질문게시판 > gps실드에서 받아온 위도 경도 값이 일정범위에 들어온다면 진동을 주도록 설계하고 싶습니다.
TODAY847 TOTAL605,476
BASIC4MCU | 질문게시판 | gps실드에서 받아온 위도 경도 값이 일정범위에 들어온다면 진동을 주도록 설계하고 싶습니다.
작성자 전기공학도 작성일2018-10-31 09:17 조회528회 댓글0건
#include <TinyGPS.h>
/* This sample code demonstrates the normal use of a TinyGPS object.
   It requires the use of SoftwareSerial, and assumes that you have a
   4800-baud serial GPS device hooked up on pins 3(rx) and 4(tx).
TinyGPS gps;
SoftwareSerial nss(4, 3);
static void gpsdump(TinyGPS &gps);
static bool feedgps();
static void print_float(float val, float invalid, int len, int prec);
static void print_int(unsigned long val, unsigned long invalid, int len);
static void print_date(TinyGPS &gps);
static void print_str(const char *str, int len);
  nss.begin(9600);
  d
  Serial.print("Testing TinyGPS library v. "); Serial.println(TinyGPS::library_version());
  Serial.println("by Mikal Hart");
  Serial.println();
  Serial.print("Sizeof(gpsobject) = "); Serial.println(sizeof(TinyGPS));
  Serial.println();
  Serial.println("Sats HDOP Latitude Longitude Fix  Date       Time       Date Alt     Course Speed Card  Distance Course Card  Chars Sentences Checksum");
Serial.println(" (deg) (deg) Age Age (m) --- from GPS ---- ---- to London ---- RX RX Fail");
  Serial.println("--------------------------------------------------------------------------------------------------------------------------------------");
  bool newdata = false;
  unsigned long start = millis();
  // Every second we print an update
  while (millis() - start < 1000)
    if (feedgps())
      newdata = true;
  gpsdump(gps);
  float flat, flon;
  unsigned long age, date, time, chars = 0;
  unsigned short sentences = 0, failed = 0;
  static const float LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
  print_int(gps.satellites(), TinyGPS::GPS_INVALID_SATELLITES, 5);
  print_int(gps.hdop(), TinyGPS::GPS_INVALID_HDOP, 5);
  gps.f_get_position(&flat, &flon, &age);
  print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 9, 5);
  print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 10, 5);
  print_int(age, TinyGPS::GPS_INVALID_AGE, 5);
  print_date(gps);
  print_float(gps.f_altitude(), TinyGPS::GPS_INVALID_F_ALTITUDE, 8, 2);
  print_float(gps.f_course(), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
  print_float(gps.f_speed_kmph(), TinyGPS::GPS_INVALID_F_SPEED, 6, 2);
  print_str(gps.f_course() == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(gps.f_course()), 6);
  print_int(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0UL : (unsigned long)TinyGPS::distance_between(flat, flon, LONDON_LAT, LONDON_LON) / 1000, 0xFFFFFFFF, 9);
  print_float(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : TinyGPS::course_to(flat, flon, 51.508131, -0.128002), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
  print_str(flat == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON)), 6);
