질문게시판 > 답변 : avr 빌드 추가 질문입니다.
TODAY742 TOTAL2,272,993
BASIC4MCU | 질문게시판 | 답변 : avr 빌드 추가 질문입니다.
작성자 master 작성일2018-12-06 09:10 조회5,196회 댓글1건
// DateTime : 2018-12-06 오전 9:12:58
#define F_CPU 16000000UL
#include <avr/io.h>
#include <util/delay.h>
#include <stdio.h>
#include <avr/interrupt.h>
#include <math.h>
#define YES 1
#define NO  0
unsigned char door_open=NO;
unsigned int sec=0;
float distance;
void IR_ADC(){
  float val,sum=0unsigned int i=0;
  for(i=0i<=10i++){ val=12343.85*pow(ADC,-1.15); sum+=val_delay_us(200); }
  distance=sum/10;
void Door_first_close(){ PORTC=1_delay_ms(1000); PORTC=0; }
void Door_close(){ PORTC=1; }
void Door_open(){ PORTC=2_delay_ms(1000); PORTC=0; }
ISR(TIMER1_COMPA_vect){
  if(door_open==YES){ sec++; }
  else if(door_open==NO){ PORTC=0cli(); TCCR1B=(1<<WGM12)|(0<<CS12); TCNT1=0sec=0; }
int main(void){
  DDRC=0xFF;
  TCCR1B=(1<<WGM12)|(0<<CS12); OCR1A=62499TIMSK=(1<<OCIE1A);
  ADCSRA=0xE7;
  Door_first_close();
    IR_ADC();
    if(distance<10){
      if(door_open==YES){ sec=2; }
        cli(); Door_open(); TCCR1B=(1<<WGM12)|(1<<CS12); sei();
        door_open=YES;
    if(sec>=3){ sec=0Door_close(); door_open=NO; }
// DateTime : 2018-12-06 오전 9:13:23
Build started 6.12.2018 at 09:12:23
avr-gcc  -mmcu=atmega128 -Wall -gdwarf-2 -std=gnu99                                           -DF_CPU=16000000UL -O1 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT main.o -MF dep/main.o.d  -c  ../main.c
avr-gcc -mmcu=atmega128 -Wl,-u,vfprintf  -lprintf_flt  -lm main.o    -lprintf_flt -lm  -o test.elf
avr-objcopy -O ihex -R .eeprom -R .fuse -R .lock -R .signature  test.elf test.hex
avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" --change-section-lma .eeprom=0 --no-change-warnings -O ihex test.elf test.eep || exit 0
AVR Memory Usage
Deviceatmega128
Program:    5430 bytes (4.1Full)
(.text + .data + .bootloader)
Data:          7 bytes (0.2Full)
(.data + .bss + .noinit)
Build succeeded with 0 Warnings...
4.18에서 에러 안납니다.
컴파일러 옵션 캡쳐해서 올려드릴테니 참고하세요
조회수 5,196
두루미님의 댓글
두루미 작성일
옵션 때문이었네요 감사합니다.
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 11903
공지 사이트 이용 안내댓글[25] master 17-10-29 31173
질문 lcd 1602에 특수문자를 출력하는 방법을 알고싶습니다.댓글[3] dndktn 22-08-12 25
질문 stm32 wifi 파일전송댓글[3] 하리 22-08-11 23
질문 회로 구성 수정댓글[2] 첨부파일 픽공부 22-08-11 29
질문 아두이노 와이파이통신 질문 있습니다댓글[1] 학생 22-08-11 26
질문 포토다이오드와의 연결 질문합니다.댓글[7] 이미지첨부파일 박윤모 22-08-10 42
질문 회로 구성댓글[4] 픽공부 22-08-10 37
질문 아두이노 센서, 와이파이, 블루투스 연결댓글[1] pattern 22-08-10 49
질문 PIC 블루투스 연결댓글[19] 픽공부 22-08-09 56
질문 PIC18F452 블루투스 연결댓글[4] 마이컴 22-08-08 62
질문 아두이노 코드 해석을 못하겠습니다...댓글[2] 김가헌 22-08-08 67
질문 아두이노 코드를 avr로 변환해 주세요 ...ㅠ댓글[3] 옹냥냥 22-08-08 58
질문 아두이노 녹음-스피커모듈 관련 질문있습니다 ㅠㅠ댓글[2] 방귀뿡뿡 22-08-08 45
질문 Serial EEPROM 실수값 저장..댓글[2] 이미지첨부파일 광이 22-08-07 38
질문 STM32 Live Expression 값들이 깜빡이는 현상댓글[3] 둠둠 22-08-05 113
질문 아두이노 ESP32 wifi module댓글[1] Yoon 22-08-03 178
질문 atmega128과 dht11, lcd를 연결했는데 0도라고 뜹니다.댓글[1] 고양이33 22-08-02 426
질문 ATMEGA 128 코드를 합치려고 하는데 어렵네요댓글[2] 고양이33 22-08-02 233
질문 서보모터 제어에 대해 질문있습니다.댓글[2] 첨부파일 뉴비에오 22-07-30 157
질문 적외선 통신 알려주실분있나요 ㅠㅠ댓글[1] hkjsj10 22-07-30 147
질문 아두이노 관련 궁금합니다.댓글[1] 뱝뱝 22-07-28 138
질문 아두이노 우노 MCP4725댓글[3] 이미지 opqr 22-07-27 292
질문 레오나르도 인체감지센서 알림 안옴 면지지 22-07-24 225
답변 답변글 답변 : 레오나르도 인체감지센서 알림 안옴 master 22-07-25 160
질문 Uno에서 엔코더값 놓치는 이유가 뭘까요...댓글[3] MAKTUB 22-07-24 163
질문 아두이노 압력센서 연동 질문댓글[4] dbice 22-07-23 271
질문 아두이노 버튼 누르기 문의댓글[1] 김형근 22-07-23 195
질문 HM10 다중페어링댓글[1] ㅎㅋㅎㅋㅎ 22-07-22 207
질문 모터드라이브 선정댓글[6] 이미지 조숩인 22-07-22 297
