질문게시판 > 코드 관련...
TODAY833 TOTAL1,150,249
BASIC4MCU | 질문게시판 | 코드 관련...
작성자 용용 작성일2018-10-26 16:38 조회1,122회 댓글0건
#include <stdio.h>
#define SENSOR_IN    (PINF&0x02) // PB4
#define SENSOR_OUT_1 DDRF|=0x02  // PB4
#define SENSOR_OUT_0 DDRF&=~0x0 // PB4
#define MOTER PORTB|=0x01
#define LED_R PORTB|=0x08
#define LED_B PORTB|=0x04
unsigned int /*led_r, led_b, mot,*/ adc_data;
unsigned char data[5];
//float volt1, water;
void Putch0(char data)
   while(!(UCSR0A & 0x20));
   UDR0 = data;
char Getch0(void)
   while(!(UCSR0A & 0x80));
   return UDR0;
void UART_initialize(void)
   UCSR0A = 0x0;
   UCSR0B = 0b00011000;
   UCSR0C = 0b00000110;
   UBRR0H = 0;
   UBRR0L = 8;
ISR(ADC_vect,ISR_BLOCK)
   adc_data = ADC;
   //volt1 = (float)(adc_data/1023.0)*5;
   //water = volt1/100;
   //  printf("\n\r water price : %d.%d",((int)(volt1*10))/10,((int)(volt1*10))%10);
   //  printf("\n\r water price : %d",adc_data);
   char adc_channel;
   FILE *fp;
   fp = fdevopen(Putch0, Getch0);
   cli();
   ACSR = 0x80;
   DDRA = 0xff;
   DDRB = 0xff;
   DDRD = 0xff;
   PORTB = 0x00;
   UART_initialize();
   adc_channel=0;
   ADMUX = 0x41;      //01000001
   //ADCSRA = 0x87;      //10000111
   ADMUX |= adc_channel;
   ADCSRA = 0xeF;
   printf("\n\r water price Test start");
   sei();
      if(adc_data<700)
         PORTB = 0x04;//00000100
         PORTD = 0x08;//00000100
         PORTB = 0x09;//0000 1001
         _delay_ms(500);
         PORTB = 0x01;//0000 0001
         _delay_ms(500);
         PORTD = 0x00;
이거 와
 * . Author:          KOPO2016
 * . MCU Type:         Atmega 128
 * . Clock Frequency:   16Mhz
 * . Compiler:      AVR Studio 4.0 (WinAVR-20090313)
 * Note: Project -> Configuration options -> frequency : 16000000
/*          ASCII(English)-Only Display on Graphic LCD Module                  */
/*   Graphic LCD Module : 128x64 dot,LED backlight                       */
/* LCD_DATABUS PORTC : C0-C7 = DB0-DB7 (7-14, data bus)                       */
/* LCD_CONTROL PORTA :                                               */
/*                   A0 = D/-I    (1, data/instruction)                   */
/*                   A1 = R/-W    (2, read/write)                      */
/*                       A2 = E       (3, enable)                          */
/*                       A3 = GLCD_CS1     (4, chip select 1)                */
/*                       A4 = GLCD_CS2     (5, chip select 2)               */
#define F_CPU   16000000UL
#include <stdio.h>
#include "GLCD_kor.h"      // define   (delay)
#define AM2302_IN    (PINE&0x10) // PE4
#define AM2302_OUT_1 DDRE|=0x10  // PE4
#define AM2302_OUT_0 DDRE&=~0x10 // PE4
#define LCD_DATABUS   PORTC // GLCD data
#define LCD_CONTROL   PORTA // GLCD control signal
#define lcd_RS_1  PORTC|=1
#define lcd_RS_0  PORTC&=~1
#define lcd_E_1   PORTC|=4
#define lcd_E_0   PORTC&=~4
#define lcd_Out PORTA   // PORTA.4~7 4bits
unsigned char LineBuf1[17] ;
unsigned char LineBuf2[17] ;
unsigned int  half_usec,Temp,Humi, adc_data;
unsigned char data[5],Temp_sign;
float volt1, volt2, temper, humi;