  gps.stats(&chars, &sentences, &failed);
  print_int(chars, 0xFFFFFFFF, 6);
  print_int(sentences, 0xFFFFFFFF, 10);
  print_int(failed, 0xFFFFFFFF, 9);
  Serial.println();
  char sz[32];
  if (val == invalid)
    strcpy(sz, "*******");
    sprintf(sz, "%ld", val);
  sz[len] = 0;
  for (int i=strlen(sz); i<len; ++i)
    sz[i] = ' ';
  if (len > 0)
    sz[len-1] = ' ';
  Serial.print(sz);
  feedgps();
  char sz[32];
  if (val == invalid)
    sz[len] = 0;
        if (len > 0)
          sz[len-1] = ' ';
    for (int i=7; i<len; ++i)
        sz[i] = ' ';
    Serial.print(sz);
    Serial.print(val, prec);
    int vi = abs((int)val);
    int flen = prec + (val < 0.0 ? 2 : 1);
    flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
    for (int i=flen; i<len; ++i)
      Serial.print(" ");
  feedgps();
  int year;
  byte month, day, hour, minute, second, hundredths;
  unsigned long age;
  gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
  if (age == TinyGPS::GPS_INVALID_AGE)
    Serial.print("*******    *******    ");
    char sz[32];
    sprintf(sz, "%02d/%02d/%02d %02d:%02d:%02d   ",
        month, day, year, hour, minute, second);
    Serial.print(sz);
  feedgps();
  int slen = strlen(str);
  for (int i=0; i<len; ++i)
    Serial.print(i<slen ? str[i] : ' ');
  feedgps();
  while (nss.available())
    if (gps.encode(nss.read()))
      return true;
  return false;
예를들어 위도 38.5 경도  50일시 38<=위도 <=39   49.5<=경도<=50.5
이곳에서 받아온 gps 위도 경도값을 어느 범위에 들어오면 (체크포인트로) 진동센서가 인지해서 진동을 주고싶은데 세기는 255정도로주고싶습니다. 혹시 코딩 도와주실 수 있으신가요 ..ㅠㅠ
조회수 528
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 595
공지 사이트 이용 안내댓글[8] master 17-10-29 7621
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 2843
질문 atmega128a 카운터/타이머 출력비교 질문이요댓글[1] 새글 초짜 19-08-17 10
질문 모터드라이버 병렬 연결댓글[3] 새글 박준2 19-08-16 17
질문 서로 다른전원(5v 12v) 제어방법 질문 master 19-08-16 10
질문 모터드라이버 관련 질문 드립니다.댓글[4] 박준이 19-08-15 20
질문 Atmega128, 초음파센서 ,부저 gksl 19-08-14 16
답변 답변글 답변 : Atmega128, 초음파센서 ,부저댓글[1] master 19-08-15 18
질문 led 전력소모에 관하여,,,댓글[9] 슬레a 19-08-14 43
질문 알고리즘 문의댓글[1] 벅바 19-08-13 19
질문 블루투스가 한번 작동하고 그 다음부터 작동을 하지 않습니다.댓글[1] 아야어여 19-08-13 21
질문 아두이노 코딩 질문입니다 너무 급해요 ㅠㅠ댓글[3] 전민결 19-08-12 45
질문 코딩 작성좀 부탁드립니다. 너무 급합니다 ㅠㅠ댓글[1] 아두이노보초 19-08-10 64
질문 stm32f1 계열에서 USB로 스마트폰 연결 방법(CDC)댓글[2] 에르테르 19-08-08 38
질문 코딩을 합치고 싶습니다.. 알려주세요 19-08-08 40
답변 답변글 답변 : 코딩을 합치고 싶습니다.. master 19-08-08 40
질문 금속센서를 이용한 서보모터 돌리기댓글[1] 후우 19-08-07 49
질문 아두이노로 빛 파장 계산하기 이미지 master 19-08-07 36
질문 ISP 질문이요댓글[2] 초짜 19-08-06 32
질문 atmega128a 다시 질문이요~댓글[4] 이미지첨부파일 초짜 19-08-05 53
질문 atmega128a SCK 질문이요댓글[1] 초짜 19-08-04 39
답변 답변글 답변 : atmega128a SCK 질문이요 master 19-08-04 30
질문 A4988 모터드라이버 발열에 대해...댓글[1] 이미지첨부파일 눈티이 19-07-30 64
질문 아두이노 코딩 질문댓글[1] 119min 19-07-27 75
질문 아두이노 코딩질문 붕붕 19-07-26 63
답변 답변글 답변 : 아두이노 코딩질문댓글[6] master 19-07-26 148
질문 적외선 센서 송수신 코딩 알려주세요댓글[3] 이미지첨부파일 뱀비 19-07-22 110
질문 BLDC 모터 정역회전 알고리즘대로 코딩 이미지첨부파일 CIE18 19-07-21 73
답변 답변글 답변 : BLDC 모터 정역회전 알고리즘대로 코딩 master 19-07-21 69
