질문게시판 > 답변 : 아두이노 외부 인터럽트 loop문과 연동
TODAY5,877 TOTAL814,980
BASIC4MCU | 질문게시판 | 답변 : 아두이노 외부 인터럽트 loop문과 연동
작성자 master 작성일2018-10-03 00:07 조회701회 댓글0건
// DateTime : 2018-10-03 오전 12:11:30
#include <MD_TCS230.h>
#include <FreqCount.h>
#include <DFPlayer_Mini_Mp3.h>
#include "ColorMatch.h"
#define BLACK_CAL     0
#define WHITE_CAL     1
#define READ_VAL      2
#define LEARN_VAL     3
#define LEARN_MODE   'L'
#define MATCH_MODE   'M'
#define  S2_OUT       7
#define  S3_OUT       6
MD_TCS230 CS(S2_OUT,S3_OUT);
colorData rgb;
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10,11);
#define interruptPin1 3
uint8_t modeOp='M',ctIndex;
unsigned long time=0;
char runflag=1;
  Serial.begin(115200);
  mySerial.begin(9600);
  CS.begin();
  if(modeOp==MATCH_MODE){ CS.setDarkCal(&sdBlack); CS.setWhiteCal(&sdWhite); }
  mp3_set_serial(mySerial); delay(1); mp3_set_volume(15);
  pinMode(interruptPin1,INPUT);
  digitalWrite(interruptPin1,INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(interruptPin1),toggle,FALLING); // CHANGE
char getChar(){ while(Serial.available()==0); return(toupper(Serial.read())); }
void clearInput(){ while(Serial.read()!=-1); }
void toggle(){ runflag^=1; }
char *readASCII(uint8_t size){
  #define BUF_SIZE(9+1)
    static char s[BUF_SIZE]; uint8_t i=0char c;
    s[0]=0size--;
    while((i<size)&&(size<BUF_SIZE)){
      c=getChar(); if(c=='\n')breaks[i++]=cs[i]=0;
    clearInput();
    return(s);
  #undef BUF_SIZE
uint8_t fsmReadValue(uint8_t state,uint8_t valType){
  static uint8_t selChannel,readCount;
  static sensorData sd;
  switch(state){
    case 0:{ // 시작하기 위한 안내문을 보여줍니다:
      Serial.print(F("\n\n값을 읽는 중: "));
      switch(valType){
        case BLACK_CALSerial.print(("검정색 영점 조정")); break;
        case WHITE_CALSerial.print(("하얀색 영점 조정")); break;
        case READ_VAL:  Serial.print(("색 맞추기")); break;
        case LEARN_VALSerial.print(ct[ctIndex].name); break;
        default:        Serial.print(F("??")); break;
      clearInput();
      if(valType==LEARN_VAL){ char *p; }
      elseSerial.print(("\n시작하려면 어떤 키든 눌러주세요...")); clearInput(); }
      state++;
    case 1CS.read(); state++; break// 센서 값을 읽기 시작합니다
    case 2:{ // 값을 읽어 들일 때까지 기다립니다
      if(CS.available()){
        switch(valType){
          case BLACK_CALCS.getRaw(&sdBlack); CS.setDarkCal(&sdBlack);  break;
          case WHITE_CALCS.getRaw(&sdWhite); CS.setWhiteCal(&sdWhite); break;
          case READ_VAL:
          case LEARN_VAL:{
            CS.getRGB(&rgb);
            Serial.print(("\nRGB["));
            Serial.print(rgb.value[TCS230_RGB_R]); Serial.print((","));
            Serial.print(rgb.value[TCS230_RGB_G]); Serial.print((","));
            Serial.print(rgb.value[TCS230_RGB_B]); Serial.print(("]"));
        state++;
    defaultstate=0break// reset fsm
  return(state);
