질문게시판 > 아두이노 코딩 질문
TODAY2,802 TOTAL794,971
BASIC4MCU | 질문게시판 | 아두이노 코딩 질문
작성자 ungung2 작성일2018-10-27 21:27 조회953회 댓글0건
int ledPins[]={36,37,38,39,40,41,42,43,44,45,46,47};//디지털 핀 입력 (사다리)
void RandomLED(){//(랜덤으로 사다리 설정)
  int rand = random(14);//0~13 난수
  if(rand==0){
    digitalWrite(ledPins[0],HIGH);
    digitalWrite(ledPins[1],HIGH);
    digitalWrite(ledPins[2],LOW);
    digitalWrite(ledPins[3],HIGH);
    digitalWrite(ledPins[4],LOW);
    digitalWrite(ledPins[5],LOW);
    digitalWrite(ledPins[6],HIGH);
    digitalWrite(ledPins[7],LOW);
    digitalWrite(ledPins[8],HIGH);
    digitalWrite(ledPins[9],HIGH);
    digitalWrite(ledPins[10],LOW);
    digitalWrite(ledPins[11],HIGH);
  else if(rand==1){
    digitalWrite(ledPins[3],LOW);
    digitalWrite(ledPins[7],HIGH);
    digitalWrite(ledPins[11],LOW);
  else if(rand==2){
    digitalWrite(ledPins[6],LOW);
    digitalWrite(ledPins[10],HIGH);
  else if(rand==3){
    digitalWrite(ledPins[0],LOW);
    digitalWrite(ledPins[1],LOW);
    digitalWrite(ledPins[2],HIGH);
    digitalWrite(ledPins[4],HIGH);
    digitalWrite(ledPins[5],HIGH);
    digitalWrite(ledPins[8],LOW);
    digitalWrite(ledPins[9],LOW);
  else if(rand==4){
  else if(rand==5){
  else if(rand==6){
  else if(rand==7){
  else if(rand==8){
 else if(rand==9){
  else if(rand==10){
  else if(rand==11){
  else if(rand==12){
  else {
void flowLine1(int a,int b){//각 라인 출력 위한 함수
  for(int i=a;i<=b;i++) {
  digitalWrite(i,HIGH);
  delay(200);
void flowLine2(int a,int b){
  delay(200);
void flowLine3(int a,int b){
  delay(200);
void flowLine4(int a,int b){
  delay(200);
void button1(){ // 라인 1 출력위한 함수
  //button 누르면
  flowLine1(0,1);
  if(ledPins[0]=1)
    //flowLineStop1(1);
    //flowLineNew2(10);
    flowLine2(10,12);
   if(ledPins[1]=1)
      flowLine1(3,5);
      delay(300);
      if(ledPins[2]=0)
        {flowLine1(6,7);
          if(ledPins[3]=1)
            flowLine1(7,8);
          {flowLine2(16,17);} }
      else if(ledPins[2]=1)
      {flowLine2(14,16);
    }//else
    }//1-high
    else if(ledPins[1]=0)
    flowLine2(13,14);
     if(ledPins[5]=1)
    {flowLine3(21,23);}
   }//ledpins[0]=high
 flowLine1(2,3);
  // initialize digital pin 13 as an output.
  for(int i=0;i<36;i++) {
    pinMode(i,OUTPUT);
  }//36개 라인 핀
 for(int i=0; i<12; i++){
  pinMode(ledPins[i],OUTPUT);
}//사다리 12개 핀
 for(int i=0;i<9;i++) {
  digitalWrite(i,LOW);
  digitalWrite(i+9,LOW);
  digitalWrite(i+18,LOW);
  digitalWrite(i+27,LOW);
 randomSeed(analogRead(A0));
 delay(500);
 RandomLED();
button1();
}//setup
led와 버튼만 이용해서 네 개의 라인 사다리 타기를 만들고 있습니다.
RandomLED() 함수를 통해 미리 설정한(그려둔? 14가지 경우만 하려고합니다) 사다리 led를
키고 이후에 button1 함수를 부르면 첫번째 라인 led가 high가 되면서 타고 내려오는건데요
맞게 구성한거같은데 자꾸 1번째 2번째 사다리led 에서 high가 아닌데도 그 조건문이 실행됩니다. 방법이 없을까요?
조회수 953
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 986
공지 사이트 이용 안내댓글[10] master 17-10-29 8951
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 3382
질문 atmega 128 깔끔하게 정리 부탁드려요 ㅠㅠ댓글[1] 새글 끵끵끵 17:17 6
답변 답변글 답변 : atmega 128 깔끔하게 정리 부탁드려요 ㅠㅠ 새글 master 17:43 3
질문 아두이노 고정밀 서보모터 구동 새글 master 17:12 4
질문 AVR ATMEGA128 블루투스 서보모터 제어 질문드립니다.댓글[5] 새글 어려운AVR 14:13 6
질문 atmega128 스톱워치 질문 새글 master 13:15 12
질문 atmega128 가변저항 LED 새글 비러 13:15 3
답변 답변글 답변 : atmega128 가변저항 LED 새글 master 13:37 4
질문 ATMEGA128 스위치적인 질문이 있습니다.댓글[1] 새글 lilliCe 06:32 12
질문 아두이노 코딩 질문이요ㅠㅠ 새글 rkdeh 04:02 6
답변 답변글 답변 : 아두이노 코딩 질문이요ㅠㅠ 새글 master 09:44 9
질문 아두이노 rc카 코딩댓글[1] 새글 KInb 19-12-09 9
질문 atmega16 빨리누르기 게임 이미지새글첨부파일 잘생김 19-12-09 24
답변 답변글 답변 : atmega16 빨리누르기 게임 새글 master 19-12-09 16
질문 AVR POLLING EDGE 질문 새글 master 19-12-09 5
질문 atmega128 온도센서 이용 모터 제어 질문드립니다. 이미지새글첨부파일 우와우와웅 19-12-09 15
답변 답변글 답변 : atmega128 온도센서 이용 모터 제어 질문드립니다. 새글 master 19-12-09 26
질문 Atmega128 코드 질문댓글[1] 이미지새글첨부파일 Hanshin 19-12-09 17
질문 세그먼트 코드 오류 재질문 새글 프로미스애인 19-12-08 9
답변 답변글 답변 : 세그먼트 코드 오류 재질문 새글 master 19-12-09 9
질문 Atmega 128 세그먼트카운팅 질문댓글[1] 새글 프로미스애인 19-12-08 15
질문 앱인벤터 아두이노 이용해서 피아노음율내기 bas213 19-12-07 14
답변 답변글 답변 : 앱인벤터 아두이노 이용해서 피아노음율내기 master 19-12-07 15
질문 아두이노 컴파일 오류 질문입니다!!댓글[1] 메롱198 19-12-07 18
질문 Atmega128로 3-phase BLDC MOTOR 구동 질문! 이미지첨부파일 조셉 19-12-06 24
답변 답변글 답변 : Atmega128로 3-phase BLDC MOTOR 구동 질문!댓글[2] master 19-12-06 39
질문 세그먼트 숫자가 같을시 LED 깜박거리기댓글[1] 홍구 19-12-06 28
질문 MP3 모듈 질문있습니다.댓글[1] 초짜 19-12-06 19
MCU BASIC ⓒ 2019
