질문게시판 > 답변 : C8051F060을 이용한 DAC
TODAY1,072 TOTAL434,282
BASIC4MCU | 질문게시판 | 답변 : C8051F060을 이용한 DAC
작성자 master 작성일2018-04-16 12:44 조회818회 댓글2건
// DateTime : 2018-04-16 오후 12:36:45
#include <c8051f060.h>// SFR declarations
// 16-bit SFR Definitions for 'F06x
sfr16 RCAP4=0xCA// Timer4 capture/reload
sfr16 TMR4=0xCC;  // Timer4
sfr16 DAC0=0xD2;  // DAC0 data
sfr16 DAC1=0xD2;  // DAC1 data
// Global Constants
#define SYSCLK          24500000 // Internal oscillator frequency in Hz
#define SAMPLE_RATE_DAC 100000L  // DAC sampling rate in Hz
#define PHASE_PRECISION 65536    // range of phase accumulator
#define FREQUENCY       1000     // Frequency of output waveform in Hz
//<PHASE_ADD>is the change in phase between DAC samples; It is used in
// the set_DACs routine.
unsigned int PHASE_ADD=FREQUENCY*PHASE_PRECISION/SAMPLE_RATE_DAC;
int code SINE_TABLE[256]={
  0x0000,0x0324,0x0647,0x096a,0x0c8b,0x0fab,0x12c8,0x15e2,
  0x18f8,0x1c0b,0x1f19,0x2223,0x2528,0x2826,0x2b1f,0x2e11,
  0x30fb,0x33de,0x36ba,0x398c,0x3c56,0x3f17,0x41ce,0x447a,
  0x471c,0x49b4,0x4c3f,0x4ebf,0x5133,0x539b,0x55f5,0x5842,
  0x5a82,0x5cb4,0x5ed7,0x60ec,0x62f2,0x64e8,0x66cf,0x68a6,
  0x6a6d,0x6c24,0x6dca,0x6f5f,0x70e2,0x7255,0x73b5,0x7504,
  0x7641,0x776c,0x7884,0x798a,0x7a7d,0x7b5d,0x7c29,0x7ce3,
  0x7d8a,0x7e1d,0x7e9d,0x7f09,0x7f62,0x7fa7,0x7fd8,0x7ff6,
  0x7fff,0x7ff6,0x7fd8,0x7fa7,0x7f62,0x7f09,0x7e9d,0x7e1d,
  0x7d8a,0x7ce3,0x7c29,0x7b5d,0x7a7d,0x798a,0x7884,0x776c,
  0x7641,0x7504,0x73b5,0x7255,0x70e2,0x6f5f,0x6dca,0x6c24,
  0x6a6d,0x68a6,0x66cf,0x64e8,0x62f2,0x60ec,0x5ed7,0x5cb4,
  0x5a82,0x5842,0x55f5,0x539b,0x5133,0x4ebf,0x4c3f,0x49b4,
  0x471c,0x447a,0x41ce,0x3f17,0x3c56,0x398c,0x36ba,0x33de,
  0x30fb,0x2e11,0x2b1f,0x2826,0x2528,0x2223,0x1f19,0x1c0b,
  0x18f8,0x15e2,0x12c8,0x0fab,0x0c8b,0x096a,0x0647,0x0324,
  0x0000,0xfcdc,0xf9b9,0xf696,0xf375,0xf055,0xed38,0xea1e,
  0xe708,0xe3f5,0xe0e7,0xdddd,0xdad8,0xd7da,0xd4e1,0xd1ef,
  0xcf05,0xcc22,0xc946,0xc674,0xc3aa,0xc0e9,0xbe32,0xbb86,
  0xb8e4,0xb64c,0xb3c1,0xb141,0xaecd,0xac65,0xaa0b,0xa7be,
  0xa57e,0xa34c,0xa129,0x9f14,0x9d0e,0x9b18,0x9931,0x975a,
  0x9593,0x93dc,0x9236,0x90a1,0x8f1e,0x8dab,0x8c4b,0x8afc,
  0x89bf,0x8894,0x877c,0x8676,0x8583,0x84a3,0x83d7,0x831d,
  0x8276,0x81e3,0x8163,0x80f7,0x809e,0x8059,0x8028,0x800a,
  0x8000,0x800a,0x8028,0x8059,0x809e,0x80f7,0x8163,0x81e3,
  0x8276,0x831d,0x83d7,0x84a3,0x8583,0x8676,0x877c,0x8894,
  0x89bf,0x8afc,0x8c4b,0x8dab,0x8f1e,0x90a1,0x9236,0x93dc,
  0x9593,0x975a,0x9931,0x9b18,0x9d0e,0x9f14,0xa129,0xa34c,
  0xa57e,0xa7be,0xaa0b,0xac65,0xaecd,0xb141,0xb3c1,0xb64c,
  0xb8e4,0xbb86,0xbe32,0xc0e9,0xc3aa,0xc674,0xc946,0xcc22,
  0xcf05,0xd1ef,0xd4e1,0xd7da,0xdad8,0xdddd,0xe0e7,0xe3f5,
  0xe708,0xea1e,0xed38,0xf055,0xf375,0xf696,0xf9b9,0xfcdc,
// Set_DACs
// Calculates the update values for the two DACs using SINE_TABLE.The DACs
// will actually be updated upon the next Timer4 interrupt.Until that time,
// the DACs will hold their current value.
