질문게시판 > avr128
TODAY834 TOTAL1,140,482
BASIC4MCU | 질문게시판 | avr128
작성자 ohjee0507 작성일2018-11-26 14:09 조회967회 댓글0건
#define  F_CPU 16000000UL
#include <avr/io.h>
#include <avr/interrupt.h>
#include <stdio.h>
#include <util/delay.h>
#define DO  0
#define RE  1
#define MI  2
#define FA  3
#define SOL 4
#define RA  5
#define SI  6
#define DDO 7
#define EOS -1 // End Of Song  표시
#define ON  0
#define OFF 1
#define sbi(PORTX,bitX)  PORTX|=(1<<bitX)
#define cbi(PORTX,bitX)  PORTX&=~(1<<bitX)
unsigned char f_table[8]={17,43,66,77,97,114,117,137};
int song[]={DO,DO,EOS};
char string1[16]="  DARK  ";
char string2[16]="  ";
char buf[32];
volatile int tone;
int value=666;
void LCD_command(char c){
  PORTA=c&0xF0cbi(PORTA,0); sbi(PORTA,2); _delay_us(1); cbi(PORTA,2);
  PORTA=c<<0x4cbi(PORTA,0); sbi(PORTA,2); _delay_us(1); cbi(PORTA,2); _delay_ms(2);
void LCD_data(char d){
  PORTA=d&0xF0sbi(PORTA,0); sbi(PORTA,2); _delay_us(1); cbi(PORTA,2);
  PORTA=d<<0x4sbi(PORTA,0); sbi(PORTA,2); _delay_us(1); cbi(PORTA,2); _delay_us(100);
void LCD_string(char line,char *s){ LCD_command(0x80+((line-1)*0x40)); while(*s)LCD_data(*s++); }
void LCD_init(void){
  _delay_ms(50); LCD_command(0x28); LCD_command(0x0C); LCD_command(0x06); LCD_command(0x01);
ISR(TIMER0_OVF_vect){ TCNT0=f_table[tone]; PORTB^=0x10; } // 버저
void main(){
  int i;
  DDRA=0xFFDDRB=0x10;
  LCD_init();
  TCNT0=f_table[song[i]]; TCCR0=0x03TIMSK=0x01;
  sei();
    i=0dotone=song[i++]; _delay_ms(400); }while(tone!=EOS);
    sprintf(buf,"%s ",string1);
    LCD_string(1,buf);     _delay_ms(1000); LCD_command(0x01);
    LCD_string(2,string2); _delay_ms(1000); LCD_command(0x01);
int i, j;
DDRC=0xff;
DDRD=0xff;
PORTC=0x00;
PORTD=0x00;
unsigned char dark[16][32]={ 0, 0, 0, 0, 0, 0, 0, 0,  0, 0, 0, 0, 0, 0, 0, 0,  0, 0, 0, 0, 0, 0, 0, 0,  0, 0, 0, 0, 0, 0, 0, 0,
  0, 0, 0, 1, 1, 0, 0, 0,  0, 0, 0, 1, 1, 1, 1, 0,  0, 0, 0, 0, 0, 1, 1, 0,  0, 0, 0, 1, 1, 1, 1, 0,
  0, 0, 1, 1, 1, 1, 0, 0,  0, 0, 1, 1, 1, 1, 1, 0,  0, 1, 0, 0, 0, 1, 1, 0,  0, 0, 1, 1, 1, 1, 1, 0,
  0, 1, 1, 0, 0, 1, 1, 0,  0, 1, 1, 0, 0, 1, 1, 0,  0, 1, 1, 0, 0, 1, 1, 0,  0, 1, 1, 0, 0, 1, 1, 0,
  0, 1, 1, 0, 0, 1, 1, 0,  0, 1, 1, 0, 0, 1, 1, 0,  0, 0, 1, 1, 0, 1, 1, 0,  0, 1, 1, 0, 0, 1, 1, 0,
  0, 1, 1, 0, 0, 1, 1, 0,  0, 1, 1, 0, 0, 1, 1, 0,  0, 0, 0, 1, 1, 1, 1, 0,  0, 1, 1, 0, 0, 1, 1, 0,
  0, 1, 1, 0, 0, 1, 1, 0,  0, 1, 1, 0, 0, 1, 1, 0,  0, 0, 0, 0, 1, 1, 1, 0,  0, 1, 1, 1, 1, 1, 1, 0,
