질문게시판 > 아두이노 색상인지센서(tcs3200) 질문
TODAY802 TOTAL1,140,450
BASIC4MCU | 질문게시판 | 아두이노 색상인지센서(tcs3200) 질문
작성자 master 작성일2018-11-04 08:18 조회1,243회 댓글0건
int s0 = 10;
int s1 = 11;
int s2 = 12;
int s3 = 13;
int out = 9;
int flag=0;
int vibration = 3;
byte counter=0;
byte countR = 0, countG = 0 , countB = 0;
 pinMode(s0,OUTPUT);
 pinMode(s1,OUTPUT);
 pinMode(s2,OUTPUT);
 pinMode(s3,OUTPUT);
 pinMode(vibration, OUTPUT);
void TCS()
 flag=0;
 digitalWrite(s1,HIGH);
 digitalWrite(s0,HIGH);
 digitalWrite(s2,LOW);
 digitalWrite(s3,LOW);
 attachInterrupt(0, ISR_INTO, CHANGE);
 timer0_init();
void ISR_INTO()
 counter++;
 void timer0_init(void)
 {TCCR2A=0x00;
  TCCR2B=0x07;   //the clock frequency source 1024 points
  TCNT2= 100;    //10 ms overflow again
  TIMSK2 = 0x01; //allow interrupt
 int i=0;
 ISR(TIMER2_OVF_vect)//the timer 2, 10ms interrupt overflow again. Internal overflow interrupt executive function
    TCNT2=100;
    flag++;
 if (flag == 1)
    countR = counter;
     Serial.print("red=");
    Serial.println(countR,DEC);
    digitalWrite(vibration, (countR > 5) ? HIGH : LOW) ;  //if countR is bigger than 120, HIGH, not LOW
    digitalWrite(s2, HIGH);
    digitalWrite(s3, HIGH);
    analogWrite(3, 100);
  else if (flag == 2)
    countG = counter;
     Serial.print("green=");
    Serial.println(countG,DEC);
    digitalWrite(vibration, (countG > 5) ? HIGH : LOW) ;
    digitalWrite(s2, LOW);
  else if (flag == 3)
    countB = counter;
    Serial.print("blue=");
    Serial.println(countB,DEC);
    digitalWrite(vibration, (countB > 5) ? HIGH : LOW) ;
    digitalWrite(s3, LOW);
    flag = 0 ;
  else if(flag==4)
     flag=0;
     counter = 0;
  TCS();
while(1);
색상인지센서(tcs3200)으로 노란색을 인지하여 진동모터가 울리게 할려고 하는데 색상인지센서를 처음   접하는 터라 노란색만 인지하게 하는 방법을 모르겠습니다ㅠㅠ
혹시 문제점이 있으면 알려주시면 감사하겠습니다!!!
FFFF00
R - 255
G - 255
B - 000
R, G, B 값을 모두 체크해야합니다.
// DateTime : 2018-09-22 오후 3:22:03
int s0=10,s1=11,s2=12,s3=13;
int out=9,vibration=3;
byte flag=2;
byte counter=0,countR=0,countG=0,countB=0;
void timer0_init(void){ //10 ms overflow
  TCCR2A=0x00TCCR2B=0x07TCNT2=100TIMSK2=0x01;
void TCS(){
  flag=0;
  digitalWrite(s0,HIGH); digitalWrite(s1,HIGH);
  digitalWrite(s2,LOW); digitalWrite(s3,HIGH); // 다음 측정 B
  attachInterrupt(0,ISR_INTO,CHANGE);
  timer0_init();
int i=0;
ISR(TIMER2_OVF_vect){ // 10ms
  TCNT2=100;
  if(flag==0){ // red
    countR=counter;
    Serial.print("red="); Serial.println(countR,DEC);
  //if(countR>64)digitalWrite(vibration,1);
  //else         digitalWrite(vibration,0);
    digitalWrite(s2,HIGH); digitalWrite(s3,HIGH); // 다음 측정 G
  else if(flag==1){ // green
    countG=counter;
    Serial.print("green="); Serial.println(countG,DEC);
    if((countR>64)&&(countG>64)&&(countB<20))digitalWrite(vibration,1);
  else// blue // if(flag==2)
    countB=counter;
    Serial.print("blue="); Serial.println(countB,DEC);
  //if(countB>64)digitalWrite(vibration,1);
    digitalWrite(s2,LOW); digitalWrite(s3,LOW); // 다음 측정 R
  if(++flag>2)flag=0;
  counter=0;
void ISR_INTO(){ counter++; } // 펄스 카운트
  Serial.begin(115200);
  pinMode(s0,OUTPUT); pinMode(s1,OUTPUT); pinMode(s2,OUTPUT); pinMode(s3,OUTPUT);
  pinMode(vibration,OUTPUT);
  analogWrite(3,100);
  TCS();
  while(1);
115200으로 통신 속도를 올렸습니다.
