질문게시판 > 답변 : atmega128 초보입니다.
TODAY507 TOTAL2,269,786
BASIC4MCU | 질문게시판 | 답변 : atmega128 초보입니다.
작성자 master 작성일2018-12-01 14:41 조회5,201회 댓글1건
// DateTime : 2018-12-01 오후 2:45:45
#include <avr/io.h>
#include <util/delay.h>
#include <avr/interrupt.h>
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
//-RGB LCD 제어 PORT&PIN---------------------------------------------------------------
#define RGB_DATA_DDR                              DDRA //-Data Bus제어 Port
#define RGB_DATA_PORT                             PORTA
#define DATA_D4                                   PA0 //-Data Bus PIN
#define DATA_D5                                   PA1
#define DATA_D6                                   PA2
#define DATA_D7                                   PA3
#define RGB_LCD_DDR                               DDRF //-RGB LCD 제어 Port
#define RGB_LCD_PORT                              PORTF
#define RS_BIT                                    PF2 //-Register Select: LOW-Command,HIGH-Data
#define RW_BIT                                    PF3 //-Read/Wite: LOW-Wite        HIGH-Read
#define EN_BIT                                    PF4 //-Enable Pin: LOW-Disable    HIGH-Enable
#define RED_BIT                                   PF5 //-Red Backlight: LOW-Off        HIGH-On
#define GREEN_BIT                                 PF6 //-Green Backight: LOW-Off     HIGH-On
#define BLUE_BIT                                  PF7 //-Blue Backlight: LOW-Off       HIGH-On
//-RBG LCD 제어관련 상수---------------------------------------------------------------
#define ALL_SET                                   0xff //-모든 Pin 1로 셋
#define ALL_CLEAR                                 0x00 //-모든 Pin 0으로 클리어
#define DDRAM_ADDR                                0x80 //-DD(Display Data)RAM 주소
//-RBG LCD 제어관련 명령어--------------------------------------------------------------
#define CMD_CLEAR_DISPLAY                        0x01 //-CLEAR_DISPLAY(0x01)
#define CMD_RETURN_HOME                          0x02 //-RETURN_HOME(0x02)
#define CMD_ENTRYMODE_SET                        0x06 //-ENTRYMODE_SET(0x04)|Left(0x02)|Shift Decrement(0x00)
#define CMD_DISPLAY_CONTROL                      0x0C //-DISPLAY_CONTROL(0x08)|Display On(0x04)|Cursor Off(0x00)|Blink Off(0x00)
#define CMD_CURSOR_SHIFT_RIGHT                   0x1C //-CURSOR_SHIFT(0x10)|Shift Move(0x08)|Move Right(0x04)
#define CMD_FUNCTION_SET                         0x28 //-FUNCTION_SET(0x02)|4BIT(0x00)|2 Line(0x08)|5x8 Dots(0x00)
#define CMD_8BIT_MODE                            0x03 //-FUNCTION_SET(0x02)|8BIT(0x01)
#define CMD_4BIT_MODE                            0x03 //-FUNCTION_SET(0x02)|4BIT(0x00)
#define DDRAM_FS_ADDR                            0x0
#define DDRAM_EF_ADDR                            0x0F
#define DDRAM_SS_ADDR                            0x40
#define DDRAM_SF_ADDR                            0x4F
#define LX_LIMIT              100 //-LED Off 되는 한계 값 정의
//-LED 관련
#define DDR_LED               DDRD
#define PORT_LED              PORTD