void uart0_init(void)
UCSR0A = 0x00;
UCSR0B = 0x00; //disable while setting baud rate
UCSR0C = 0x06;
UBRR0H = 0x00; //set baud rate hi
UBRR0L = 0x67; //set baud rate lo
UCSR0B = 0x18;
void Tx0char(char m)   {   while (((UCSR0A >> UDRE0) & 0x01) == 0); UDR0 = m; }
int   Putchar(char c)      {   Tx0char(c);   return c; }
int Getchar(void)      {   while ((UCSR0A & 0x80) == 0);   return UDR0; }
void lcdCmd(char c){
    lcd_RS_0;
    lcd_Out=c&0xF0; lcd_E_1; _delay_us(1); lcd_E_0; _delay_us(1);
    lcd_Out=c<<4;   lcd_E_1; _delay_us(1); lcd_E_0; _delay_us(40);
void lcdData(char d){
    lcd_RS_1;
    lcd_Out=(d&0xF0)|1; lcd_E_1; _delay_us(1); lcd_E_0; _delay_us(1);
    lcd_Out=(d<<4)|1;   lcd_E_1; _delay_us(1); lcd_E_0; _delay_us(40);
void lcd_puts(char *str)
   while
   (*str)lcdData(*str++);
void lcd_init(void){
    _delay_ms(50);
    lcdCmd(0x28); lcdCmd(0x28); lcdCmd(0x28);
    lcdCmd(0x0C); lcdCmd(0x06); lcdCmd(0x01); _delay_ms(2);
void lcd_gotoxy(char x, char y){
    if     (y==0)lcdCmd(0x80+x);
    else if(y==1)lcdCmd(0xC0+x);
    else if(y==2)lcdCmd(0x94+x);
    else if(y==3)lcdCmd(0xD4+x);
void AM2302_rd(void){
    unsigned char i,k;
   for(i=0;i<8;i++)data[i]=0; // 변수 초기화
   //host start signal
    AM2302_OUT_1;
    _delay_ms(1);
   AM2302_OUT_0; // 데이터 요구
   //released time
    TCNT1=0; TCCR1B=2;
   while(AM2302_IN);
   TCCR1B=0;
   half_usec=TCNT1; // high_time
    if((half_usec<30)||(half_usec>410))goto AM2302_Error;         // 30us high 측정, (min20~max200us),실측 20us
   //response AM2302
    TCNT1=0; TCCR1B=2;
   while(!AM2302_IN);
   TCCR1B=0;
   half_usec=TCNT1; // low_time
    if((half_usec<140)||(half_usec>180))goto AM2302_Error;        // 80us low 측정, (min75~max85us),실측 80us
    TCNT1=0; TCCR1B=2;
   while(AM2302_IN);
   TCCR1B=0;
   if((half_usec<140)||(half_usec>180))goto AM2302_Error;        // 80us high 측정, (min75~max85us),실측 80us
    for(k=0;k<5;k++)
        for(i=0;i<8;i++)
            //pulse
            TCNT1=0; TCCR1B=2; while(!AM2302_IN); TCCR1B=0; half_usec=TCNT1; // low_time
            if((half_usec<85)||(half_usec>150))goto AM2302_Error; // 50us low(min48~max55us),실측 56us,68us
            TCNT1=0; TCCR1B=2; while(AM2302_IN); TCCR1B=0; half_usec=TCNT1; // high_time
            if((half_usec<34)||(half_usec>165))goto AM2302_Error; // 26us & 70us high(min22~max75us),실측 24us,72~76us
            if(half_usec>96)data[k]|=0x80>>i; // high구간 48us이상이면 1
    //Parity(check sum)check
    i=data[0]+data[1]+data[2]+data[3];
    if(i!=data[4])goto AM2302_Error; //Parity error
    //data copy
    Humi=(unsigned int)data[0]*256+data[1];
    Temp=(unsigned int)data[2]*256+data[3];
   //Temp 영하 체크
    if(Temp&0x8000){ Temp_sign=1; Temp&=0x7FFF; } // 영하
    else             Temp_sign=0;                 // 영상
    return;
AM2302_Error:;
    Humi=Temp=0; Temp_sign=0;
//   uart0_init();f
   DDRD = 0xff;
    fdevopen(Putchar,Getchar); // printf 와 scanf 사용가능
   unsigned char keyDown[20];
   unsigned int R=0, C=0;
   printf("Lab_UART0\r\n");
   printf("%c\n\r", 0x0C);