시리얼모니터 출력에서
노란색일 때의 R,G,B값을 잘 확인하고 체크하세요
조회수 1,243
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 1842
공지 사이트 이용 안내댓글[12] master 17-10-29 11709
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 4416
질문 소스 코딩 도와주세요 새글 bas213 01:45 8
답변 답변글 답변 : 소스 코딩 도와주세요 새글 master 06:15 6
질문 안녕하세요. 질문있습니다. 새글 dkendlsh 20-07-08 14
답변 답변글 답변 : 안녕하세요. 질문있습니다. 새글 master 20-07-08 10
질문 아두이노 nfc 센서와 pH센서 같이 연결댓글[1] 새글 알려주세요제발ㅠㅠ 20-07-08 16
질문 아두이노 초음파 센서, 부저, 스위치 합치기 도와주세요ㅜㅜ 이밍밍 20-07-05 35
질문 이 도어락 코드좀 이미지첨부파일 문준혁 20-07-05 41
질문 아두이노 입력전원댓글[2] 왕왕초a 20-07-02 50
질문 외부인터럽트가 발생했을때 ADC변환, 데이터 송신프로그램 질문입니다. 이소부 20-07-02 28
답변 답변글 답변 : 외부인터럽트가 발생했을때 ADC변환, 데이터 송신프로그램 질문입니다. master 20-07-02 34
질문 아두이노 마사지 키트 문의드립니다.댓글[3] 야아이양 20-07-02 35
질문 아두이노 공기청정기댓글[3] 행노비 20-07-02 50
질문 (아두이노)압력센서를 이용한 led on/off와 팬 작동댓글[1] 호조조 20-07-02 33
질문 아두이노 기체유량센서댓글[1] 최하림 20-07-01 31
질문 아두이노 pwm 제어 관련 질문드리고 싶습니다.댓글[4] 궁금스 20-07-01 66
질문 아두이노 합침 첨부파일 우경민 20-06-30 42
질문 소스 합쳐주세요 첨부파일 우경민 20-06-30 58
답변 답변글 답변 : 소스 합쳐주세요댓글[1] master 20-06-30 79
질문 소스코드 질문드립니다댓글[1] rqjiqwrji 20-06-30 72
질문 안녕하세요. 이런피아노 제작이 가능할까요?댓글[3] 애니멀티비 20-06-30 101
질문 서보모터+세그먼트+버튼 이용 오류 해결좀요..댓글[1] 이미지첨부파일 우편봉투 20-06-29 71
질문 소스코드 질문드립니다. mangham 20-06-29 52
답변 답변글 답변 : 소스코드 질문드립니다. master 20-06-29 50
답변 답변글 답변 : 답변 : 소스코드 질문드립니다. master 20-06-30 42
질문 라즈베리파이 블루투스댓글[1] 타조 20-06-28 66
질문 조도센서로 led, 서보모터, 스텝모터 제어하기 이미지첨부파일 tmxhathej 20-06-28 85
답변 답변글 답변 : 조도센서로 led, 서보모터, 스텝모터 제어하기 master 20-06-29 70