void Set_DACs(void){
  char SFRPAGE_SAVE=SFRPAGE;   // Save Current SFR page
  static unsigned phase_acc=0// Holds phase accumulator
  int SIN_temp,COS_temp;       // Temporary 16-bit variables
  unsigned char index;         // Index into SINE table
  phase_acc+=PHASE_ADD;        // Increment phase accumulator
  index=phase_acc>>8;
  SIN_temp=SINE_TABLE[index];  // Read the table value
  index+=64;                   // 90 degree phase shift
  COS_temp=SINE_TABLE[index];
  // Add a DC bias to change the the rails from a bipolar(-32768 to 32767)to unipolar(0 to 65535)
  // Note: the XOR with 0x8000 translates the bipolar quantity into a unipolar quantity.
  SFRPAGE=DAC0_PAGE;
  DAC0=0x8000^SIN_temp;    // Write to DAC0 //DAC0L; DAC0H; SFRPAGE=DAC1_PAGE; //DAC1=0x8000^COS_temp;  // Write to DAC1
  SFRPAGE=SFRPAGE_SAVE;    // Restore SFR page
// Interrupt Service Routines
// TIMER4_ISR--Wave Generator
// This ISR is called on Timer4 overflows.Timer4 is set to auto-reload mode
// and is used to schedule the DAC output sample rate in this example.
// Note that the value that is written to DAC1 during this ISR call is
// actually transferred to DAC1 at the next Timer4 overflow.
void TIMER4_ISR(void)interrupt 16{
  TF4=0;       // Clear Timer4 overflow flag
  Set_DACs();
// Initialization Routines
// OSCILLATOR_Init
// Return Value: None
// Parameters: None
// This function initializes the system clock to use the internal oscillator
// at 24.5
void OSCILLATOR_Init(void){
  char SFRPAGE_SAVE=SFRPAGE// Save Current SFR page
  SFRPAGE=CONFIG_PAGE;       // set SFR page
  OSCICN|=0x03;              // Set internal oscillator to run at its maximum frequency
// DAC0_Init
// Configure DAC0 to update on Timer4 overflows and enable the the VREF buffer.
void DAC0_Init(void){
  SFRPAGE=DAC0_PAGE;
  DAC0CN=0x94;                // Enable DAC0 in left-justified mode managed by Timer4 overflows
  SFRPAGE=ADC2_PAGE;
  REF2CN|=0x03;               // Enable the internal VREF(2.4v)and the Bias Generator
// DAC1_Init
// Configure DAC1 to update on Timer4 overflows and enable the the VREF buffer.
void DAC1_Init(void){
  SFRPAGE=DAC1_PAGE;
  DAC1CN=0x94;                // Enable DAC1 in left-justified mode managed by Timer4 overflows
  SFRPAGE=ADC2_PAGE;
// TIMER4_Init
// Parameters:
//   1)int counts-calculated Timer overflow rate range is positive range of integer: 0 to 32767
// Configure Timer4 to auto-reload at interval specified by<counts>using SYSCLK as its time base.
void TIMER4_Init(int counts){
  SFRPAGE=TMR4_PAGE;
  TMR4CN=0x00;                // Stop Timer4; Clear overflow flag(TF4); Set to Auto-Reload Mode
  TMR4CF=0x08;                // Configure Timer4 to increment; Timer4 counts SYSCLKs
  RCAP4=-counts;              // Set reload value
  TMR4=RCAP4;                 // Initialzie Timer4 to reload value
  EIE2|=0x04;                 // Enable Timer4 interrupts
  TMR4CN|=0x04;               // Start Timer4
// MAIN Routine
void main(void){
  WDTCN=0xdeWDTCN=0xad;              // Disable watchdog timer
  OSCILLATOR_Init();                   // Initialize oscillator
  DAC0_Init();                         // Initialize DAC0
  DAC1_Init();                         // Initialize DAC1
  TIMER4_Init(SYSCLK/SAMPLE_RATE_DAC); // Initialize Timer4 to overflow<SAMPLE_RATE_DAC>times per second
  EA=1;                                // Enable global interrupts
  while(1);
  Set_DACs();
  LED 토글
타이머 인터럽트 에서 LED 토글 시키면
타이머 인터럽트가 실행 되는지 여부와
타이머 인터럽트 주기를 알 수 있습니다.
