BASIC4MCU | 질문게시판 | atmega128 4bit LCD 스톱워치
작성자 코딩응애 작성일2018-12-04 19:45 조회28,357회 댓글8건본문
#define F_CPU 16000000L
#include <util/delay.h>#define LCD_WDATA PORTA
#define LCD_WINST PORTA
#define LCD_CTRL PORTD
#define LCD_EN 0
#define LCD_RW 1
#define LCD_RS 2
#define Byte unsigned char#define WGM01 3
#define OCIE0 1
#define CS01 1#define ON 1
#define OFF 0
Byte Temp;
int cnt;
Byte sec,min,hour;void init_timer0(void)
TCCR0|=(1<<WGM01);
OCR0=100;
TIMSK=(1<<OCIE0);
}ISR(TIMER0_COMP_vect)
cnt++;
if(cnt==200000){cnt=0; sec++;}
if(sec>=60){min++; sec=0;}
if(min>=60){hour++; min=0;}
if(hour>=24){hour=0;}
void Portinit(void)
DDRA=0xFF;
DDRD=0x0F;
void LCD_DATA(Byte ch)
LCD_CTRL|=(1<<LCD_RS);
LCD_CTRL&=~(1<<LCD_RW);
LCD_CTRL|=(1<<LCD_EN);
_delay_us(50);
LCD_WDATA=ch;
_delay_us(50);
LCD_CTRL&=~(1<<LCD_EN);
void LCD_Comm(Byte ch)
LCD_CTRL&=~(1<<LCD_RS);
LCD_CTRL|=~(1<<LCD_EN);
_delay_us(50);
LCD_WINST=ch;
_delay_us(50);
void LCD_CHAR(Byte c)
LCD_DATA(c);
_delay_ms(1);
void LCD_STR(Byte *str)
while(*str!=0)
LCD_CHAR(*str);
str++;
}void LCD_pos(unsigned char col, unsigned char row)
LCD_Comm(0x80|(row+col*0x40));
void LCD_Clear(void)
LCD_Comm(0x01);
_delay_ms(2);
}void LCD_init(void)
LCD_Comm(0x38);
_delay_ms(2);
LCD_Comm(0x38);
_delay_ms(2);
LCD_Comm(0x38);
_delay_ms(2);
LCD_Comm(0x0E);
_delay_ms(2);
LCD_Comm(0x06);
_delay_ms(2);
LCD_Clear();
}int main(void)
Byte str1[]="Current Time";
Byte str2[]="00:00:00";
Temp=0;
cnt=0;
sec=min=0;
hour=24;
init_timer0();
TCCR0|=1<<CS01;
Portinit();
LCD_init();
LCD_pos(0,0);
LCD_STR(str1);
LCD_pos(1,0);
LCD_STR(str2);
sei();
LCD_pos(1,5);
LCD_CHAR((min/10)+'0');
LCD_CHAR((min%10)+'0');
LCD_pos(1,8);
LCD_CHAR((sec/10)+'0');
LCD_CHAR((sec%10)+'0');
위코드는 2줄짜리 lcd를 이용한 스톱워치 코드이고
4bit 4line lcd를 사용할건데 코드를 어떻게 바꿔야 할지 모르겠습니다ㅠㅠ 제발 도와주세요ㅠㅠㅠㅠㅠ
댓글 8
조회수 28,357master님의 댓글
제공받은 기본소스 없나요?