   printf("*============================================================+\r\n");
   printf("|  Hyper terminal Setting                                    |\r\n");
   printf("|------------------------------------------------------------|\r\n");
   printf("|  Speed-9600, DataBit-8, Parity-None, StopBit-1, Flow-None  |\r\n");
   printf("*============================================================|\r\n");
   byte i;
   MCU_initialize();                             // initialize MCU and kit
   _delay_us(10);                                 // wait for system stabilization
   GLCD_init();
   _delay_us(10);
   GLCD_clear();                                 // initialize GLCD screen
   cursor_flag = 0;                              // cursor off
   //GLCD_String(0,0,"->");
//   C=3;
//   C=0; R=0;
//   printf("(!) User Start => ");
       lcd_init();
    lcd_gotoxy(0,0); lcd_puts("AM2302 test");
    lcd_gotoxy(0,1); lcd_puts("Humi & Temp");
   _delay_ms(2000);
//   GLCD_Bitmap( (char*)em_font, 0, 0, 64, 64);
//   _delay_ms(2000);
         _delay_ms(10);             // AM2302 데이터 요구 주기
        AM2302_rd();
      sprintf(LineBuf1, "%d.%d?C 입니다 ",Temp/10,Temp%10);
      sprintf(LineBuf2, "%d.%d 입니다. ", Humi/10,Humi%10);
      GLCD_String(0,0,"온도는");
       GLCD_String(1,0,LineBuf1);
        GLCD_String(2,0,"습도는");
        GLCD_String(3,0,LineBuf2);
        if(Humi/10 > 50)
           PORTD = 0x08;
           PORTD = 0x00;
//      scanf("%s",&keyDown);
//       GLCD_String(C,R,keyDown);//      C++;
//      if (C>20) { C=0; R++;}
   return 0;
J MOD를 사용중입니다. 이 두개 코드를 합쳐 주실 수 있나요??
부탁 드립니다. ㅜ
조회수 1,122
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 1871
공지 사이트 이용 안내댓글[12] master 17-10-29 11793
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 4452
질문 아두이노와 STM L432KC 블루투스 통신관련 질문입니다. 새글 아니뭐그냥 01:13 8
질문 아래 글에 재질문입니다!댓글[3] 새글 수파도프 20-07-15 16
질문 rtc 모터제어댓글[5] 새글 수파도프 20-07-15 25
질문 타이머 관련해서 질문 드립니다.댓글[1] 새글 코딩공부하자 20-07-15 14
답변 답변글 답변 : 타이머 관련해서 질문 드립니다.댓글[2] 새글 코딩공부하자 20-07-15 13
질문 아두이노, PC 간 버튼통신 질문댓글[3] 이미지새글 songsare 20-07-15 22
질문 아두이노 코드 볼 스위치 코드에 대해서 질문 드립니다. 새글 아두이노어려웡 20-07-14 18
질문 외부 인터럽트에 대해 질문드립니다..!댓글[2] 새글 코딩공부하자 20-07-14 23
질문 초음파 센서와 연동질문댓글[2] 야야두이노 20-07-14 27
질문 아두이노 due 타이머 인터럽트댓글[9] 궁금 20-07-14 24
질문 아두이노 LCD, 블루투스 코드 병합 ㅜㅜ간절합니다 야야두이노 20-07-13 40
답변 답변글 답변 : 아두이노 LCD, 블루투스 코드 병합 ㅜㅜ간절합니다 master 20-07-13 25
답변 답변글 답변 : 답변 : 아두이노 LCD, 블루투스 코드 병합 ㅜㅜ간절합니다댓글[2] 이미지 야야두이노 20-07-13 29
질문 Atmega48 주파수 관련해서 질문드립니다..!댓글[5] 코딩공부하자 20-07-13 26
질문 타이머 인터럽트 채터링 문제? 이미지첨부파일 궁금 20-07-13 23
답변 답변글 답변 : 타이머 인터럽트 채터링 문제?댓글[2] master 20-07-13 19
질문 아두이노 질문있습니다댓글[1] 이미지 djfuqspdy 20-07-12 32
질문 PD제어 소스 질문있습니다.댓글[3] 궁금 20-07-10 41
질문 unique id 생성댓글[1] cheaminee 20-07-10 38
질문 아두이노 포트 변경댓글[2] cheaminee 20-07-09 46
질문 소스 코딩 도와주세요 bas213 20-07-09 51
답변 답변글 답변 : 소스 코딩 도와주세요 master 20-07-09 46
질문 안녕하세요. 질문있습니다. dkendlsh 20-07-08 30
답변 답변글 답변 : 안녕하세요. 질문있습니다.댓글[1] master 20-07-08 39
질문 아두이노 nfc 센서와 pH센서 같이 연결댓글[1] 알려주세요제발ㅠㅠ 20-07-08 41
질문 아두이노 초음파 센서, 부저, 스위치 합치기 도와주세요ㅜㅜ 이밍밍 20-07-05 62
질문 이 도어락 코드좀 이미지첨부파일 문준혁 20-07-05 66
