질문게시판 > 아두이노 I2C.h
TODAY1,185 TOTAL789,597
BASIC4MCU | 질문게시판 | 아두이노 I2C.h
작성자 김리락 작성일2018-10-18 00:58 조회1,461회 댓글5건
I2C 헤더파일을 사용해서 LIDARlite-v3 센서의 거리를 출력하고자합니다.
LidarLite.h를 사용한 예제를 출력하면 센서값이 나오는걸 보니 하드웨어적 문제는 없는것같으나, 이상하게도 I2C 파일을 사용하면 센서값이 계속 0,0,0,0,0,0,.....0이 나오네요..
#include <I2C.h>
#define    LIDARLite_ADDRESS       0x62          // Default I2C Address of LIDAR-Lite.
#define    RegisterMeasure         0x00          // Register to write to initiate ranging.
#define    MeasureValue            0x04          // Value to initiate ranging.
#define    RegisterHighLowB        0x8f          // Register to get both High and Low bytes in 1 call.
#define    CalibrationRegister     0x13          // The register to set for calibration
#define    CalibrationOffsetVlue   0x00          // The calibration offset... see note below.
Calibration offset is a Two's Compliment Value:
For postive offset... i.e. to add a constant to the distance output... simply convert the decimal number to hex
Example... if i want to add 5 to all distance readings... the CalibrationOffsetValue would be 0x05
For negative offset... i.e. to subtract a constant from the distance output, you need to subtract the value from 256
and convert that to hex.
Example 1... if i want to remove 5 from all distance readings: 256-5 = 251 so the CalibrationOffsetValue would be 0xFB
Example 2... if i want to remove 12 from all distance readings: 256-12 = 244 so the CalibrationOffsetValue would be 0xF4
Use this page to get the hex values: http://www.cs.princeton.edu/courses/archive/fall07/cos109/bc.html
  Serial.begin(9600); //Opens serial connection at 9600bps.
  I2c.begin(); // Opens & joins the irc bus as master
  delay(100); // Waits to make sure everything is powered up before sending or receiving data
  I2c.timeOut(50); // Sets a timeout to ensure no locking up of sketch if I2C communication fails
  LidarLiteCalibrate();
   Serial.println(LidarLiteRawDistance());
FUNCTIONS
void LidarLiteCalibrate(){
 // Write 0x04 to register 0x00
  uint8_t nackack = 100; // Setup variable to hold ACK/NACK resopnses
  while (nackack != 0){ // While NACK keep going (i.e. continue polling until sucess message (ACK) is received )
    nackack = I2c.write(LIDARLite_ADDRESS,CalibrationRegister, CalibrationOffsetVlue); // Write Calibration Offset Value to 0x13
    delay(1); // Wait 1 ms to prevent overpolling
int LidarLiteRawDistance(){
    nackack = I2c.write(LIDARLite_ADDRESS,RegisterMeasure, MeasureValue); // Write 0x04 to 0x00
  byte distanceArray[2]; // array to store distance bytes from read function
  // Read 2byte distance from register 0x8f
    nackack = I2c.read(LIDARLite_ADDRESS,RegisterHighLowB, 2, distanceArray); // Read 2 Bytes from LIDAR-Lite Address and store in array
  int distance = (distanceArray[0] << 8) + distanceArray[1];  // Shift high byte [0] 8 to the left and add low byte [1] to create 16-bit int
  return distance; // give us this value
댓글 5
조회수 1,461
I2C 방식의 LCD 연결하면서 값이 나오지 않는다는 것인가요?
김리락님의 댓글
김리락 작성일
I2C방식으로 센서의 출력값 DISTANCE를 보고싶은건데 distance값이 계속 0이 나옵니다.
라이브러리 종류가 여러가지 인 경우에는
정상 동작하는 라이브러리를 찾아보세요
정 안되면 I2C를 사용하지 않은 LidarLite.h를 사용하세요
김리락님의 댓글
김리락 댓글의 댓글 작성일
이거한번만 봐주세요
#include <I2C.h>
  // Print Distance
  Serial.println(distance);
정상작동 하지않는 코드인데 소프트웨어적으로 문제가있는지 봐주세요..ㅠ
외부 모듈과의 인터페이스는
실제 하드웨어가 있어야지 체크가 가능합니다.
예제를 만들지 않은 사람은 눈으로 봐서는 알지 못합니다.
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 977
공지 사이트 이용 안내댓글[10] master 17-10-29 8935
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 3374
질문 앱인벤터 아두이노 이용해서 피아노음율내기 새글 bas213 19-12-07 12
답변 답변글 답변 : 앱인벤터 아두이노 이용해서 피아노음율내기 새글 master 19-12-07 11
질문 아두이노 컴파일 오류 질문입니다!!댓글[1] 새글 메롱198 19-12-07 13
질문 Atmega128로 3-phase BLDC MOTOR 구동 질문! 이미지새글첨부파일 조셉 19-12-06 18
답변 답변글 답변 : Atmega128로 3-phase BLDC MOTOR 구동 질문!댓글[2] 새글 master 19-12-06 29
질문 세그먼트 숫자가 같을시 LED 깜박거리기댓글[1] 새글 홍구 19-12-06 19
질문 MP3 모듈 질문있습니다.댓글[1] 새글 초짜 19-12-06 15
질문 코딩 질문이요댓글[1] 새글 호롷홀 19-12-06 16
질문 엔코더 회전 시간 추가 질문댓글[2] starmachin 19-12-06 17
질문 atmega128 배열이동 질문있어요!댓글[1] 마이크로 19-12-06 19
질문 sx1276 로라모듈댓글[1] 엘도라도 19-12-06 15
질문 소스코드 합치는 방법좀 알려주세요 ...댓글[1] 첨부파일 구슬박은놈 19-12-06 18
질문 가변저항옴값질문입니다 현이꽃 19-12-06 11
답변 답변글 답변 : 가변저항옴값질문입니다 이미지 master 19-12-06 12
질문 라인트레이서 + 초음파 호롷홀 19-12-05 17
답변 답변글 답변 : 라인트레이서 + 초음파 master 19-12-06 18
질문 코딩관련 질문이요ㅠㅠㅠㅠ댓글[2] 이미지 rkdeh 19-12-05 23
질문 아두이노 MsTimer2 구퓨리 19-12-05 12
답변 답변글 답변 : 아두이노 MsTimer2댓글[1] master 19-12-05 14
질문 코드 해석 부탁드립니다댓글[1] asdqwd 19-12-05 12
질문 아두이노 심박수 측정 코드 해석 부탁드립니다댓글[3] asdqwd 19-12-05 19
질문 아두이노 오류입니다 도와주세요 ㅠㅠ댓글[1] 이미지 구슬박은놈 19-12-05 12
질문 동일 센서 연결 질문 드립니다.댓글[1] 정다나 19-12-05 13
질문 atmega128 FND 질문 studio4 19-12-05 30
답변 답변글 답변 : atmega128 FND 질문 master 19-12-05 23
질문 자동차 냉각회로 질문있습니다.댓글[3] 이미지 rhdwkr00 19-12-04 21
질문 코딩관련 질문드립니다.댓글[3] rkdeh 19-12-04 29
MCU BASIC ⓒ 2019
