질문게시판 > 답변 : HC-06 text Data를 입력으로 사용하는 코드 질문입니다.
TODAY4,378 TOTAL819,836
BASIC4MCU | 질문게시판 | 답변 : HC-06 text Data를 입력으로 사용하는 코드 질문입니다.
작성자 master 작성일2018-10-31 00:50 조회657회 댓글0건
// DateTime : 2018-10-31 오전 12:55:30
#include <SoftwareSerial.h>
SoftwareSerial BTserial(10,11); // 10--HC-06 TX // 11--HC-06 RX
#include <Adafruit_GFX.h>
#include <RGBmatrixPanel.h>
#define F2(progmem_ptr)  (const __FlashStringHelper*)progmem_ptr
#define CLK   8          // MUST be on PORTB!(Use pin 11 on Mega)
#define LAT   A3
#define OE    9
#define A     A0
#define B     A1
#define C     A2
RGBmatrixPanel matrix(A,B,C,CLK,LAT,OE,true);
char   rxCnt=0,str1[50];
char   str[]PROGMEM="Welcome to DFrobot 32x16 RGB LED Matrix";
int    textX=matrix.width(),textMin=sizeof(str)*-12,hue=0;
int8_t ball[3][4]={
  { 3011}, // Initial X,Y pos&velocity for 3 bouncy balls
  {17,151,-1},
  {274,-11}
static const uint16_t PROGMEM ballcolor[3]={
  0x0080,// Green=1
  0x0002,// Blue=1
  0x1000 // Red=1
  matrix.begin();
  matrix.setTextWrap(false); // Allow text to run off right edge
  matrix.setTextSize(2);
  Serial.begin(9600); Serial.println("Enter AT commands: ");
  BTserial.begin(9600);
  byte i;
  matrix.fillScreen(0); // Clear background
  for(i=0;i<3;i++){                                                          // Bounce three balls around
    matrix.fillCircle(ball[i][0],ball[i][1],5,pgm_read_word(&ballcolor[i])); // Draw 'ball'
    ball[i][0]+=ball[i][2];                                                  // Update X,Y position
    ball[i][1]+=ball[i][3];
    if((ball[i][0]==0)||(ball[i][0]==(matrix.width()-1)))ball[i][2]*=-1// Bounce off edges
    if((ball[i][1]==0)||(ball[i][1]==(matrix.height()-1)))ball[i][3]*=-1;
  matrix.setTextColor(matrix.ColorHSV(hue,255,255,true)); // Draw big scrolly text on top
  matrix.setCursor(textX,1);
  matrix.print(F2(str));
  if((--textX)<textMin)textX=matrix.width();              // Move text left(w/wrap),increase hue
  hue+=7if(hue>=1536)hue-=1536;
  matrix.swapBuffers(false);                              // Update display
  if(BTserial.available()){
    char r=BTserial.read();
    Serial.write(r);
    str1[rxCnt++]=rstr1[rxCnt]=0;
    if(r=='\n'){ // 문자열 입력 완료
      rxCnt=0;
      memcpy(str,str1,strlen(str1));
      textMin=sizeof(str)*-12;
  if(Serial.available()){
    BTserial.write(Serial.read());
잘 될런지 모르겠습니다.
잘 안되면 공부해서 만드셔야합니다.
조회수 657
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 1009
공지 사이트 이용 안내댓글[10] master 17-10-29 9002
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 3414
질문 앱인벤터이용해서 세그먼트사용하기댓글[2] 새글 bas213 20:08 4
질문 센서 질문입니다 새글 오기 16:54 4
답변 답변글 답변 : 센서 질문입니다 새글 master 20:03 3
질문 AT mega128 글리치 제거관련 질문입니다.댓글[1] 새글 스아레즈 15:24 5
질문 아두이노 코딩합치기질문입니다. 새글 항정통 10:39 8
답변 답변글 답변 : 아두이노 코딩합치기질문입니다. 새글 master 12:05 4
질문 아두이노 MPU6050과 LED를 이용한 밝기조절댓글[3] 이미지새글첨부파일 초보아두 03:26 12
질문 서보모터 질문 새글 알씨알씨 19-12-15 9
질문 서보모터 속도댓글[1] 새글 알씨알씨 19-12-15 12
질문 초기화 어떻게 하나요?댓글[1] 새글 끵끵끵 19-12-15 15
질문 미세먼지센서 GP2Y1023AU0F 코드 질문드립니다! 새글첨부파일 덕덕덕 19-12-15 13
질문 질문 하나만 더하겠습니다!! 새글 Leos 19-12-15 15
답변 답변글 답변 : 질문 하나만 더하겠습니다!! 새글 master 19-12-15 8
질문 아두이노 자동차 소스 작성중 어려움이 있어 질문 드립니다.댓글[1] 새글 쿤싼 19-12-15 18
질문 atmega 128에서 인터럽트가 적용이 되질 않습니다. 새글 메가콜라 19-12-14 10
답변 답변글 답변 : atmega 128에서 인터럽트가 적용이 되질 않습니다.댓글[1] 새글 master 19-12-14 16
질문 온도센서 질문입니다.댓글[1] 오기 19-12-14 18
질문 ATMEGA128 노래 속도 Leos 19-12-14 20
답변 답변글 답변 : ATMEGA128 노래 속도 master 19-12-14 19
질문 초기화 어떻게 하나요?댓글[2] 끵끵끵 19-12-14 17
답변 답변글 답변 : 초기화 어떻게 하나요? 새글 master 19-12-14 5
질문 서보모터 이용 자율주행 관련 질문 klohs 19-12-13 14
답변 답변글 답변 : 서보모터 이용 자율주행 관련 질문 master 19-12-13 14
질문 atmega128 / bldc모터 구동 질문입니다.댓글[1] 이미지첨부파일 조셉 19-12-13 20
질문 블루투스(HM-10) 비콘 관련 질문댓글[2] 으앙 19-12-12 17
질문 모터가 이상합니다.댓글[3] 첨부파일 이즈미 19-12-12 23
MCU BASIC ⓒ 2019
