질문게시판 > C8051F060을 이용한 DAC
TODAY1,078 TOTAL434,288
BASIC4MCU | 질문게시판 | C8051F060을 이용한 DAC
작성자 민8959 작성일2018-04-16 10:55 조회919회 댓글0건
안녕하세요, 안녕하세요, 현재 silabotory의 8051을 프로그래밍하여 컨트롤하는 공부를 하고 있는 학생입니다.
현재 silab 사의 C8051의 DAC를 이용하여 아날로그 신호가 나오는 것을 확인하는 과정에 있습니다.
밑의 코드는 silab에서 지원하는 example 코드 입니다.
#include <c8051f060.h>                 // SFR declarations
// 16-bit SFR Definitions for 'F06x
sfr16 RCAP4    = 0xCA;                 // Timer4 capture/reload
sfr16 TMR4     = 0xCC;                 // Timer4
sfr16 DAC0     = 0xD2;                 // DAC0 data
sfr16 DAC1     = 0xD2;                 // DAC1 data
// Global Constants
#define SYSCLK       24500000          // Internal oscillator frequency in Hz
#define SAMPLE_RATE_DAC 100000L        // DAC sampling rate in Hz
#define PHASE_PRECISION 65536          // range of phase accumulator
#define FREQUENCY 1000                 // Frequency of output waveform in Hz
// <PHASE_ADD> is the change in phase between DAC samples; It is used in
// the set_DACs routine.
unsigned int PHASE_ADD = FREQUENCY * PHASE_PRECISION / SAMPLE_RATE_DAC;
int code SINE_TABLE[256] = {
   0x0000, 0x0324, 0x0647, 0x096a, 0x0c8b, 0x0fab, 0x12c8, 0x15e2,
   0x18f8, 0x1c0b, 0x1f19, 0x2223, 0x2528, 0x2826, 0x2b1f, 0x2e11,
   0x30fb, 0x33de, 0x36ba, 0x398c, 0x3c56, 0x3f17, 0x41ce, 0x447a,
   0x471c, 0x49b4, 0x4c3f, 0x4ebf, 0x5133, 0x539b, 0x55f5, 0x5842,
   0x5a82, 0x5cb4, 0x5ed7, 0x60ec, 0x62f2, 0x64e8, 0x66cf, 0x68a6,
   0x6a6d, 0x6c24, 0x6dca, 0x6f5f, 0x70e2, 0x7255, 0x73b5, 0x7504,
   0x7641, 0x776c, 0x7884, 0x798a, 0x7a7d, 0x7b5d, 0x7c29, 0x7ce3,
   0x7d8a, 0x7e1d, 0x7e9d, 0x7f09, 0x7f62, 0x7fa7, 0x7fd8, 0x7ff6,
   0x7fff, 0x7ff6, 0x7fd8, 0x7fa7, 0x7f62, 0x7f09, 0x7e9d, 0x7e1d,
   0x7d8a, 0x7ce3, 0x7c29, 0x7b5d, 0x7a7d, 0x798a, 0x7884, 0x776c,
   0x7641, 0x7504, 0x73b5, 0x7255, 0x70e2, 0x6f5f, 0x6dca, 0x6c24,
   0x6a6d, 0x68a6, 0x66cf, 0x64e8, 0x62f2, 0x60ec, 0x5ed7, 0x5cb4,
   0x5a82, 0x5842, 0x55f5, 0x539b, 0x5133, 0x4ebf, 0x4c3f, 0x49b4,
   0x471c, 0x447a, 0x41ce, 0x3f17, 0x3c56, 0x398c, 0x36ba, 0x33de,
   0x30fb, 0x2e11, 0x2b1f, 0x2826, 0x2528, 0x2223, 0x1f19, 0x1c0b,
   0x18f8, 0x15e2, 0x12c8, 0x0fab, 0x0c8b, 0x096a, 0x0647, 0x0324,
   0x0000, 0xfcdc, 0xf9b9, 0xf696, 0xf375, 0xf055, 0xed38, 0xea1e,
   0xe708, 0xe3f5, 0xe0e7, 0xdddd, 0xdad8, 0xd7da, 0xd4e1, 0xd1ef,
   0xcf05, 0xcc22, 0xc946, 0xc674, 0xc3aa, 0xc0e9, 0xbe32, 0xbb86,
   0xb8e4, 0xb64c, 0xb3c1, 0xb141, 0xaecd, 0xac65, 0xaa0b, 0xa7be,
   0xa57e, 0xa34c, 0xa129, 0x9f14, 0x9d0e, 0x9b18, 0x9931, 0x975a,
   0x9593, 0x93dc, 0x9236, 0x90a1, 0x8f1e, 0x8dab, 0x8c4b, 0x8afc,
   0x89bf, 0x8894, 0x877c, 0x8676, 0x8583, 0x84a3, 0x83d7, 0x831d,
   0x8276, 0x81e3, 0x8163, 0x80f7, 0x809e, 0x8059, 0x8028, 0x800a,
   0x8000, 0x800a, 0x8028, 0x8059, 0x809e, 0x80f7, 0x8163, 0x81e3,
   0x8276, 0x831d, 0x83d7, 0x84a3, 0x8583, 0x8676, 0x877c, 0x8894,
   0x89bf, 0x8afc, 0x8c4b, 0x8dab, 0x8f1e, 0x90a1, 0x9236, 0x93dc,
   0x9593, 0x975a, 0x9931, 0x9b18, 0x9d0e, 0x9f14, 0xa129, 0xa34c,
   0xa57e, 0xa7be, 0xaa0b, 0xac65, 0xaecd, 0xb141, 0xb3c1, 0xb64c,
   0xb8e4, 0xbb86, 0xbe32, 0xc0e9, 0xc3aa, 0xc674, 0xc946, 0xcc22,
   0xcf05, 0xd1ef, 0xd4e1, 0xd7da, 0xdad8, 0xdddd, 0xe0e7, 0xe3f5,
   0xe708, 0xea1e, 0xed38, 0xf055, 0xf375, 0xf696, 0xf9b9, 0xfcdc,
// Function Prototypes
void main(void);
void OSCILLATOR_Init(void);
void DAC0_Init (void);
void DAC1_Init (void);
void TIMER4_Init(int counts);
void Set_DACs(void);
// MAIN Routine
void main (void)
   WDTCN = 0xde;                       // Disable watchdog timer
   WDTCN = 0xad;
   OSCILLATOR_Init ();                 // Initialize oscillator
   DAC0_Init ();                       // Initialize DAC0
   DAC1_Init ();                       // Initialize DAC1
