질문게시판 > 아두이노 피아노 관련 문의 드립니다.
TODAY830 TOTAL506,477
BASIC4MCU | 질문게시판 | 아두이노 피아노 관련 문의 드립니다.
작성자 싼타공룡 작성일2018-11-21 19:41 조회254회 댓글0건
안녕하세요.
아두이노를 이용하여 식물or과일 연주기를 만들고 있습니다.
예전에 적외선 센서를 연결하여 센서를 터치하면 연주되는 피아노를 만들었어요.
이것을 적외선 센서를 제외하고
직접 식물에 연결하여 저항값으로 연주되는 피아노를 만들고 싶습니다.
어떻게 수정해야 할까요?
  2-12-2011
  Spark Fun Electronics 2011
  Nathan Seidle
  Updated to Arduino 1.01 by Marc "Trench" Tschudin
  This code is public domain but you buy me a beer if you use this and we meet someday (Beerware license).
  This code works with the VS1053 Breakout Board and controls the VS1053 in what is called Real Time MIDI mode.
  To get the VS1053 into RT MIDI mode, power up the VS1053 breakout board with GPIO0 tied low, GPIO1 tied high.
  I use the NewSoftSerial library to send out the MIDI serial at 31250bps. This allows me to print regular messages
  for debugging to the terminal window. This helped me out a ton.
  5V : VS1053 VCC
  GND : VS1053 GND
  D3 (SoftSerial TX) : VS1053 RX
  D4 : VS1053 RESET
  Attach a headphone breakout board to the VS1053:
  VS1053 LEFT : TSH
  VS1053 RIGHT : RSH
  VS1053 GBUF : GND
  When in the drum bank (0x78), there are not different instruments, only different notes.
  To play the different sounds, select an instrument # like 5, then play notes 27 to 87.
  To play "Sticks" (31):
  talkMIDI(0xB0, 0, 0x78); //Bank select: drums
  talkMIDI(0xC0, 5, 0); //Set instrument number
  //Play note on channel 1 (0x90), some note value (note), middle velocity (60):
  noteOn(0, 31, 60);
SoftwareSerial mySerial(2, 3); // RX, TX
byte note = 0; //The MIDI note value to be played
byte resetMIDI = 4; //Tied to VS1053 Reset line
byte ledPin = 13; //MIDI traffic inidicator
int  instrument = 9;  // 5,8,9:piano,11,12,18 36 :base drum,0:drum
//Send a MIDI note-on message.  Like pressing a piano key
//channel ranges from 0-15
void noteOn(byte channel, byte note, byte attack_velocity) {
  talkMIDI( (0x90 | channel), note, attack_velocity);
//Send a MIDI note-off message.  Like releasing a piano key
void noteOff(byte channel, byte note, byte release_velocity) {
  talkMIDI( (0x80 | channel), note, release_velocity);
//Plays a MIDI note. Doesn't check to see that cmd is greater than 127, or that data values are less than 127
void talkMIDI(byte cmd, byte data1, byte data2) {
  digitalWrite(ledPin, HIGH);
  mySerial.write(cmd);
  mySerial.write(data1);
  //Some commands only have one data byte. All cmds less than 0xBn have 2 data bytes
  //(sort of: http://253.ccarh.org/handout/midiprotocol/)
  if ( (cmd & 0xF0) <= 0xB0)
    mySerial.write(data2);
  digitalWrite(ledPin, LOW);
  Serial.begin(57600);
  //Setup soft serial for MIDI control
  mySerial.begin(31250);
  //Reset the VS1053
  pinMode(resetMIDI, OUTPUT);
  digitalWrite(resetMIDI, LOW);
  digitalWrite(resetMIDI, HIGH);
