질문게시판 > 답변 : rc카 관련 질문입니다.
TODAY2,847 TOTAL795,016
BASIC4MCU | 질문게시판 | 답변 : rc카 관련 질문입니다.
작성자 master 작성일2018-10-31 16:44 조회690회 댓글0건
// DateTime : 2018-10-31 오후 4:49:26
#include <DHT11.h>
#include <AFMotor.h>
#include <SoftwareSerial.h>
const int trigPin=6,echoPin=7,rxPin=A0,txPin=2,pin=12;
DHT11 dht11(pin);
LiquidCrystal_I2C lcd(0x3F,16,2);
SoftwareSerial mySerial(rxPin,txPin); // RX,TX
AF_DCMotor motor_1(1);
AF_DCMotor motor_2(2);
AF_DCMotor motor_4(4);
  pinMode(trigPin,OUTPUT); pinMode(echoPin,INPUT);
  lcd.begin(); lcd.clear(); lcd.backlight();
  mySerial.begin(9600);
  motor_1.setSpeed(150); motor_2.setSpeed(150); motor_4.setSpeed(250);
  motor_1.run(RELEASE); motor_2.run(RELEASE);
char mode=0;
  if(mySerial.available()){
    char ch=mySerial.read();
    motor_4.run(FORWARD); //쿨링팬 속도 고정
    switch(ch){
      case 'F'mode=chSerial.write(mode); motor_1.run(FORWARD); motor_2.run(FORWARD); break;
      case 'B'mode=chSerial.write(mode); motor_1.run(BACKWARD); motor_2.run(BACKWARD); break;
      case 'L'mode=chSerial.write(mode); motor_1.run(BACKWARD); motor_2.run(FORWARD); break;
      case 'R'mode=chSerial.write(mode); motor_1.run(FORWARD); motor_2.run(BACKWARD); break;
      case 'S'mode=chSerial.write(mode); motor_1.run(RELEASE); motor_2.run(RELEASE); break;
      case 'A'mode=chSerial.write(mode); break//자동모드
  if(mode=='A'){ //초음파,lcd 띄우기
    Serial.println("Astart");
    double duration,distance;
    digitalWrite(trigPin,LOW); delayMicroseconds(2);
    digitalWrite(trigPin,HIGH); delayMicroseconds(10); digitalWrite(trigPin,LOW);
    duration=pulseIn(echoPin,HIGH); distance=duration*17/1000;
    delay(200);
    lcd.setCursor(0,0); lcd.print(distance); lcd.setCursor(8,0); lcd.print("cm");
    float humi,tempdht11.read(humi,temp);
    lcd.setCursor(0,1); lcd.print(temp); lcd.print((char)223); lcd.print("C");
    lcd.setCursor(8,1); lcd.print(humi); lcd.print("%");
    if(distance>=10){ motor_1.run(FORWARD); motor_2.run(FORWARD); }
    elsemotor_1.run(FORWARD); motor_2.run(RELEASE); } // 정방향으로 회전
    Serial.println("Adnd");
시리얼모니터에 출력하도록 수정했으니
코드가 어디를 실행하는지 체크하세요
조회수 690
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 986
공지 사이트 이용 안내댓글[10] master 17-10-29 8952
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 3382
질문 atmega 128 깔끔하게 정리 부탁드려요 ㅠㅠ댓글[1] 새글 끵끵끵 17:17 8
답변 답변글 답변 : atmega 128 깔끔하게 정리 부탁드려요 ㅠㅠ댓글[1] 새글 master 17:43 7
질문 아두이노 고정밀 서보모터 구동 새글 master 17:12 4
질문 AVR ATMEGA128 블루투스 서보모터 제어 질문드립니다.댓글[5] 새글 어려운AVR 14:13 6
질문 atmega128 스톱워치 질문 새글 master 13:15 12
질문 atmega128 가변저항 LED 새글 비러 13:15 3
답변 답변글 답변 : atmega128 가변저항 LED 새글 master 13:37 4
질문 ATMEGA128 스위치적인 질문이 있습니다.댓글[1] 새글 lilliCe 06:32 12
질문 아두이노 코딩 질문이요ㅠㅠ 새글 rkdeh 04:02 6
답변 답변글 답변 : 아두이노 코딩 질문이요ㅠㅠ 새글 master 09:44 9
질문 아두이노 rc카 코딩댓글[1] 새글 KInb 19-12-09 9
질문 atmega16 빨리누르기 게임 이미지새글첨부파일 잘생김 19-12-09 24
답변 답변글 답변 : atmega16 빨리누르기 게임 새글 master 19-12-09 16
질문 AVR POLLING EDGE 질문 새글 master 19-12-09 5
질문 atmega128 온도센서 이용 모터 제어 질문드립니다. 이미지새글첨부파일 우와우와웅 19-12-09 16
답변 답변글 답변 : atmega128 온도센서 이용 모터 제어 질문드립니다. 새글 master 19-12-09 27
질문 Atmega128 코드 질문댓글[1] 이미지새글첨부파일 Hanshin 19-12-09 17
질문 세그먼트 코드 오류 재질문 새글 프로미스애인 19-12-08 9
답변 답변글 답변 : 세그먼트 코드 오류 재질문 새글 master 19-12-09 9
질문 Atmega 128 세그먼트카운팅 질문댓글[1] 새글 프로미스애인 19-12-08 15
질문 앱인벤터 아두이노 이용해서 피아노음율내기 bas213 19-12-07 14
답변 답변글 답변 : 앱인벤터 아두이노 이용해서 피아노음율내기 master 19-12-07 15
질문 아두이노 컴파일 오류 질문입니다!!댓글[1] 메롱198 19-12-07 18
질문 Atmega128로 3-phase BLDC MOTOR 구동 질문! 이미지첨부파일 조셉 19-12-06 24
답변 답변글 답변 : Atmega128로 3-phase BLDC MOTOR 구동 질문!댓글[2] master 19-12-06 39
질문 세그먼트 숫자가 같을시 LED 깜박거리기댓글[1] 홍구 19-12-06 28
질문 MP3 모듈 질문있습니다.댓글[1] 초짜 19-12-06 19
MCU BASIC ⓒ 2019
