질문게시판 > 답변 : 아두이노를 이용한 오디오 스펙트럼 질문드립니다.
TODAY880 TOTAL1,145,670
BASIC4MCU | 질문게시판 | 답변 : 아두이노를 이용한 오디오 스펙트럼 질문드립니다.
작성자 master 작성일2018-10-20 17:32 조회1,516회 댓글0건
// DateTime : 2018-10-20 오후 5:36:50
#include <MSGEQ7.h>
#include <Keypad.h>
#include <Adafruit_NeoPixel.h>
#define MIN_K_value 100
#define MAX_K_value 200
int K_value=100;
MSGEQ7 eq;
Adafruit_NeoPixel pixels=Adafruit_NeoPixel(40,6,NEO_GRB+NEO_KHZ800);
const byte ROWS=4//four rows
const byte COLS=4//four columns
char keys[ROWS][COLS]={ // 키패드의 4행 4열을 정의
  { 'A','B','C','D'},
  { 'E','F','G','H'},
  { 'I','J','K','L'},
  { 'M','N','O','P'}
byte rowPins[ROWS]={ 10,11,12,13}; //connect to the row pinouts of the keypad
byte colPins[COLS]={ 9,8,7,3}; //connect to the column pinouts of the keypad
Keypad keypad=Keypad(makeKeymap(keys),rowPins,colPins,ROWS,COLS);
uint32_t*color_map;
uint32_t color_a[40]={
  0x00E1FFE1,0x00E1FFE1,0x00E1FFE1,0x00E1FFE1,0x00E1FFE1,0x00E1FFE1,0x00E1FFE1,0x00E1FFE1,
  0x00008000,0x00008000,0x00008000,0x00008000,0x00008000,0x00008000,0x00008000,0x00008000,
  0x00FFFF00,0x00FFFF00,0x00FFFF00,0x00FFFF00,0x00FFFF00,0x00FFFF00,0x00FFFF00,0x00FFFF00,
  0x000000ff,0x000000ff,0x000000ff,0x000000ff,0x000000ff,0x000000ff,0x000000ff,0x000000ff,
  0x00ff0000,0x00ff0000,0x00ff0000,0x00ff0000,0x00ff0000,0x00ff0000,0x00ff0000,0x00ff0000
uint32_t color_b[40]={
  0x00efef00,0x00efef00,0x00efef00,0x00efef00,0x00efef00,0x00efef00,0x00efef00,0x005050af,
  0x009400D3,0x009400D3,0x009400D3,0x009400D3,0x009400D3,0x009400D3,0x009400D3,0x009400D3,
  0x00efef00,0x00efef00,0x00efef00,0x00efef00,0x00efef00,0x00efef00,0x00efef00,0x00efef00,
uint32_t color_c[40]={
  0x0032BEBE,0x0032BEBE,0x0032BEBE,0x0032BEBE,0x0032BEBE,0x0032BEBE,0x0032BEBE,0x0032BEBE,
uint32_t color_d[40]={
  0x00FFFFFB,0x00FFFFFB,0x00C63C26,0x0000FFFF,0x00C63C26,0x00444693,0x00444693,0x00C77EB5,
uint32_t color_p[40]={
  0x00000000,0x00000000,0x00000000,0x00000000,0x00000000,0x00000000,0x00000000,0x00000000,
  eq.init();
  pixels.begin();
  pixels.clear();
int cnt=0,on_off=0;
  char key=keypad.getKey();
  if(key=='A'){ color_map=color_aSerial.println(color_map[0]); }
  if(key=='B'){ color_map=color_bSerial.println(color_map[0]); }
  if(key=='C'){ color_map=color_cSerial.println(color_map[0]); }
  if(key=='D'){ color_map=color_dSerial.println(color_map[0]); }
  if(key=='E'){                    Serial.println(color_map[0]); }
  if(key=='P'){ color_map=color_pSerial.println(color_map[0]); }
  if(key=='N'){ K_value=100cnt=0,on_off=1pixels.clear(); }
  if(key=='O'){ on_off^=1Serial.print("on_off="); Serial.println(on_off); }
  if(on_off){
  eq.poll();
  int max_v=0;
  pixels.clear();
  for(int i=0i<7i++){
    int l=eq.getLValue(i);
    int r=eq.getRValue(i);
    int v=(l<r?r:l);
    max_v=(v>max_v?v:max_v);
    for(int j=0;j<5;j++){ if(v>K_value*(5-j))on_pixel(i+(8*j)); }
  for(int j=0;j<5;j++){ if(max_v>K_value*(5-j))on_pixel(7+(8*j)); }
  K_value=constrain(max_v/5,MIN_K_value,MAX_K_value);
  pixels.show();
void on_pixel(int index){
  pixels.setPixelColor(index,color_map[index]);
조회수 1,516
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 1856
공지 사이트 이용 안내댓글[12] master 17-10-29 11750
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 4434
질문 아두이노 질문있습니다댓글[1] 이미지새글 djfuqspdy 20-07-12 18
질문 PD제어 소스 질문있습니다.댓글[3] 궁금 20-07-10 31
질문 unique id 생성댓글[1] cheaminee 20-07-10 27
질문 아두이노 포트 변경댓글[2] cheaminee 20-07-09 34
질문 소스 코딩 도와주세요 bas213 20-07-09 41
답변 답변글 답변 : 소스 코딩 도와주세요 master 20-07-09 32
질문 안녕하세요. 질문있습니다. dkendlsh 20-07-08 24
답변 답변글 답변 : 안녕하세요. 질문있습니다.댓글[1] master 20-07-08 30
질문 아두이노 nfc 센서와 pH센서 같이 연결댓글[1] 알려주세요제발ㅠㅠ 20-07-08 30
질문 아두이노 초음파 센서, 부저, 스위치 합치기 도와주세요ㅜㅜ 이밍밍 20-07-05 55
질문 이 도어락 코드좀 이미지첨부파일 문준혁 20-07-05 60
질문 아두이노 입력전원댓글[2] 왕왕초a 20-07-02 67
질문 외부인터럽트가 발생했을때 ADC변환, 데이터 송신프로그램 질문입니다. 이소부 20-07-02 39
답변 답변글 답변 : 외부인터럽트가 발생했을때 ADC변환, 데이터 송신프로그램 질문입니다. master 20-07-02 48
질문 아두이노 마사지 키트 문의드립니다.댓글[3] 야아이양 20-07-02 52
질문 아두이노 공기청정기댓글[3] 행노비 20-07-02 64
질문 (아두이노)압력센서를 이용한 led on/off와 팬 작동댓글[1] 호조조 20-07-02 45
질문 아두이노 기체유량센서댓글[1] 최하림 20-07-01 42
질문 아두이노 pwm 제어 관련 질문드리고 싶습니다.댓글[4] 궁금스 20-07-01 79
질문 아두이노 합침 첨부파일 우경민 20-06-30 52
질문 소스 합쳐주세요 첨부파일 우경민 20-06-30 66
답변 답변글 답변 : 소스 합쳐주세요댓글[1] master 20-06-30 92
질문 소스코드 질문드립니다댓글[1] rqjiqwrji 20-06-30 79
질문 안녕하세요. 이런피아노 제작이 가능할까요?댓글[3] 애니멀티비 20-06-30 109
질문 서보모터+세그먼트+버튼 이용 오류 해결좀요..댓글[1] 이미지첨부파일 우편봉투 20-06-29 84
질문 소스코드 질문드립니다. mangham 20-06-29 66
답변 답변글 답변 : 소스코드 질문드립니다. master 20-06-29 60