  talkMIDI(0xB0, 0x07, 127); //0xB0 is channel message, set channel volume to near max (127)
  for (int pin = 5; pin < 10; pin++) {
    pinMode(pin, INPUT); // IR
    delay(10);
  //Demo Basic MIDI instruments, GM1
  Serial.println("Basic Instruments");
  talkMIDI(0xB0, 0, 0x00); //Default bank GM1
  //Change to different instrument
  talkMIDI(0xC0, instrument, 0); //Set instrument number. 0xC0 is a 1 data byte command
  //Play notes from F#-0 (30) to F#-5 (90):
  if (analogRead(0) < 500)
    noteOn(0, 30, 60);//Note on channel 1 (0x90), some note value (note), middle velocity (0x45):
    delay(500);
  if (analogRead(1) < 500)
    noteOn(0, 31, 60);//Note on channel 1 (0x90), some note value (note), middle velocity (0x45):
    delay(500);
  if (analogRead(2) < 500)
    noteOn(0, 32, 60);//Note on channel 1 (0x90), some note value (note), middle velocity (0x45):
    delay(500);
  if (analogRead(3) < 500)
    noteOn(0, 33, 60);//Note on channel 1 (0x90), some note value (note), middle velocity (0x45):
    delay(500);
  if (analogRead(4) < 500)
    noteOn(0, 34, 60);//Note on channel 1 (0x90), some note value (note), middle velocity (0x45):
    delay(500);
  if (analogRead(5) < 500)
    noteOn(0, 35, 60);//Note on channel 1 (0x90), some note value (note), middle velocity (0x45):
    delay(500);
    noteOff(0, 32, 60);
조회수 254
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 329
공지 사이트 이용 안내댓글[7] master 17-10-29 6423
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 2504
질문 아두이노 질문댓글[1] 새글 리싸 10:30 8
질문 아두이노 알람시계 질문합니다!!댓글[3] 새글 쥬스 10:02 7
질문 블루투스 1대1 연결 질문입니다. 새글 hm02087 01:15 7
답변 답변글 답변 : 블루투스 1대1 연결 질문입니다. 새글 master 10:32 5
질문 마스터님 codevision에서 atmel studio로 변환 여쭤봅니다.댓글[1] 새글첨부파일 whwo0 19-05-24 7
질문 압력센서의 샘플링 값 응용에 관해 질문있습니다..댓글[1] 새글 매난국죽 19-05-24 11
질문 마그네틱 센서 질문드립니다. 새글 화무란 19-05-24 10
답변 답변글 답변 : 마그네틱 센서 질문드립니다. 새글 master 19-05-24 9
질문 master님 질문합니다!댓글[4] 새글 동스타 19-05-24 30
질문 아두이노 코드 합치는 것 질문이요!!!댓글[3] 새글 아야어여 19-05-24 24
질문 정수값을 블루투스로 읽기댓글[1] 새글 상오 19-05-24 13
질문 아두이노 레오나르도와 hc-06 블루투스 모듈 질문드립니다 새글 아야어여 19-05-24 12
답변 답변글 답변 : 아두이노 레오나르도와 hc-06 블루투스 모듈 질문드립니다 새글 master 19-05-24 13
질문 블루투스 코딩 문의댓글[2] 새글 후우우운 19-05-24 14
답변 답변글 답변 : 블루투스 코딩 문의댓글[3] 새글 master 19-05-24 23
질문 if문 중복이 안되나요? 소스좀 봐주세요 이미지새글첨부파일 지니아빠 19-05-24 9
답변 답변글 답변 : if문 중복이 안되나요? 소스좀 봐주세요댓글[3] 이미지새글 master 19-05-24 14
질문 스탑와치를 타이머 인터럽트로 구동시키려구 합니다 새글 master1 19-05-24 9
질문 아두이노 회로도 합치는방법을 모르겠어요 ㅠㅠ댓글[1] 새글 겨울비 19-05-24 12
질문 초음파와 금속센서 + 서보모터 (추가질문) 새글 아두이노초짜 19-05-23 8
답변 답변글 답변 : 초음파와 금속센서 + 서보모터 (추가질문) 새글 master 19-05-24 7
질문 초음파, 온도 센서를 이용해서 펌프 만들 때댓글[4] 새글 벡터스칼라 19-05-23 28
질문 ATMEGA128a 타이머와 부저 새글 동스타 19-05-23 20
답변 답변글 답변 : ATMEGA128a 타이머와 부저댓글[1] 새글 master 19-05-24 13
질문 atmega128a 디지털시계 문의드립니다 새글 아트메가잘하고싶다 19-05-23 32
답변 답변글 답변 : atmega128a 디지털시계 문의드립니다 새글 master 19-05-24 18
질문 마스터님께(창문소스코드 의문점) 새글 wait 19-05-23 13