   TIMER4_Init(SYSCLK/SAMPLE_RATE_DAC);// Initialize Timer4 to overflow
                                       // <SAMPLE_RATE_DAC> times per
                                       // second
   EA = 1;                             // Enable global interrupts
   while(1);
// Interrupt Service Routines
// TIMER4_ISR -- Wave Generator
// This ISR is called on Timer4 overflows.  Timer4 is set to auto-reload mode
// and is used to schedule the DAC output sample rate in this example.
// Note that the value that is written to DAC1 during this ISR call is
// actually transferred to DAC1 at the next Timer4 overflow.
void TIMER4_ISR (void) interrupt 16
   TF4 = 0;                            // Clear Timer4 overflow flag
   Set_DACs();
// Initialization Routines
// OSCILLATOR_Init
// Return Value : None
// Parameters   : None
// This function initializes the system clock to use the internal oscillator
// at 24.5
void OSCILLATOR_Init (void)
   char SFRPAGE_SAVE = SFRPAGE;        // Save Current SFR page
   SFRPAGE = CONFIG_PAGE;              // set SFR page
   OSCICN |= 0x03;                     // Set internal oscillator to run
                                       // at its maximum frequency
   SFRPAGE = SFRPAGE_SAVE;             // Restore SFR page
// DAC0_Init
// Configure DAC0 to update on Timer4 overflows and enable the the VREF buffer.
void DAC0_Init(void)
   SFRPAGE = DAC0_PAGE;
   DAC0CN = 0x94;                      // Enable DAC0 in left-justified mode
                                       // managed by Timer4 overflows
   SFRPAGE = ADC2_PAGE;
   REF2CN |= 0x03;                     // Enable the internal VREF (2.4v) and
                                       // the Bias Generator
// DAC1_Init
// Configure DAC1 to update on Timer4 overflows and enable the the VREF buffer.
void DAC1_Init(void)
   SFRPAGE = DAC1_PAGE;
   DAC1CN = 0x94;                      // Enable DAC1 in left-justified mode
// TIMER4_Init
// Parameters   :
//   1)  int counts - calculated Timer overflow rate
//                    range is positive range of integer: 0 to 32767
// Configure Timer4 to auto-reload at interval specified by <counts> using
// SYSCLK as its time base.
void TIMER4_Init (int counts)
   SFRPAGE = TMR4_PAGE;
   TMR4CN = 0x00;                      // Stop Timer4; Clear overflow flag (TF4);
                                       // Set to Auto-Reload Mode
   TMR4CF = 0x08;                      // Configure Timer4 to increment;
                                       // Timer4 counts SYSCLKs
   RCAP4 = -counts;                    // Set reload value
   TMR4 = RCAP4;                       // Initialzie Timer4 to reload value
   EIE2 |= 0x04;                       // Enable Timer4 interrupts
   TMR4CN |= 0x04;                     // Start Timer4
// Set_DACs
// Calculates the update values for the two DACs using SINE_TABLE.  The DACs
// will actually be updated upon the next Timer4 interrupt.  Until that time,
// the DACs will hold their current value.
void Set_DACs(void)
   static unsigned phase_acc = 0;      // Holds phase accumulator
   int SIN_temp, COS_temp;             // Temporary 16-bit variables
   unsigned char index;                // Index into SINE table
   phase_acc += PHASE_ADD;             // Increment phase accumulator
   index = phase_acc >> 8;
   SIN_temp = SINE_TABLE[index];       // Read the table value
   index += 64;                        // 90 degree phase shift
   COS_temp = SINE_TABLE[index];
   // Add a DC bias to change the the rails from a bipolar (-32768 to 32767)
   // to unipolar (0 to 65535)
   // Note: the XOR with 0x8000 translates the bipolar quantity into
   // a unipolar quantity.
