루투스 코딩 문의댓글[2] 새글 후우우운 19-05-24 14
답변 답변글 답변 : 블루투스 코딩 문의댓글[3] 새글 master 19-05-24 22
질문 if문 중복이 안되나요? 소스좀 봐주세요 이미지새글첨부파일 지니아빠 19-05-24 9
답변 답변글 답변 : if문 중복이 안되나요? 소스좀 봐주세요댓글[3] 이미지새글 master 19-05-24 14
질문 스탑와치를 타이머 인터럽트로 구동시키려구 합니다 새글 master1 19-05-24 9
질문 아두이노 회로도 합치는방법을 모르겠어요 ㅠㅠ댓글[1] 새글 겨울비 19-05-24 12
질문 초음파와 금속센서 + 서보모터 (추가질문) 새글 아두이노초짜 19-05-23 8
답변 답변글 답변 : 초음파와 금속센서 + 서보모터 (추가질문) 새글 master 19-05-24 7
질문 초음파, 온도 센서를 이용해서 펌프 만들 때댓글[4] 새글 벡터스칼라 19-05-23 28
질문 ATMEGA128a 타이머와 부저 새글 동스타 19-05-23 20
답변 답변글 답변 : ATMEGA128a 타이머와 부저댓글[1] 새글 master 19-05-24 13
질문 atmega128a 디지털시계 문의드립니다 새글 아트메가잘하고싶다 19-05-23 32
답변 답변글 답변 : atmega128a 디지털시계 문의드립니다 새글 master 19-05-24 18
질문 마스터님께(창문소스코드 의문점) 새글 wait 19-05-23 13
