BASIC4MCU | 질문게시판 | 답변 : atmega128 초보입니다.
작성자 master 작성일2018-12-01 14:41 조회4,504회 댓글1건
https://www.basic4mcu.com/bbs/board.php?bo_table=gac&wr_id=6120
// MCU BASIC: https://www.basic4mcu.com// DateTime : 2018-12-01 오후 2:45:45// by Ok-Hyun Park//#include <avr/io.h>#include <util/delay.h>#include <avr/interrupt.h>#include <string.h>#include <stdlib.h>#include <stdio.h>//-RGB LCD 제어 PORT&PIN---------------------------------------------------------------#define RGB_DATA_DDR DDRA //-Data Bus제어 Port#define RGB_DATA_PORT PORTA#define DATA_D4 PA0 //-Data Bus PIN#define DATA_D5 PA1#define DATA_D6 PA2#define DATA_D7 PA3#define RGB_LCD_DDR DDRF //-RGB LCD 제어 Port#define RGB_LCD_PORT PORTF#define RS_BIT PF2 //-Register Select: LOW-Command,HIGH-Data#define RW_BIT PF3 //-Read/Wite: LOW-Wite HIGH-Read#define EN_BIT PF4 //-Enable Pin: LOW-Disable HIGH-Enable#define RED_BIT PF5 //-Red Backlight: LOW-Off HIGH-On#define GREEN_BIT PF6 //-Green Backight: LOW-Off HIGH-On#define BLUE_BIT PF7 //-Blue Backlight: LOW-Off HIGH-On//-RBG LCD 제어관련 상수---------------------------------------------------------------#define ALL_SET 0xff //-모든 Pin 1로 셋#define ALL_CLEAR 0x00 //-모든 Pin 0으로 클리어#define DDRAM_ADDR 0x80 //-DD(Display Data)RAM 주소//-RBG LCD 제어관련 명령어--------------------------------------------------------------#define CMD_CLEAR_DISPLAY 0x01 //-CLEAR_DISPLAY(0x01)#define CMD_RETURN_HOME 0x02 //-RETURN_HOME(0x02)#define CMD_ENTRYMODE_SET 0x06 //-ENTRYMODE_SET(0x04)|Left(0x02)|Shift Decrement(0x00)#define CMD_DISPLAY_CONTROL 0x0C //-DISPLAY_CONTROL(0x08)|Display On(0x04)|Cursor Off(0x00)|Blink Off(0x00)#define CMD_CURSOR_SHIFT_RIGHT 0x1C //-CURSOR_SHIFT(0x10)|Shift Move(0x08)|Move Right(0x04)#define CMD_FUNCTION_SET 0x28 //-FUNCTION_SET(0x02)|4BIT(0x00)|2 Line(0x08)|5x8 Dots(0x00)#define CMD_8BIT_MODE 0x03 //-FUNCTION_SET(0x02)|8BIT(0x01)#define CMD_4BIT_MODE 0x03 //-FUNCTION_SET(0x02)|4BIT(0x00)#define DDRAM_FS_ADDR 0x0#define DDRAM_EF_ADDR 0x0F#define DDRAM_SS_ADDR 0x40#define DDRAM_SF_ADDR 0x4F//#define LX_LIMIT 100 //-LED Off 되는 한계 값 정의//-LED 관련#define DDR_LED DDRD#define PORT_LED PORTD#define LED_ON 0x00#define LED_OFF 0xF0/*-------------------------------------------------------------------------*///-Temp관련#define TEMP_ADDR 72 //-온도센서의 Slave 주소#define TEMP_ADDR_W TEMP_ADDR<<1 //-Write 주소#define TEMP_ADDR_R (TEMP_ADDR<<1)+1 //_ Read 주소#define TEMP_REG 0 //_ 온도 데이터 저장 Reg.