#define LED_ON                0x00
#define LED_OFF               0xF0
//-Temp관련
#define TEMP_ADDR             72 //-온도센서의 Slave 주소
#define TEMP_ADDR_W           TEMP_ADDR<<1 //-Write 주소
#define TEMP_ADDR_R           (TEMP_ADDR<<1)+1 //_ Read 주소
#define TEMP_REG              0 //_ 온도 데이터 저장 Reg.주소
#define TEMP_LIMIT            25 //_ DC Motor ON 되는 한계 값
//-Clock 제어를 위한 선언
#define CPU_CLOCK             16000000 //_ 16MHz
#define SCL_FREQUENCY         400000 //_ 400KHz
//-DC 모터 제어를 위한 정의
#define DCM_DDR               DDRB // B포트를 모두 출력으로
#define DCM_PORT              PORTB // B포트를 모두 출력으로 8칸이 다 1이 출력된다는거임
#define FORWARD_BIT           0
#define BACKWARD_BIT          1
//-온도값 저장 전역 변수 선언
volatile unsigned int  gTempValue//_ 측정된 온도 값 저장
//-USART 제어를 위한 전역 변수 선언
volatile unsigned int gLightValue//-측정된 조도값 저장
/*=====================================함수 선언=========================================================*/
void RGB_LCD_Init(void);
void RGB_LCD_Enable(void);
void RGB_LCD_Write(unsigned char nValue);
void Set4BitMode(void);
void SendText(unsigned char addrCommand,char*szText);
void SendCommandl(unsigned char command);
void SendData(unsigned char data);
void LCD_Display(void);
void ADC_LED_Init(void);
void ADC_Convert(void);
void LED_OnOff(unsigned char nNum);
//_ Temp&ADC
void TEMP_DC_Init(void);
void TEMP_Read(void);
//_ DC Motor
void Run_DCM(void);
void Stop_DCM(void);
void TEMP_DC_Init(void){
  //-DC Motor 초기화
  DCM_DDR|=(1<<FORWARD_BIT)|(1<<BACKWARD_BIT); //-PB0,PB1 비트 Output으로 설정
  DCM_PORT&=~((1<<FORWARD_BIT)|(1<<BACKWARD_BIT)); //-DC모터 구동 정지로 설정
  //-Temp TWI 초기화
  TWSR&=~((1<<TWPS1)|(1<<TWPS0)); //-분주비 설정
  TWBR=(CPU_CLOCK/SCL_FREQUENCY-16)/ 2//-TWI 통신 속도 설정
void TEMP_Read(void){
  unsigned char     arrTemp[2]; //-읽어온 2byte 데이터 저장
  unsigned int      nTmp//-12bit 온도 값 저장
  float             fCValue//-섭씨로 변환한 값 저장
  //-START condition
  TWCR=(1<<TWINT)|(1<<TWSTA)|(1<<TWEN);
  while(!(TWCR&(1<<TWINT)));
  //-Slave Addr+Read 전송
  TWDR=TEMP_ADDR_R;
  TWCR=(1<<TWINT)|(1<<TWEN);
  //-측정된 온도값 읽기
  for(int i=0i<2i++){ TWCR=(1<<TWINT)|(1<<TWEA)|(1<<TWEN); while(!(TWCR&(1<<TWINT))); arrTemp[i]=TWDR; }
  nTmp=arrTemp[0]<<8nTmp=nTmp|arrTemp[1]; nTmp=nTmp>>4//-측정된 12bit 온도 데이터 계산
  fCValue=(float)nTmp*0.0625;                             //-온도값을 섭씨로 변환->data_value*0.0625--------------
  TWCR=(1<<TWINT)|(1<<TWSTO)|(1<<TWEN); _delay_ms(5);     //-STOP condition
  if((int)fCValue>TEMP_LIMIT)Run_DCM(); else Stop_DCM();
  gTempValue=(int)fCValue;                                //-섭씨 온도값 저장
void Run_DCM(void){                                //-DC Motor 동작
  DCM_PORT&=~((1<<FORWARD_BIT)|(1<<BACKWARD_BIT)); //-정방향으로 회전
  DCM_PORT|=(1<<FORWARD_BIT);
void Stop_DCM(void){ DCM_PORT=(1<<FORWARD_BIT)|(1<<BACKWARD_BIT); }
/*=LED관련 함수*/
//-LED On/Off
void LED_OnOff(unsigned char nNum){
  if(nNum==LED_ON)PORT_LED=0x00//-4개 LED ON
  else            PORT_LED=0xF0//-4개 LED OFF
/*=ADC&Light 관련 함수*/
//-ADC&Light 초기화
void ADC_LED_Init(void){