  0, 1, 1, 1, 1, 1, 1, 0,  0, 1, 1, 0, 0, 1, 1, 0,  0, 0, 0, 0, 0, 1, 1, 0,  0, 0, 1, 1, 1, 1, 1, 0,
  0, 1, 1, 1, 1, 1, 1, 0,  0, 1, 1, 0, 0, 1, 1, 0,  0, 0, 0, 0, 0, 1, 1, 0,  0, 0, 1, 0, 0, 1, 1, 0,
  0, 1, 1, 0, 0, 1, 1, 0,  0, 1, 1, 0, 0, 1, 1, 0,  0, 0, 0, 0, 1, 1, 1, 0,  0, 1, 1, 0, 0, 1, 1, 0,
  0, 1, 1, 0, 0, 1, 1, 0,  0, 0, 1, 1, 1, 1, 1, 0,  0, 1, 1, 0, 0, 1, 1, 0,  0, 1, 1, 0, 0, 1, 1, 0,
  0, 1, 1, 0, 0, 1, 1, 0,  0, 0, 0, 1, 1, 1, 1, 0,  0, 1, 0, 0, 0, 1, 1, 0,  0, 1, 1, 0, 0, 1, 1, 0,
  0, 0, 0, 0, 0, 0, 0, 0,  0, 0, 0, 0, 0, 0, 0, 0,  0, 0, 0, 0, 0, 0, 0, 0,  0, 0, 0, 0, 0, 0, 0, 0};//원하는 모양으로 정렬 함수를 만들어서 출력함.
//0b 0000 0000 -> 0d 0 -> 0x00
//0b 0000 0001 -> 0d 1 -> 0x01
//0b 0000 0010 -> 0d 2 -> 0x02
//0b 0000 0011 -> 0d 3 -> 0x03
    while (1)
for(i=0; i<16; i++){
PORTC = i; // 행
for(j=0; j<32; j++){
PORTD = 0x00 + dark[i][j]; //색깔지정   1, 2, 3값으로 색을 조정할 수 있음.
PORTD = 0x10 + dark[i][j]; //4번 비트 클락 0->1 열을 뜻함
PORTD = 0x23; //래치 0010<-이거 0011   : 래치는 행과 열을 통해 만든 것을 LED에 보여주는 방아쇠 역할을 한다.
int i, j;
DDRC=0xff; //  1111 1111
DDRD=0xff; // 1111 1111
PORTC=0x00;// 0000 0000
PORTD=0x00;// 0000 0000
unsigned char  smile[16][32]={ 0, 0, 0, 0, 0, 0, 0, 0,  0, 0, 0, 0, 0, 0, 0, 0,  0, 0, 0, 0, 0, 0, 0, 0,  0, 0, 0, 0, 0, 0, 0, 0,
  0, 0, 0, 0, 0, 0, 0, 1,  1, 0, 0, 0, 0, 0, 0, 0,  0, 0, 0, 0, 0, 0, 0, 1,  1, 0, 0, 0, 0, 0, 0, 0,
  0, 0, 0, 0, 0, 0, 1, 1,  1, 1, 0, 0, 0, 0, 0, 0,  0, 0, 0, 0, 0, 0, 1, 1,  1, 1, 0, 0, 0, 0, 0, 0,
  0, 0, 0, 0, 0, 1, 1, 0,  0, 1, 1, 0, 0, 0, 0, 0,  0, 0, 0, 0, 0, 1, 1, 0,  0, 1, 1, 0, 0, 0, 0, 0,
  0, 0, 0, 0, 1, 1, 0, 0,  0, 0, 1, 1, 0, 0, 0, 0,  0, 0, 0, 0, 1, 1, 0, 0,  0, 0, 1, 1, 0, 0, 0, 0,
  0, 0, 0, 0, 1, 0, 0, 0,  0, 0, 0, 1, 0, 0, 0, 0,  0, 0, 0, 0, 1, 0, 0, 0,  0, 0, 0, 1, 0, 0, 0, 0,
  1, 1, 1, 1, 1, 0, 0, 0,  0, 0, 0, 0, 0, 0, 0, 0,  0, 0, 0, 0, 0, 0, 0, 0,  0, 0, 0, 1, 1, 1, 1, 1,
  0, 0, 0, 1, 0, 0, 0, 0,  0, 0, 0, 0, 0, 0, 0, 0,  0, 0, 0, 0, 0, 0, 0, 0,  0, 0, 0, 0, 1, 0, 0, 0,
  0, 0, 1, 0, 0, 0, 0, 0,  0, 0, 0, 0, 0, 0, 0, 0,  0, 0, 0, 0, 0, 0, 0, 0,  0, 0, 0, 0, 0, 1, 0, 0,
  0, 1, 0, 0, 0, 0, 0, 0,  0, 0, 0, 0, 0, 0, 0, 0,  0, 0, 0, 0, 0, 0, 0, 0,  0, 0, 0, 0, 0, 0, 1, 0,
  1, 0, 0, 0, 0, 0, 0, 0,  0, 0, 0, 0, 0, 0, 0, 0,  0, 0, 0, 0, 0, 0, 0, 0,  0, 0, 0, 0, 0, 0, 0, 1,
    while (1)
PORTC = i; // 행
PORTD = 0x00 + smile[i][j]; //색깔지정 1,2,3 으로 색을 조정할 수 있음.