주소#define TEMP_LIMIT 25 //_ DC Motor ON 되는 한계 값//-Clock 제어를 위한 선언#define CPU_CLOCK 16000000 //_ 16MHz#define SCL_FREQUENCY 400000 //_ 400KHz//-DC 모터 제어를 위한 정의#define DCM_DDR DDRB // B포트를 모두 출력으로#define DCM_PORT PORTB // B포트를 모두 출력으로 8칸이 다 1이 출력된다는거임#define FORWARD_BIT 0#define BACKWARD_BIT 1//-온도값 저장 전역 변수 선언volatile unsigned int gTempValue; //_ 측정된 온도 값 저장//-USART 제어를 위한 전역 변수 선언volatile unsigned int gLightValue; //-측정된 조도값 저장/*=====================================함수 선언=========================================================*/void RGB_LCD_Init(void);void RGB_LCD_Enable(void);void RGB_LCD_Write(unsigned char nValue);void Set4BitMode(void);void SendText(unsigned char addrCommand,char*szText);void SendCommandl(unsigned char command);void SendData(unsigned char data);void LCD_Display(void);void ADC_LED_Init(void);void ADC_Convert(void);void LED_OnOff(unsigned char nNum);//_ Temp&ADCvoid TEMP_DC_Init(void);void TEMP_Read(void);//_ DC Motorvoid Run_DCM(void);void Stop_DCM(void);//void TEMP_DC_Init(void){//-DC Motor 초기화DCM_DDR|=(1<<FORWARD_BIT)|(1<<BACKWARD_BIT); //-PB0,PB1 비트 Output으로 설정DCM_PORT&=~((1<<FORWARD_BIT)|(1<<BACKWARD_BIT)); //-DC모터 구동 정지로 설정//-Temp TWI 초기화TWSR&=~((1<<TWPS1)|(1<<TWPS0)); //-분주비 설정TWBR=(CPU_CLOCK/SCL_FREQUENCY-16)/ 2; //-TWI 통신 속도 설정}//void TEMP_Read(void){unsigned char arrTemp[2]; //-읽어온 2byte 데이터 저장unsigned int nTmp; //-12bit 온도 값 저장float fCValue; //-섭씨로 변환한 값 저장//-START conditionTWCR=(1<<TWINT)|(1<<TWSTA)|(1<<TWEN);while(!(TWCR&(1<<TWINT)));//-Slave Addr+Read 전송TWDR=TEMP_ADDR_R;TWCR=(1<<TWINT)|(1<<TWEN);while(!(TWCR&(1<<TWINT)));//-측정된 온도값 읽기for(int i=0; i<2; i++){ TWCR=(1<<TWINT)|(1<<TWEA)|(1<<TWEN); while(!(TWCR&(1<<TWINT))); arrTemp[i]=TWDR; }nTmp=arrTemp[0]<<8; nTmp=nTmp|arrTemp[1]; nTmp=nTmp>>4; //-측정된 12bit 온도 데이터 계산fCValue=(float)nTmp*0.0625; //-온도값을 섭씨로 변환->data_value*0.0625--------------TWCR=(1<<TWINT)|(1<<TWSTO)|(1<<TWEN); _delay_ms(5); //-STOP conditionif((int)fCValue>TEMP_LIMIT)Run_DCM(); else Stop_DCM();gTempValue=(int)fCValue; //-섭씨 온도값 저장}//void Run_DCM(void){ //-DC Motor 동작DCM_PORT&=~((1<<FORWARD_BIT)|(1<<BACKWARD_BIT)); //-정방향으로 회전DCM_PORT|=(1<<FORWARD_BIT);}//void Stop_DCM(void){ DCM_PORT=(1<<FORWARD_BIT)|(1<<BACKWARD_BIT); }/*=LED관련 함수*///-LED On/Offvoid LED_OnOff(unsigned char nNum){if(nNum==LED_ON)PORT_LED=0x00; //-4개 LED ONelse PORT_LED=0xF0; //-4개 LED OFF}/*=ADC&Light 관련 함수*///-ADC&Light 초기화void ADC_LED_Init(void){//-LED 초기화DDR_LED|=0xF0; PORT_LED|=0xF0;//-ADC0 채널,AREF 기준 전압 및 채널을 선택ADMUX=0;//-채널,활성화,프리스케일 설정ADCSRA=(1<<ADEN)|(1<<ADPS2)|(1<<ADPS1)|(1<<ADPS0);}/*==ADC 변환 함수 구현*/void ADC_Convert(void){unsigned int result;cli(); //-ADC 변환 중 인터럽트 금지ADCSRA|=(1<<ADSC); //-ADC 변환 시작while(!(ADCSRA&(1<<ADIF))); //-ADC 변환 완료 신호 대기result=ADCL; //-변환 결과 저장result|=((ADCH&0x03)<<8);sei(); //-인터럽트 허용if(result>LX_LIMIT)LED_OnOff(LED_OFF); //-CDS Value>50 LED OFFelse LED_OnOff(LED_ON); //-CDS Value<=50 LED ON//-조도값 저장gLightValue=result;}//void SendCommand(unsigned char command){ //-RBG_LCD 명령어 전달 함수 구현---------------------------------RGB_LCD_PORT&=~((1<<RS_BIT)|(1<<RW_BIT)|(1<<EN_BIT)); //-Command 전송을 위한 RS=0,RW=0,EN=0RGB_LCD_Write(command>>4); RGB_LCD_Write(command); //-Data