  //-LED 초기화
  DDR_LED|=0xF0PORT_LED|=0xF0;
  //-ADC0 채널,AREF 기준 전압 및 채널을 선택
  ADMUX=0;
  //-채널,활성화,프리스케일 설정
  ADCSRA=(1<<ADEN)|(1<<ADPS2)|(1<<ADPS1)|(1<<ADPS0);
/*==ADC 변환 함수 구현*/
void ADC_Convert(void){
  unsigned int result;
  cli(); //-ADC 변환 중 인터럽트 금지
  ADCSRA|=(1<<ADSC); //-ADC 변환 시작
  while(!(ADCSRA&(1<<ADIF))); //-ADC 변환 완료 신호 대기
  result=ADCL//-변환 결과 저장
  result|=((ADCH&0x03)<<8);
  sei(); //-인터럽트 허용
  if(result>LX_LIMIT)LED_OnOff(LED_OFF); //-CDS Value>50 LED OFF
  else LED_OnOff(LED_ON); //-CDS Value<=50 LED ON
  //-조도값 저장
  gLightValue=result;
void SendCommand(unsigned char command){ //-RBG_LCD 명령어 전달 함수 구현---------------------------------
  RGB_LCD_PORT&=~((1<<RS_BIT)|(1<<RW_BIT)|(1<<EN_BIT)); //-Command 전송을 위한 RS=0,RW=0,EN=0
  RGB_LCD_Write(command>>4); RGB_LCD_Write(command); //-Data Bus에 CMD 쓰기
void SendData(unsigned char data){ //-RBG_LCD 데이터 전달 함수 구현---------------------------------
  RGB_LCD_PORT|=(1<<RS_BIT); RGB_LCD_PORT&=~((1<<RS_BIT)|(1<<EN_BIT)); //-Data 전송을 위한 RS=1,RW=0,EN=0
  RGB_LCD_Write(data>>4); RGB_LCD_Write(data);
void SendText(unsigned char addrCommand,char*szText){ //-RBG_LCD 문자열 출력 함수 구현---------------------------------
  SendCommand(addrCommand); //-DD Ram 주소 전달
  while(*szText!='\0'){ SendData(*szText); szText++; }
void RGB_LCD_Write(unsigned char nValue){ //-RBG_LCD 명령어/데이터 레지스터 기록 구현---------------------------------
  int nTmp=0;
  RGB_DATA_PORT=0x00;
  for(int nldx=0nldx<4nldx++){ nTmp=(nValue>>nldx)&0x01RGB_DATA_PORT|=(nTmp<<(DATA_D4+nldx)); }
  RGB_LCD_Enable();
void RGB_LCD_Enable(void){
  RGB_LCD_PORT|=(1<<EN_BIT); _delay_us(1); RGB_LCD_PORT&=~(1<<EN_BIT); _delay_us(100);
void Set4BitMode(void){ //-RBG_LCD 4bit 인터페이스 설정 구현---------------------------------
  RGB_LCD_Write(CMD_8BIT_MODE); _delay_us(4500);
  RGB_LCD_Write(CMD_8BIT_MODE); _delay_us(150);
  RGB_LCD_Write(CMD_4BIT_MODE);
void RGB_LCD_Init(void){
  RGB_LCD_DDR=((1<<RS_BIT)|(1<<RW_BIT)|(1<<EN_BIT)|(1<<RED_BIT)|(1<<GREEN_BIT)|(1<<BLUE_BIT));
  RGB_LCD_PORT&=~((1<<RS_BIT)|(1<<RW_BIT)|(1<<EN_BIT)|(1<<RED_BIT)|(1<<GREEN_BIT)|(1<<BLUE_BIT));
  RGB_DATA_DDR=ALL_SETRGB_DATA_PORT=ALL_CLEAR//-Data 입력 Pin Output 설정 및 초기화
  Set4BitMode(); //-(2)RGB LCD 인터페이스 설정
  SendCommand(CMD_FUNCTION_SET);    //-(3)RGB LCD 출력을 위한 설정 //-LCD의 행,열,글자 크기 설정
  SendCommand(CMD_DISPLAY_CONTROL); //-디스플레이,커서,문자 깜빡임 On/Off 설정
  SendCommand(CMD_ENTRYMODE_SET);   //-커서 이동 방향,문자 디스플레이 이동 여부 설정
  SendCommand(CMD_CLEAR_DISPLAY);   //-LCD 화연 지우고 커서는 1행 1열 위치,DDRAM AC=0
  RGB_LCD_PORT|=(1<<GREEN_BIT);     //-Green Backlight 켜기
  _delay_us(2000);
void LCD_Display(void){ //-측정된 온도,조도값 LCD에 출력--------------------------
  char arrTmp[16]="",pTmp[4]="";
  itoa(gTempValue,pTmp,10);  strcat(arrTmp,"T: "); strcat(arrTmp,pTmp); strcat(arrTmp,"C");  //-온도값 문자열로 변환
  itoa(gLightValue,pTmp,10); strcat(arrTmp,"L: "); strcat(arrTmp,pTmp); strcat(arrTmp,"Lx "); //-조도값 문자열로 변환
  SendText(DDRAM_ADDR|DDRAM_FS_ADDR,arrTmp);
// DESC:(1)일정 온도 이상이 되면 DC모터를 회전시키고 일정 밝기 이하면 LED를 켜준다.