코딩응애님의 댓글
코딩응애
#define FUNCSET 0x28 //Function Set
#define ENTMODE 0x06 //Entry Mode Set
#define ALLCLR 0x01 //Clear Display
#define DISPON 0x0c //Display On
#define LINE2 0xC0 //Set DDRAM Address (0x40)
#define LINE3 0x94 //Set DDRAM Address (0x14)
#define LINE4 0xD4 //Set DDRAM Address (0x54)
#define PORT_DATA PORTD
#define DDR_DATA DDRD
//인스트럭션 쓰기 함수
void LCD_write_command(unsigned char byte){
_delay_ms(2);
//인스트럭션 상위 바이트
PORT_DATA = (byte & 0xF0); //데이터
PORT_DATA &= 0xFE; //RS = 0
PORT_DATA &= 0xFD; //RW = 0
_delay_us(1);
PORT_DATA |= 0x04; //E = 1
_delay_us(1);
PORT_DATA &= 0xFB; //E = 0
//인스트럭션 하위 바이트
PORT_DATA = ((byte<<4) & 0xF0);//데이터
_delay_us(1);
_delay_us(1);
void LCD_write_data(unsigned char byte){
_delay_ms(2);
//데이터 상위 바이트
PORT_DATA |= 0x01; //RS = 1
_delay_us(1);
_delay_us(1);
_delay_us(1);
_delay_us(1);
//문자열 출력 함수
void LCD_write_string(char *string){
uint8_t i;
for(i=0; string[i]; i++){ //종료 문자를 만날 때 까지
LCD_write_data(string[i]);
void LCD_init(void){
DDR_DATA = 0xFF; //출력 포트 설정
_delay_ms(15);
LCD_write_command(0x20);
_delay_ms(5);
_delay_us(100);
LCD_write_command(FUNCSET);
LCD_write_command(DISPON);
LCD_write_command(ALLCLR);
LCD_write_command(ENTMODE);
int main(void){
LCD_init(); //LCD 초기화
LCD_write_string("A"); //문자열 출력
LCD_write_command(LINE2); //2번째줄
LCD_write_string("B"); //문자열 출력
LCD_write_command(LINE3); //3번째줄
LCD_write_string("C"); //문자열 출력
LCD_write_command(LINE4); //4번째줄
LCD_write_string("D"); //문자열 출력
while(1);
return 0;
} 처음 LCD 구동 할 때 코드입니다. 이렇게 배웠는데 초시계 기능을 합치려고 하니까 모르겠어서요ㅠㅠ 질문한 코드는 인터넷에 찾아본 코드입니다 !
master 작성일아래 답변글 돌려보셨나요?
코딩응애님의 댓글
코딩응애
네 lcd에 아무것도 안뜨네요ㅜㅜ
질문소스는 8비트 방식이고
답변도 질문소스를 수정한 것이라서 8비트 방식입니다.
아래 3개의 함수만 바꿔주면 4비트로 변경이 가능합니다.
공부해서 변경해보세요
LCD_write_command()
LCD_write_data()
LCD_init()
왼쪽 게시판메뉴 중 디스플레이/LCD 게시판에 4비트 방식의 예제도 있습니다.
코딩응애님의 댓글
코딩응애
#define ALLCLR 0x01
#define DISPON 0x0c
#define DDR_DATA PORTD
#define LINE2 0xC0
#define LINE3 0x94
#define LINE4 0xD4//
volatile Byte flag=0,sec=0,min=0,hour=24;
_delay_us(1);
_delay_us(1);
//인스트럭션 하위 바이트
_delay_us(1);
_delay_us(1);
_delay_us(50);
_delay_ms(2);
//데이터 상위 바이트
_delay_us(1);
_delay_us(1);
_delay_us(1);
_delay_us(1);
_delay_ms(5);
void LCD_CHAR(Byte c){ LCD_write_data(c); }
uint8_t i;
void LCD_Clear(void){ LCD_write_command(0x01); _delay_ms(2); }
DDR_DATA = 0xFF; PORT_DATA &= 0xFB; _delay_ms(50);
LCD_write_command(0x38); LCD_write_command(0x38); LCD_write_command(0x38);
LCD_write_command(0x0E); LCD_write_command(0x06); LCD_Clear();
LCD_write_command(FUNCSET); LCD_write_command(DISPON); LCD_write_command(ALLCLR); LCD_write_command(ENTMODE);
ISR(TIMER0_COMP_vect){
if(++sec>59){ sec=0;
if(++min>59){ min=0; if(++hour>23)hour=0; }
flag=1;
int main(void){
DDRD=0xFF; DDRD=0x0F;
LCD_init();
LCD_write_string("Current Time");
LCD_write_string("00: 00: 00");
TCCR1B=0x0D; OCR1A=15624; TIMSK=0x10; //1sec
SREG=0x80;
if(flag){ flag=0;
LCD_init(); LCD_CHAR((hour/10)+'0'); LCD_CHAR((hour%10)+'0');
LCD_init();
LCD_write_string(" "); LCD_CHAR((min /10)+'0'); LCD_CHAR((min %10)+'0');
LCD_init();
LCD_write_string(" "); LCD_CHAR((sec /10)+'0'); LCD_CHAR((sec %10)+'0');
바꿔보았는데도 구동이 안되네요ㅠㅠ 뭐가 잘못됐는지 알수 있을까요ㅜㅜ?
코딩응애님의 댓글
코딩응애
제어핀과 D4~7 모두 D포트에 연결했습니다!
https://www.basic4mcu.com/bbs/board.php?bo_table=gac&wr_id=6385
이 글은 포트C에 LCD를 연결 했는데요
PC0=RS
PC1=RW
PC2=E
PC3 연결안함
PC4-D4
PC5-D5
PC6-D6
PC7-D7
이렇게 연결 했습니다.
LCD 함수 참고해서 만들어보세요