Bus에 CMD 쓰기}//void SendData(unsigned char data){ //-RBG_LCD 데이터 전달 함수 구현---------------------------------RGB_LCD_PORT|=(1<<RS_BIT); RGB_LCD_PORT&=~((1<<RS_BIT)|(1<<EN_BIT)); //-Data 전송을 위한 RS=1,RW=0,EN=0RGB_LCD_Write(data>>4); RGB_LCD_Write(data);}//void SendText(unsigned char addrCommand,char*szText){ //-RBG_LCD 문자열 출력 함수 구현---------------------------------SendCommand(addrCommand); //-DD Ram 주소 전달while(*szText!='\0'){ SendData(*szText); szText++; }}//void RGB_LCD_Write(unsigned char nValue){ //-RBG_LCD 명령어/데이터 레지스터 기록 구현---------------------------------int nTmp=0;RGB_DATA_PORT=0x00;for(int nldx=0; nldx<4; nldx++){ nTmp=(nValue>>nldx)&0x01; RGB_DATA_PORT|=(nTmp<<(DATA_D4+nldx)); }RGB_LCD_Enable();}//void RGB_LCD_Enable(void){RGB_LCD_PORT|=(1<<EN_BIT); _delay_us(1); RGB_LCD_PORT&=~(1<<EN_BIT); _delay_us(100);}//void Set4BitMode(void){ //-RBG_LCD 4bit 인터페이스 설정 구현---------------------------------RGB_LCD_PORT&=~((1<<RS_BIT)|(1<<RW_BIT)|(1<<EN_BIT)); //-Command 전송을 위한 RS=0,RW=0,EN=0RGB_LCD_Write(CMD_8BIT_MODE); _delay_us(4500);RGB_LCD_Write(CMD_8BIT_MODE); _delay_us(4500);RGB_LCD_Write(CMD_8BIT_MODE); _delay_us(150);RGB_LCD_Write(CMD_4BIT_MODE);}//void RGB_LCD_Init(void){RGB_LCD_DDR=((1<<RS_BIT)|(1<<RW_BIT)|(1<<EN_BIT)|(1<<RED_BIT)|(1<<GREEN_BIT)|(1<<BLUE_BIT));RGB_LCD_PORT&=~((1<<RS_BIT)|(1<<RW_BIT)|(1<<EN_BIT)|(1<<RED_BIT)|(1<<GREEN_BIT)|(1<<BLUE_BIT));RGB_DATA_DDR=ALL_SET; RGB_DATA_PORT=ALL_CLEAR; //-Data 입력 Pin Output 설정 및 초기화Set4BitMode(); //-(2)RGB LCD 인터페이스 설정SendCommand(CMD_FUNCTION_SET); //-(3)RGB LCD 출력을 위한 설정 //-LCD의 행,열,글자 크기 설정SendCommand(CMD_DISPLAY_CONTROL); //-디스플레이,커서,문자 깜빡임 On/Off 설정SendCommand(CMD_ENTRYMODE_SET); //-커서 이동 방향,문자 디스플레이 이동 여부 설정SendCommand(CMD_CLEAR_DISPLAY); //-LCD 화연 지우고 커서는 1행 1열 위치,DDRAM AC=0RGB_LCD_PORT|=(1<<GREEN_BIT); //-Green Backlight 켜기_delay_us(2000);}//void LCD_Display(void){ //-측정된 온도,조도값 LCD에 출력--------------------------char arrTmp[16]="",pTmp[4]="";itoa(gTempValue,pTmp,10); strcat(arrTmp,"T: "); strcat(arrTmp,pTmp); strcat(arrTmp,"C"); //-온도값 문자열로 변환itoa(gLightValue,pTmp,10); strcat(arrTmp,"L: "); strcat(arrTmp,pTmp); strcat(arrTmp,"Lx "); //-조도값 문자열로 변환SendText(DDRAM_ADDR|DDRAM_FS_ADDR,arrTmp);}/*===========================*/// DESC:(1)일정 온도 이상이 되면 DC모터를 회전시키고 일정 밝기 이하면 LED를 켜준다.//-(2)RGB_LCD에 현재 온도와 조도를 표시해 준다./*===========================*//*==Main 함수 구현==============*/int main(void){ADC_LED_Init(); //-Light&LED 초기화TEMP_DC_Init(); //-Temp&DC 초기화RGB_LCD_Init(); //-RGB_LCD 초기화while(1){TEMP_Read(); //-온도 측정ADC_Convert(); //-조도 측정LCD_Display(); //-현재 온도.조도 LCD 출력_delay_ms(1000);}return 0;}
타이핑 오타는 백만개라고 하더라도 자신이 직접 찾아야합니다.
조회수 4,504master님의 댓글
본인 능력으로 오타도 찾지 못할만큼 복잡한 소스라면 이해하는 것도 어려울테니
간단하고 쉬운 예제를 많이 공부한 후에 복잡한 소스를 보시는 것이 힘이 덜 듭니다.