//-(2)RGB_LCD에 현재 온도와 조도를 표시해 준다.
/*==Main 함수 구현==============*/
int main(void){
  ADC_LED_Init(); //-Light&LED 초기화
  TEMP_DC_Init(); //-Temp&DC 초기화
  RGB_LCD_Init(); //-RGB_LCD 초기화
    TEMP_Read(); //-온도 측정
    ADC_Convert(); //-조도 측정
    LCD_Display(); //-현재 온도.조도 LCD 출력
    _delay_ms(1000);
  return 0;
타이핑 오타는 백만개라고 하더라도 자신이 직접 찾아야합니다.
조회수 5,201
본인 능력으로 오타도 찾지 못할만큼 복잡한 소스라면 이해하는 것도 어려울테니
간단하고 쉬운 예제를 많이 공부한 후에 복잡한 소스를 보시는 것이 힘이 덜 듭니다.
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 11799
공지 사이트 이용 안내댓글[25] master 17-10-29 31123
질문 포토다이오드와의 연결 질문합니다.댓글[4] 이미지새글첨부파일 박윤모 22-08-10 15
질문 회로 구성댓글[4] 새글 픽공부 22-08-10 19
질문 아두이노 센서, 와이파이, 블루투스 연결댓글[1] 새글 pattern 22-08-10 23
질문 PIC 블루투스 연결댓글[19] 픽공부 22-08-09 30
질문 PIC18F452 블루투스 연결댓글[4] 마이컴 22-08-08 25
질문 아두이노 코드 해석을 못하겠습니다...댓글[2] 김가헌 22-08-08 34
질문 아두이노 코드를 avr로 변환해 주세요 ...ㅠ댓글[3] 옹냥냥 22-08-08 27
질문 아두이노 녹음-스피커모듈 관련 질문있습니다 ㅠㅠ댓글[2] 방귀뿡뿡 22-08-08 22
질문 Serial EEPROM 실수값 저장..댓글[2] 이미지첨부파일 광이 22-08-07 21
질문 STM32 Live Expression 값들이 깜빡이는 현상댓글[3] 둠둠 22-08-05 83
질문 아두이노 ESP32 wifi module댓글[1] Yoon 22-08-03 147
질문 atmega128과 dht11, lcd를 연결했는데 0도라고 뜹니다.댓글[1] 고양이33 22-08-02 335
질문 ATMEGA 128 코드를 합치려고 하는데 어렵네요댓글[2] 고양이33 22-08-02 199
질문 서보모터 제어에 대해 질문있습니다.댓글[2] 첨부파일 뉴비에오 22-07-30 137
질문 적외선 통신 알려주실분있나요 ㅠㅠ댓글[1] hkjsj10 22-07-30 136
질문 아두이노 관련 궁금합니다.댓글[1] 뱝뱝 22-07-28 134
질문 아두이노 우노 MCP4725댓글[3] 이미지 opqr 22-07-27 276
질문 레오나르도 인체감지센서 알림 안옴 면지지 22-07-24 194
답변 답변글 답변 : 레오나르도 인체감지센서 알림 안옴 master 22-07-25 134
질문 Uno에서 엔코더값 놓치는 이유가 뭘까요...댓글[3] MAKTUB 22-07-24 143
질문 아두이노 압력센서 연동 질문댓글[4] dbice 22-07-23 226
질문 아두이노 버튼 누르기 문의댓글[1] 김형근 22-07-23 167
질문 HM10 다중페어링댓글[1] ㅎㅋㅎㅋㅎ 22-07-22 192
질문 모터드라이브 선정댓글[6] 이미지 조숩인 22-07-22 267
질문 ad9850 sin파 2댓글[6] 이미지첨부파일 opqr 22-07-21 210
질문 ad9850 sin파 합성댓글[7] 첨부파일 opqr 22-07-20 271
질문 특정값이 n초이상,n번 이상 연속될경우를 감지하는 함수가 있나요댓글[4] 우수 22-07-17 291
질문 delay를 millis함수로 바꾸는데 질문있습니다.댓글[12] 첨부파일 뉴비에오 22-07-16 651
