질문게시판 > 마스터님 코딩 도움이 필요합니다.
TODAY985 TOTAL605,614
BASIC4MCU | 질문게시판 | 마스터님 코딩 도움이 필요합니다.
작성자 S대학생 작성일2018-10-22 15:28 조회739회 댓글0건
#include <IRremote.h>
int pinLB = 2; // L298N IN1
int pinLF = 3; // L298N IN2
int pinRB = 4; // L298N IN3
int pinRF = 5; // L298N IN4
int Lled = 8;
int Rled = 9;
long advence = 0x00FF18E7;
long back    = 0x00FF4AB5;
long stop    = 0x00FF38C7;
long left    = 0x00FF10EF;
long right   = 0x00FF5AA5;
long leftled = 0x00FF30CF;
long rightled = 0x00FF7A85;
int RECV_PIN = A0;
IRrecv irrecv(RECV_PIN);
decode_results results;
unsigned long last = millis();
unsigned long Llast, Rlast;
int mode = 0;
void M_stop() {
  digitalWrite(pinRB, 1);
  digitalWrite(pinRF, 1);
  digitalWrite(pinLB, 1);
  digitalWrite(pinLF, 1);
void M_fwd()  {
  digitalWrite(pinRB, 0);
  digitalWrite(pinLB, 0);
void M_back() {
  digitalWrite(pinRF, 0);
  digitalWrite(pinLF, 0);
void M_left() {
void M_right() {
void dump(decode_results *results) {
  int count = results->rawlen;
  if (results->decode_type == UNKNOWN) {
    Serial.println("Could not decode message");
  else {
    if     (results->decode_type == NEC ) {
      Serial.print("Decoded NEC: ");
    else if (results->decode_type == SONY) {
      Serial.print("Decoded SONY: ");
    else if (results->decode_type == RC5 ) {
      Serial.print("Decoded RC5: ");
    else if (results->decode_type == RC6 ) {
      Serial.print("Decoded RC6: ");
    Serial.print(results->value, HEX); Serial.print("(");
    Serial.print(results->bits , DEC); Serial.println(" bits)");
  Serial.print("Raw("); Serial.print(count, DEC); Serial.print("): ");
  for (int i = 0; i < count; i++) {
    if (i % 2) {
      Serial.print(      results->rawbuf[i]*USECPERTICK, DEC);
    else   {
      Serial.print(-(int)results->rawbuf[i]*USECPERTICK, DEC);
    Serial.print(" ");
  Serial.println("");
  pinMode(pinLB, OUTPUT); pinMode(pinLF, OUTPUT); pinMode(pinRB, OUTPUT); pinMode(pinRF, OUTPUT);
  pinMode(13, OUTPUT);    pinMode(Lled, OUTPUT);  pinMode(Rled, OUTPUT);
  pinMode(RECV_PIN, INPUT);
  irrecv.enableIRIn();
  if (irrecv.decode(&results)) {
    if (millis() - last > 250) {
      last = millis();
      digitalWrite(13, !digitalRead(13));
      dump(&results);
    if (results.value == advence) {
      mode = 0;
      M_fwd();
    if (results.value == back   ) {
      mode = 0;
      M_back();
    if (results.value == stop   ) {
      mode = 0;
      M_stop();
      digitalWrite(Lled, LOW);
      digitalWrite(Rled, LOW);
    if (results.value == left   ) {
      mode = 'L';
      M_left();
      digitalWrite(Lled, 1);
      Llast = millis();
    if (results.value == right  ) {
      mode = 'R';
      M_right();
      digitalWrite(Rled, 1);
      Rlast = millis();
    irrecv.resume();
  if (mode == 'L') {
    if (millis() - Llast > 250) {
      Llast = millis();
      digitalWrite(Lled, !digitalRead(Lled));
  if (mode == 'R') {
