질문게시판 > 답변 : 아두이노 우노 수위센서 응용..전문가님들 부탁드려요!
TODAY465 TOTAL2,171,664
BASIC4MCU | 질문게시판 | 답변 : 아두이노 우노 수위센서 응용..전문가님들 부탁드려요!
작성자 master 작성일2018-12-04 09:26 조회3,998회 댓글0건
// DateTime : 2018-12-04 오전 9:30:51
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2);
const int LevelPin1=A0,LevelPin2=A1,;
const int piezo=7;
const int R=5,G=6,B=9;
char  code[]="CDEFGABc";
int   freq[]={262,294,330,349,392,440,494,523};
const int LevelMax=600;
int Value1,Value2,waterLevel1,waterLevel2;
void color(int r1,int g1,int b1){
  analogWrite(R,r1); analogWrite(G,g1); analogWrite(B,b1);
  lcd.init();         lcd.backlight();
  lcd.setCursor(0,0); lcd.print("ex 6.4");
  lcd.setCursor(0,1); lcd.print("Water Level");
  delay(3000);
  Value1=analogRead(LevelPin1); waterLevel1=map(Value1,0,LevelMax,0,100);
  Value2=analogRead(LevelPin2); waterLevel2=map(Value2,0,LevelMax,0,100);
  lcd.clear();
  lcd.setCursor(0,0); lcd.print("Level1: "); lcd.print(waterLevel1); lcd.print("%");
  lcd.setCursor(0,1); lcd.print("Level2: "); lcd.print(waterLevel2); lcd.print("%");
  noTone(piezo);
  if(waterLevel1<5){
    color(0,0,255); lcd.setCursor(14,1); lcd.print("0");
  else if(waterLevel1<25){
    tone(piezo,freq[0]); color(0,127,255); lcd.setCursor(14,1); lcd.print("1");
  else if(waterLevel1<50){
    tone(piezo,freq[1]); color(127,0,255); lcd.setCursor(14,1); lcd.print("2");
  else if(waterLevel1<75){
    tone(piezo,freq[2]); color(0,255,0); lcd.setCursor(14,1); lcd.print("3");
    if(waterLevel2<5){
      tone(piezo,freq[3]); color(0,255,127); lcd.setCursor(14,1); lcd.print("4");
    else if(waterLevel2<25){
      tone(piezo,freq[4]); color(127,255,0); lcd.setCursor(14,1); lcd.print("5");
    else if(waterLevel2<50){
      tone(piezo,freq[5]); color(255,0,0); lcd.setCursor(14,1); lcd.print("6");
    else if(waterLevel2<75){
      tone(piezo,freq[6]); color(255,0,127); lcd.setCursor(14,1); lcd.print("7");
      tone(piezo,freq[7]); color(255,127,0); lcd.setCursor(14,1); lcd.print("8");
조회수 3,998
공지 사이트 이용 안내댓글[24] master 17-10-29 29789
질문 atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데.. 새글 aasdw 06:28 14
질문 아두이노 간단한 프로그램 새글 행복지수업 22-05-25 20
질문 atmega128 타이머 작성시 키패트 입력으로 인터럽트 사용에 대하여 질문이 있습니다. 이미지새글 마프하나 22-05-25 26
질문 아두이노 스텝모터 리미트 문의드립니다.댓글[2] 이미지새글첨부파일 스트렌져 22-05-24 27
질문 서보모터 제어에 관하여 궁금합니다댓글[3] 이미지첨부파일 오소로롯 22-05-24 46
질문 atmega 128 타이머 작성 중 질문 드립니다.댓글[8] 이미지 마프하나 22-05-23 60
질문 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 어떻게 해…댓글[1] 졸작부수다 22-05-23 185
질문 보드레이트 질문댓글[1] 죠르디 22-05-23 31
질문 atmega 128 블루투스 질문 입니다댓글[1] yhj2644 22-05-23 50
질문 아트메가 공부중에 질문있습니다..댓글[1] suid82 22-05-23 37
질문 Atmega128 UART통신 echo 반복 질문댓글[2] ming2ming 22-05-23 52
질문 아두이노의 지속 시간에 대해 질문합니다. merry 22-05-23 48
답변 답변글 답변 : 아두이노의 지속 시간에 대해 질문합니다. master 22-05-23 34
질문 초음파+스텝모터 도꺼비 22-05-22 36
답변 답변글 답변 : 초음파+스텝모터 master 22-05-23 37
질문 아두이노 인터럽트 질문있습니다.댓글[1] 띵꽁 22-05-22 49
답변 답변글 답변 : 아두이노 인터럽트 질문있습니다.댓글[3] master 22-05-22 45
질문 atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[4] 이미지 마프하나 22-05-22 67
답변 답변글 답변 : atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[1] 이미지 master 22-05-23 48
질문 서보모터제어 해당코드에서 어떤걸 추가해야할까요댓글[3] 이미지첨부파일 오소로롯 22-05-22 47
질문 Atmega128 UART통신에서 ECHO 관련 질문드립니다. dsfdfsa 22-05-22 52
