질문게시판 > 답변 : 아두이노 통신이용할려고 합니다.
TODAY1,590 TOTAL2,159,489
BASIC4MCU | 질문게시판 | 답변 : 아두이노 통신이용할려고 합니다.
작성자 master 작성일2018-12-01 23:23 조회3,512회 댓글0건
// DateTime : 2018-12-01 오후 11:29:07
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2);
#include <SoftwareSerial.h>
SoftwareSerial BT(12,13); //블루투스Tx---D12,블루투스Rx----D13
int out=2;
int s0=3,s1=4,s2=5,s3=6;
int s8=8;
int led_r=9,led_b=10,led_g=11;
byte select=0,flag=0;
byte counter=0,countR=0,countG=0,countB=0;
  BT.begin(9600);
  pinMode(s0,OUTPUT); pinMode(s1,OUTPUT);
  pinMode(s2,OUTPUT); pinMode(s3,OUTPUT);
  pinMode(s8,INPUT);
  pinMode(led_r,OUTPUT); pinMode(led_g,OUTPUT); pinMode(led_b,OUTPUT);
  lcd.init();
  lcd.backlight();
  TCS();
void TCS(){
  select=0;
  digitalWrite(s1,HIGH); digitalWrite(s0,HIGH);
  digitalWrite(s2,LOW); digitalWrite(s3,LOW);
  digitalWrite(s8,HIGH);
  attachInterrupt(0,ISR_INTO,CHANGE);
  timer0_init();
void ISR_INTO(){ counter++; }
void timer0_init(void){
  TCCR2A=0x00TCCR2B=0x07TCNT2=100TIMSK2=0x01//10 ms overflow again
int i=0;
ISR(TIMER2_OVF_vect){ // 10ms
  TCNT2=100;
  select++; flag=select;
  if(select==1){
    countR=counter;
    lcd.setCursor(0,0); lcd.print("countR: "); //Serial.println(countR,DEC);
    digitalWrite(led_r,(countR>120)?HIGHLOW);
    digitalWrite(s2,HIGH); digitalWrite(s3,HIGH);
  else if(select==2){
    countG=counter;
    lcd.setCursor(0,0); lcd.print("countG: "); //Serial.println(countG,DEC);
    digitalWrite(led_g,(countG>110)?HIGHLOW);
    digitalWrite(s2,LOW); digitalWrite(s3,HIGH);
  else if(select==3){
    countB=counter;
    lcd.setCursor(0,0); lcd.print("Hello,world!"); //Serial.println(countB,DEC);
    digitalWrite(led_b,(countB>115)?HIGHLOW);
    select=0;
  counter=0;
  if(flag==1){ flag=0;
    lcd.setCursor(0,0); lcd.print(countR);
    //Serial.println(countR);
    BT.println(countR);
  else if(flag==2){ flag=0;
    lcd.setCursor(5,0); lcd.print(countG);
    //Serial.println(countG);
    BT.println(countG);
  else if(flag==3){ flag=0;
    lcd.setCursor(10,0); lcd.print(countB);
    //Serial.println(countB);
    BT.println(countB);
  if(BT.available()){
    Serial.write(BT.read());
  if(Serial.available()){
    BT.write(Serial.read());
조회수 3,512
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 9620
공지 사이트 이용 안내댓글[24] master 17-10-29 29577
질문 컴퓨터 usb연결시 정상 작동하나 9V건전지 외부전원 연결 시 작동하지 않는 문제댓글[1] 이미지새글첨부파일 보겐을운용 17:26 15
질문 아두이노 dac 연결댓글[1] 이미지새글첨부파일 kodory 16:28 17
질문 아두이노 millis ->atmega128에서 사용하고 싶습니다. 새글 akmong413 16:22 15
답변 답변글 답변 : 아두이노 millis ->atmega128에서 사용하고 싶습니다. 새글 master 17:27 12
질문 아트메가 모터드라이브와 초음파 센서 연동 질문입니다댓글[1] 새글 123424135123q 00:54 19
질문 스텝모터 드라이버 선정 질문드립니다. 새글 아흐흑 22-05-18 18
답변 답변글 답변 : 스텝모터 드라이버 선정 질문드립니다.댓글[1] 이미지새글 master 06:56 15
질문 아두이노로 모터+드라이버 제어댓글[6] 새글 모토 22-05-18 33
질문 온도센서로 서보모터 제어 코딩댓글[1] 새글 진수네1조 22-05-18 38
질문 라즈베리파이 웹캠 데이터 아두이노 전송 (초보)댓글[1] 전자과 22-05-17 34
질문 아두이노 코딩 도와주세요 (초음파센서와 금속감지센서로 서보모터 제어하기) 이현주 22-05-17 57
답변 답변글 답변 : 아두이노 코딩 도와주세요 (초음파센서와 금속감지센서로 서보모터 제어하기) 새글 master 22-05-18 109
질문 아두이노 우노 2개와 앱인벤터끼리의 블루투스 통신 방법댓글[3] 이미지첨부파일 pyoleo 22-05-17 80
질문 졸업작품 첨부파일 ejdog 22-05-16 72
질문 PCB의 커넥터 연결관련 이슈같은데.. 원인을 정확히 모르겠습니다.댓글[2] 이미지 설계못해서개털림 22-05-16 61
질문 STM32F767 사용중인데 발열이 발생합니다.댓글[5] 존클라프 22-05-16 61
질문 리니어 레일 거리 조절댓글[1] 면수 22-05-16 52
질문 아두이노 심전도 센서 BPM 계산댓글[3] 쥬쥬 22-05-16 69
질문 아두이노 서로 다른 전압을 가진 부품 제어 이미지 chovo 22-05-16 49
질문 앱인벤터 질문입니다.댓글[2] 이미지 귀끠우유 22-05-16 55
질문 아두이노 우노끼리 블루투스 통신댓글[1] 첨부파일 pyoleo 22-05-16 61
질문 마이크로 받은 입력을 주파수로 변경댓글[3] 생늧판출 22-05-16 39
질문 while문 안 if문 빠져나오는 방법 kyho3855 22-05-15 33
답변 답변글 답변 : while문 안 if문 빠져나오는 방법댓글[1] master 22-05-16 43
질문 초음파센서로 속도구하기(코드 합치는법) 쥰니 22-05-15 65
답변 답변글 답변 : 초음파센서로 속도구하기(코드 합치는법)댓글[1] master 22-05-16 56
질문 360서보모터 질문입니다댓글[1] 한잔해2 22-05-14 93
질문 아두이노 초보 24V DC 제품 제어댓글[2] 제로펲시 22-05-13 96