PORTD = 0x10 + smile[i][j]; //4번 비트 클락 0->1 열을 뜻함
 이거랑 광센서 기능을 합칠 거라서 어두울 때는 도트매트릭스에 dark 라고 나오고
밝아질 때는 ^^ 모양을 구현하고 싶습니다.
도와 주세요...
조회수 967
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 1842
공지 사이트 이용 안내댓글[12] master 17-10-29 11709
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 4416
질문 소스 코딩 도와주세요 새글 bas213 01:45 8
답변 답변글 답변 : 소스 코딩 도와주세요 새글 master 06:15 6
질문 안녕하세요. 질문있습니다. 새글 dkendlsh 20-07-08 14
답변 답변글 답변 : 안녕하세요. 질문있습니다. 새글 master 20-07-08 10
질문 아두이노 nfc 센서와 pH센서 같이 연결댓글[1] 새글 알려주세요제발ㅠㅠ 20-07-08 16
질문 아두이노 초음파 센서, 부저, 스위치 합치기 도와주세요ㅜㅜ 이밍밍 20-07-05 35
질문 이 도어락 코드좀 이미지첨부파일 문준혁 20-07-05 41
질문 아두이노 입력전원댓글[2] 왕왕초a 20-07-02 50
질문 외부인터럽트가 발생했을때 ADC변환, 데이터 송신프로그램 질문입니다. 이소부 20-07-02 28
답변 답변글 답변 : 외부인터럽트가 발생했을때 ADC변환, 데이터 송신프로그램 질문입니다. master 20-07-02 34
질문 아두이노 마사지 키트 문의드립니다.댓글[3] 야아이양 20-07-02 35
질문 아두이노 공기청정기댓글[3] 행노비 20-07-02 50
질문 (아두이노)압력센서를 이용한 led on/off와 팬 작동댓글[1] 호조조 20-07-02 33
질문 아두이노 기체유량센서댓글[1] 최하림 20-07-01 31
질문 아두이노 pwm 제어 관련 질문드리고 싶습니다.댓글[4] 궁금스 20-07-01 66
질문 아두이노 합침 첨부파일 우경민 20-06-30 42
질문 소스 합쳐주세요 첨부파일 우경민 20-06-30 58
답변 답변글 답변 : 소스 합쳐주세요댓글[1] master 20-06-30 80
질문 소스코드 질문드립니다댓글[1] rqjiqwrji 20-06-30 72
질문 안녕하세요. 이런피아노 제작이 가능할까요?댓글[3] 애니멀티비 20-06-30 101
질문 서보모터+세그먼트+버튼 이용 오류 해결좀요..댓글[1] 이미지첨부파일 우편봉투 20-06-29 71
질문 소스코드 질문드립니다. mangham 20-06-29 52
답변 답변글 답변 : 소스코드 질문드립니다. master 20-06-29 50
답변 답변글 답변 : 답변 : 소스코드 질문드립니다. master 20-06-30 42
질문 라즈베리파이 블루투스댓글[1] 타조 20-06-28 66
질문 조도센서로 led, 서보모터, 스텝모터 제어하기 이미지첨부파일 tmxhathej 20-06-28 85
답변 답변글 답변 : 조도센서로 led, 서보모터, 스텝모터 제어하기 master 20-06-29 70