    if (millis() - Rlast > 250) {
      Rlast = millis();
      digitalWrite(Rled, !digitalRead(Rled));
이 코드에 밑에 코드를 후진할시에 같이 작동되고 정지를 누를시 off 되도록 하고 싶은데 도와주세요
#define PIEZO 6
#define c4 3822 // 261.63Hz 도
#define d4 3405 // 293.67Hz 레
#define e4 3034 // 329.63Hz 미
#define f4 2863 // 349.23Hz 파
#define g4 2551 // 392.11Hz 솔
#define g4s 2408 // 415.30Hz 솔#
#define a4 2273 // 440.11Hz 라
#define b4 2025 // 493.88Hz 시
#define c5 1910 // 523.25Hz 도
#define d5 1703 // 587.33Hz 레
#define d5s 1607 // 584.37Hz 레#
#define e5 1517 // 659.26Hz 미
#define f5 1432 // 698.46Hz 파
#define g5 1276 // 783.99Hz 솔
#define a5 1136 // 880.11Hz 라
#define b5 1012 // 987.77Hz 시
int song[] = { e5, d5s, e5, d5s, e5, b4, d5, c5, a4, c4, e4, a4, b4, e4, g4s, b4, c5, e4, e5, d5s, e5, d5s, e5, b4, d5, c5, a4, c4, e4, a4, b4, e4, c5, b4, a4 };
int song_pivot = 0;
unsigned long mil = 0;
  pinMode(PIEZO, OUTPUT);
  if (millis() - mil > 100) {
    int isLong;
    if(song_pivot == 8 || song_pivot == 12 || song_pivot == 16 || song_pivot == 26 || song_pivot == 30) {
      isLong = 3;
    } else if(song_pivot == 34) {
      isLong = 6;
    sing(song[song_pivot++], isLong);
    if(song_pivot == 35)  song_pivot = 0;
    mil = millis();
void sing(int eum, int isLong) {
  long lele = 125000;
  if(isLong == 3) lele = 375000;
  else if(isLong == 6) lele = 750000;
  for(long i=0; i< lele ; i+= eum) {
    digitalWrite(PIEZO, HIGH);
    delayMicroseconds(eum/2);
    digitalWrite(PIEZO, LOW);
조회수 739
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 596
공지 사이트 이용 안내댓글[8] master 17-10-29 7623
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 2843
질문 atmega128a 카운터/타이머 출력비교 질문이요댓글[1] 새글 초짜 19-08-17 12
질문 모터드라이버 병렬 연결댓글[3] 박준2 19-08-16 19
질문 서로 다른전원(5v 12v) 제어방법 질문 master 19-08-16 10
질문 모터드라이버 관련 질문 드립니다.댓글[4] 박준이 19-08-15 21
질문 Atmega128, 초음파센서 ,부저 gksl 19-08-14 18
답변 답변글 답변 : Atmega128, 초음파센서 ,부저댓글[1] master 19-08-15 18
질문 led 전력소모에 관하여,,,댓글[9] 슬레a 19-08-14 43
질문 알고리즘 문의댓글[1] 벅바 19-08-13 19
질문 블루투스가 한번 작동하고 그 다음부터 작동을 하지 않습니다.댓글[1] 아야어여 19-08-13 22
질문 아두이노 코딩 질문입니다 너무 급해요 ㅠㅠ댓글[3] 전민결 19-08-12 46
질문 코딩 작성좀 부탁드립니다. 너무 급합니다 ㅠㅠ댓글[1] 아두이노보초 19-08-10 65
질문 stm32f1 계열에서 USB로 스마트폰 연결 방법(CDC)댓글[2] 에르테르 19-08-08 38
질문 코딩을 합치고 싶습니다.. 알려주세요 19-08-08 40
답변 답변글 답변 : 코딩을 합치고 싶습니다.. master 19-08-08 40
질문 금속센서를 이용한 서보모터 돌리기댓글[1] 후우 19-08-07 49
질문 아두이노로 빛 파장 계산하기 이미지 master 19-08-07 36
질문 ISP 질문이요댓글[2] 초짜 19-08-06 32
질문 atmega128a 다시 질문이요~댓글[4] 이미지첨부파일 초짜 19-08-05 53
질문 atmega128a SCK 질문이요댓글[1] 초짜 19-08-04 39
답변 답변글 답변 : atmega128a SCK 질문이요 master 19-08-04 30
질문 A4988 모터드라이버 발열에 대해...댓글[1] 이미지첨부파일 눈티이 19-07-30 64
질문 아두이노 코딩 질문댓글[1] 119min 19-07-27 75
질문 아두이노 코딩질문 붕붕 19-07-26 63
답변 답변글 답변 : 아두이노 코딩질문댓글[6] master 19-07-26 148
질문 적외선 센서 송수신 코딩 알려주세요댓글[3] 이미지첨부파일 뱀비 19-07-22 110
질문 BLDC 모터 정역회전 알고리즘대로 코딩 이미지첨부파일 CIE18 19-07-21 74
답변 답변글 답변 : BLDC 모터 정역회전 알고리즘대로 코딩 master 19-07-21 71