uint8_t colorMatch(colorData *rgb){
  int32_t d,v,minV=999999L;
  uint8_t minI;
  for(uint8_t i=0;i<ARRAY_SIZE(ct);i++){
    v=0;
    for(uint8_t j=0;j<RGB_SIZE;j++){ d=ct[i].rgb.value[j]-rgb->value[j]; v+=(d*d); }
    if(v<minV){ minV=vminI=i; }
    if(v==0)break;
  return(minI);
  static uint8_t runState=0,readState=0;
  if(runflag){
    switch(runState){
      case 0readState=fsmReadValue(readState,READ_VAL); if(readState==0)runState++; break// 색의 RGB 값을 읽어들입니다
      case 1:{ // 가까운 색을 찾아냅니다:
        uint8_t i=colorMatch(&rgb);
        Serial.print(("\n가장 가까운 색은 ")); Serial.print(ct[i].name); Serial.print(("입니다"));
        if     (!strcmp(ct[i].name,"빨간색")){ mp3_play(0); }
        else if(!strcmp(ct[i].name,"주황색")){ mp3_play(1); }
        else if(!strcmp(ct[i].name,"노란색")){ mp3_play(1); }
        else if(!strcmp(ct[i].name,"초록색")){ mp3_play(1); }
        else if(!strcmp(ct[i].name,"파란색")){ mp3_play(0); }
        else if(!strcmp(ct[i].name,"남색"  )){ mp3_play(1); }
        else if(!strcmp(ct[i].name,"보라색")){ mp3_play(1); }
        else if(!strcmp(ct[i].name,"검정색")){ mp3_play(0); }
        else if(!strcmp(ct[i].name,"하얀색")){ mp3_play(1); }
        else if(!strcmp(ct[i].name,"분홍색")){ mp3_play(1); }
        runState++;
        for(int i=0;i<100;i++){ delay(30); if(!runflag)break; }
      defaultrunState=0;
인터럽트 종류 변경
100ms 딜레이 제거
3000ms 딜레이를 for문으로 나눠서 실행하고
runflag=0 이면 딜레이 도중에 빠져나와서 응답시간을 빠르게 함
조회수 701
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 1002
공지 사이트 이용 안내댓글[10] master 17-10-29 8989
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 3406
질문 서보모터 질문 새글 알씨알씨 21:21 4
질문 서보모터 속도댓글[1] 새글 알씨알씨 18:27 8
질문 초기화 어떻게 하나요?댓글[1] 새글 끵끵끵 17:01 11
질문 미세먼지센서 GP2Y1023AU0F 코드 질문드립니다! 새글첨부파일 덕덕덕 15:57 8
질문 질문 하나만 더하겠습니다!! 새글 Leos 11:58 14
답변 답변글 답변 : 질문 하나만 더하겠습니다!! 새글 master 18:22 6
질문 아두이노 자동차 소스 작성중 어려움이 있어 질문 드립니다.댓글[1] 새글 쿤싼 02:10 12
질문 atmega 128에서 인터럽트가 적용이 되질 않습니다. 새글 메가콜라 19-12-14 9
답변 답변글 답변 : atmega 128에서 인터럽트가 적용이 되질 않습니다.댓글[1] 새글 master 19-12-14 13
질문 온도센서 질문입니다.댓글[1] 새글 오기 19-12-14 14
질문 ATMEGA128 노래 속도 새글 Leos 19-12-14 17
답변 답변글 답변 : ATMEGA128 노래 속도 새글 master 19-12-14 13
질문 초기화 어떻게 하나요?댓글[2] 새글 끵끵끵 19-12-14 16
답변 답변글 답변 : 초기화 어떻게 하나요? 새글 master 19-12-14 4
질문 서보모터 이용 자율주행 관련 질문 klohs 19-12-13 13
답변 답변글 답변 : 서보모터 이용 자율주행 관련 질문 master 19-12-13 12
질문 atmega128 / bldc모터 구동 질문입니다.댓글[1] 이미지첨부파일 조셉 19-12-13 18
질문 블루투스(HM-10) 비콘 관련 질문댓글[2] 으앙 19-12-12 17
질문 모터가 이상합니다.댓글[3] 첨부파일 이즈미 19-12-12 22
질문 아두이노 코딩 질문이요 나비힛 19-12-12 24
답변 답변글 답변 : 아두이노 코딩 질문이요 master 19-12-12 20
질문 앱인벤터에 값을 표기하는데 앞에 ( 가 붙는데 떼고 싶습니다. 이미지첨부파일 어려운AVR 19-12-11 11
답변 답변글 답변 : 앱인벤터에 값을 표기하는데 앞에 ( 가 붙는데 떼고 싶습니다.댓글[3] master 19-12-11 16
질문 아두이노 스텝모터 멈추기댓글[1] 이즈미 19-12-11 23
질문 avr atmega128 숫자야구게임댓글[1] 첨부파일 주냥몬 19-12-11 35
질문 블루투스 값이 변조가 됩니다댓글[3] 이미지첨부파일 어려운AVR 19-12-11 22
MCU BASIC ⓒ 2019