Set_DACs()
이 함수에서 DAC출력하는 부분은
  SFRPAGE=DAC0_PAGE;
 제일 마지막에 있습니다.
void main(void){
  int a,b;
  //EA=1;          // Enable global interrupts
    SFRPAGE=DAC0_PAGE; DAC0=0x3FFF; SFRPAGE=SFRPAGE_SAVE;
    for(a=1;a<1000;a++)for(b=1;b<1000;b++);
    SFRPAGE=DAC0_PAGE; DAC0=0x0000; SFRPAGE=SFRPAGE_SAVE;
인터럽트 금지시키고
딜레이로 DAC 출력해봐도 되겠죠
조회수 818
민8959님의 댓글
민8959 작성일
빠른 답변 감사합니다.
조언해주신 내용을 바탕으로 디버깅을 해보았는데요.
LED토글로 타이머가 인터럽트가 동작하는것을 확인했고, 인터럽트를 중지시키고 대신 작성해주신 코드를 첨가해서 실행해보아도 DAC 출력이 나오질 않습니다. 타이머도 동작하고 매 인터럽트 발생 시 DAC에 bit를 입력해주는 SFR의 값도 바뀌는 것을 확인했는데 출력이 왜나오지 않는지 정말 의문이네요.
칩이 고장난 걸까요?
여기서는 DAC0으로 출력하고 있는데요
DAC1로 출력해보세요
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 134
공지 사이트 이용 안내 댓글[5] master 17-10-29 5154
질문 아두이노 카메라 캡처 댓글[1] 새글 아두이노배우기 13:20 10
질문 아두이노 DC전원 2배 키우는 방법 댓글[1] 이미지새글첨부파일 4004 09:30 13
질문 아두이노 우노 모터 관련 질문 2 댓글[1] 이미지새글첨부파일 가든 19-03-21 13
질문 아두이노 LCD 질문입니다 댓글[2] 새글 Winavr 19-03-21 21
질문 아두이노메가 -> 아두이노우노 통신 질문입니다! 새글첨부파일 궈니 19-03-20 14
답변 답변글 답변 : 아두이노메가 -> 아두이노우노 통신 질문입니다! 새글 master 19-03-21 12
질문 아두이노 우노 모터 관련 질문 새글 가든 19-03-20 15
답변 답변글 답변 : 아두이노 우노 모터 관련 질문 새글 master 19-03-21 14
질문 DC 전압을 2배로 키울 수 있는 회로가 있나요? 새글 4004 19-03-20 8
답변 답변글 답변 : DC 전압을 2배로 키울 수 있는 회로가 있나요? 새글 master 19-03-21 7
답변 답변글 답변 : 답변 : DC 전압을 2배로 키울 수 있는 회로가 있나요? 댓글[1] 새글 4004 09:24 9
답변 답변글 답변 : 답변 : 답변 : DC 전압을 2배로 키울 수 있는 회로가 있나요? 새글 master 11:04 4
질문 stm32칩 공부 관련 질문 댓글[4] wiopf1 19-03-19 33
질문 AVR STUDIO 4.19 & AVRISP MKII USB 댓글[1] 오박사 19-03-18 30
질문 예제 코드 구합니다 댓글[1] 첨부파일 오박사 19-03-18 29
질문 마스터님! 고생하십니다! 인터럽트 질문좀 드리겠습니다. 닷모드 19-03-18 17
답변 답변글 답변 : 마스터님! 고생하십니다! 인터럽트 질문좀 드리겠습니다. master 19-03-19 19
질문 시리얼 통신 키보드 질문드립니다. 댓글[1] 이이제이 19-03-18 22
질문 스텝모터 제어 역방향 회전시 힘이 약하게 돌아가는 현상 궁금합니다 19-03-16 21
답변 답변글 답변 : 스텝모터 제어 역방향 회전시 힘이 약하게 돌아가는 현상 댓글[2] master 19-03-16 34
질문 아두이노시리얼 0xff가 available 사용해도 계속 뜨네요ㅠㅠ yangty01 19-03-16 15
답변 답변글 답변 : 아두이노시리얼 0xff가 available 사용해도 계속 뜨네요ㅠㅠ master 19-03-16 15
질문 atmega128 Switch를 이용한 FND제어 질문 master 19-03-16 14
질문 아두이노 시리얼통신 질문합니다. 댓글[3] 이이제이 19-03-16 35
질문 ATmega128에 대해서... 댓글[2] YDyd 19-03-15 32
질문 프로세싱 RFID 태그시 색변화.. 댓글[1] ksyh2030 19-03-14 28
질문 avr i2c eeprom 코드관련해서요 댓글[1] 이미지첨부파일 남이 19-03-14 26
질문 avr에 대해서... 댓글[3] YDyd 19-03-14 43