   DAC0 = 0x8000 ^ SIN_temp;           // Write to DAC0
   //DAC0L;
   //DAC0H;
 //  SFRPAGE = DAC1_PAGE;
   //DAC1 = 0x8000 ^ COS_temp;           // Write to DAC1
이 소스를 mcu에 업로드를 했는데, mcu의 DAC0와 DAC1핀에서 사인파를 전혀 확인할 수 없었습니다..
실행 중지를 반복할 때마다 DAC SFR에 값이 변경되는 것도 확인했고, mcu에서 VREF 전압도 2.45 볼트 나오는 것을 확인했는데, DAC0와 DAC1에서 사인파를 확인할 수가 없었습니다..
핀으로 사인파가 나오는 것을 확인하기 위해 추가적으로 코드를 작성해야 하느 부분이 있는걸까요?
8051 계열 잘 아시는 분들 도와주시면 감사하겠습니다..
그림 파일은 C8051의 pin-configuration 입니다.
C8051F060
조회수 919
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 134
공지 사이트 이용 안내 댓글[5] master 17-10-29 5154
질문 아두이노 카메라 캡처 댓글[1] 새글 아두이노배우기 13:20 10
질문 아두이노 DC전원 2배 키우는 방법 댓글[1] 이미지새글첨부파일 4004 09:30 13
질문 아두이노 우노 모터 관련 질문 2 댓글[1] 이미지새글첨부파일 가든 19-03-21 13
질문 아두이노 LCD 질문입니다 댓글[2] 새글 Winavr 19-03-21 21
질문 아두이노메가 -> 아두이노우노 통신 질문입니다! 새글첨부파일 궈니 19-03-20 14
답변 답변글 답변 : 아두이노메가 -> 아두이노우노 통신 질문입니다! 새글 master 19-03-21 12
질문 아두이노 우노 모터 관련 질문 새글 가든 19-03-20 15
답변 답변글 답변 : 아두이노 우노 모터 관련 질문 새글 master 19-03-21 14
질문 DC 전압을 2배로 키울 수 있는 회로가 있나요? 새글 4004 19-03-20 8
답변 답변글 답변 : DC 전압을 2배로 키울 수 있는 회로가 있나요? 새글 master 19-03-21 7
답변 답변글 답변 : 답변 : DC 전압을 2배로 키울 수 있는 회로가 있나요? 댓글[1] 새글 4004 09:24 9
답변 답변글 답변 : 답변 : 답변 : DC 전압을 2배로 키울 수 있는 회로가 있나요? 새글 master 11:04 4
질문 stm32칩 공부 관련 질문 댓글[4] wiopf1 19-03-19 33
질문 AVR STUDIO 4.19 & AVRISP MKII USB 댓글[1] 오박사 19-03-18 30
질문 예제 코드 구합니다 댓글[1] 첨부파일 오박사 19-03-18 29
질문 마스터님! 고생하십니다! 인터럽트 질문좀 드리겠습니다. 닷모드 19-03-18 17
답변 답변글 답변 : 마스터님! 고생하십니다! 인터럽트 질문좀 드리겠습니다. master 19-03-19 19
질문 시리얼 통신 키보드 질문드립니다. 댓글[1] 이이제이 19-03-18 22
질문 스텝모터 제어 역방향 회전시 힘이 약하게 돌아가는 현상 궁금합니다 19-03-16 21
답변 답변글 답변 : 스텝모터 제어 역방향 회전시 힘이 약하게 돌아가는 현상 댓글[2] master 19-03-16 34
질문 아두이노시리얼 0xff가 available 사용해도 계속 뜨네요ㅠㅠ yangty01 19-03-16 15
답변 답변글 답변 : 아두이노시리얼 0xff가 available 사용해도 계속 뜨네요ㅠㅠ master 19-03-16 15
질문 atmega128 Switch를 이용한 FND제어 질문 master 19-03-16 14
질문 아두이노 시리얼통신 질문합니다. 댓글[3] 이이제이 19-03-16 35
질문 ATmega128에 대해서... 댓글[2] YDyd 19-03-15 33
질문 프로세싱 RFID 태그시 색변화.. 댓글[1] ksyh2030 19-03-14 28
질문 avr i2c eeprom 코드관련해서요 댓글[1] 이미지첨부파일 남이 19-03-14 26
질문 avr에 대해서... 댓글[3] YDyd 19-03-14 43
