질문게시판 > 답변 : 아두이노 저장,재생기능
TODAY282 TOTAL2,579,451
BASIC4MCU | 질문게시판 | 답변 : 아두이노 저장,재생기능
작성자 master 작성일2018-08-06 16:44 조회6,175회 댓글1건
// DateTime : 2018-08-06 오후 4:47:50
//record,playback
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2,3);
int ledPin=13;
int resetMIDI=4;
int btn1=13,btn2=12,btn3=11,btn4=10,
#define btn12 A2 //recording
#define btn13 A1 //replay
byte note=0;
boolean bs1=0,bs2=0,bs3=0,bs4=0,bs12=0,bs13=0;
boolean br1=0,br2=0,br3=0,br4=0,br12=0,br13=0;
int bn1=60,bn2=62,bn3=64,bn4=65//버튼1  도 //버튼2  레 //버튼3  미 //버튼4  파
int patch=0;
byte byteData;
  Serial.begin(31250);
  mySerial.begin(31250);
  pinMode(resetMIDI,OUTPUT);  digitalWrite(resetMIDI,LOW ); delay(100); digitalWrite(resetMIDI,HIGH); delay(100);
  pinMode(btn1,INPUT_PULLUP); pinMode(btn2 ,INPUT_PULLUP);  pinMode(btn3 ,INPUT_PULLUP);
  pinMode(btn4,INPUT_PULLUP); pinMode(btn12,INPUT_PULLUP);  pinMode(btn13,INPUT_PULLUP);
  br1=digitalRead(btn1); br2 =digitalRead(btn2 ); br3=digitalRead(btn3);
  br4=digitalRead(btn4); br12=digitalRead(btn12); br13=digitalRead(btn13);
  if(!bs1&&!br1){ noteOn(0,bn1,100); bs1=true; } else if(bs1&&br1){ noteOff(0,bn1,0); bs1=false; }
  if(!bs2&&!br2){ noteOn(0,bn2,100); bs2=true; } else if(bs2&&br2){ noteOff(0,bn2,0); bs2=false; }
  if(!bs3&&!br3){ noteOn(0,bn3,100); bs3=true; } else if(bs3&&br3){ noteOff(0,bn3,0); bs3=false; }
  if(!bs4&&!br4){ noteOn(0,bn4,100); bs4=true; } else if(bs4&&br4){ noteOff(0,bn4,0); bs4=false; }
  if(!bs12&&!br12){}
  if(!bs13&&!br13){}
  if(Serial.available()>0){ byteData=Serial.read(); mySerial.write(byteData); }
void noteOn (byte channel,byte note,byte attack_velocity ){ talkMIDI((0x90|channel),note,attack_velocity ); }
void noteOff(byte channel,byte note,byte release_velocity){ talkMIDI((0x80|channel),note,release_velocity); }
void talkMIDI(byte cmd,byte data1,byte data2){
  digitalWrite(ledPin,HIGH);
  mySerial.write(cmd); mySerial.write(data1); if((cmd&0xF0)<=0xB0)mySerial.write(data2);
  digitalWrite(ledPin,LOW);
질문 소스를 정리해서 올린겁니다.
원하는대로 기능을 넣는 것은 차차 만들어보죠
음색 버튼은 도레미파 4개만 사용할건가요?
조회수 6,175
gksl님의 댓글
gksl 작성일
소스가 너무 길어져서 간략하게 줄인 파일을 첨부해놓았습니당!!
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 17027
질문 모터 작동 시, 일부 모듈이 꺼지는 현상에 대해 질문드립니다. 이미지새글 그렇찌 23-03-22 13
질문 ESP로 원격 모터제어를 할 수 있나용? 새글 비차 23-03-22 7
질문 HC06을 마스터로 설정하면 HC06끼리만 통신되나요?댓글[4] 비차 23-03-21 22
질문 아두이노 3LED 버튼 관련 질문댓글[1] 이츤 23-03-16 33
질문 스텝모터 코딩 질문입니다..댓글[2] 무야더싱 23-02-25 121
질문 아두이노 나노33 IOT 의 BLE 연결 문제 이미지 가루밀 23-02-24 70
질문 HM-10 모듈 사용하는데 질문있습니다.댓글[2] 뉴비에오 23-02-21 117
답변 답변글 답변 : 블루투스에서 아두이노로 신호전달에 대하여 master 23-02-14 113
질문 ATmega328p + pca9685 + 서보모터 토비 23-02-08 154
