BASIC4MCU | 질문게시판 | 답변 : 답변 : 답변 : ATmega128_V20.h 헤더파일 관련하여...
작성자 master 작성일2018-12-06 16:39 조회4,815회 댓글2건
https://www.basic4mcu.com/bbs/board.php?bo_table=gac&wr_id=6450
작성일
// MCU BASIC: https://www.basic4mcu.com// DateTime : 2018-12-06 오후 10:54:13// by Ok-Hyun Park//#define F_CPU 16000000UL // 16 MHz#include <avr/io.h>#include <stdio.h>#include <avr/interrupt.h>#include <util/delay.h>//char str[30];//--------------------------------------------------------------------#define LCD_DB_PORT PORTA // LCD_DATABUS#define LCD_DB_DDR DDRA#define LCD_CMD_PORT PORTC // LCD_COMMAND#define LCD_CMD_DDR DDRC//void LCD_cmd(char c){LCD_DB_PORT=c; LCD_CMD_PORT=1; _delay_us(1); LCD_CMD_PORT=0; _delay_ms(3);}//void LCD_data(char d){LCD_DB_PORT=d; LCD_CMD_PORT=3; _delay_us(1); LCD_CMD_PORT=2; _delay_us(50);}//void LCD_str(char *s){ while(*s)LCD_data(*s++); }//void LCD_init(void){_delay_ms(50);LCD_cmd(0x38); // Function set(data length-8bit,2행,5x8dote)LCD_cmd(0x0C); // Display on/off control(화면출력 ON,커서표시&커서깜빡임 OFF)LCD_cmd(0x06); // Entry mode set(커서 오른쪽 이동,화면이동 OFF)LCD_cmd(0x01); // Clear display}//--------------------------------------------------------------------ISR(TIMER0_OVF_vect){ // 9.984msstatic int ms10=0; static char key=0;//TCNT0=100;//if((PINB&1)==0)key=1; // PB0(key1)//if(key){ // key=1이 되면PORTB|=0x20; // led켜짐if(++ms10==500){ ms10=0; PORTB&=0x0F; key=0; } // 5000ms뒤 리셋, LED OFF}}//int main(){int i=0; //,a=0,b=0,j=0,k=0,adresult[2];//DDRB=0xF0; // LED(PB4~PB7) // KEY(PB0)//DDRG=0x08; // 부저_delay_ms(50);LCD_init();TCNT0=100; TCCR0=7; TIMSK=1; // 9.984msADCSRA=0xE7;SREG=0x80;while(1){ADMUX=0x46; _delay_ms(1); i=ADC; // PF6LCD_cmd(0x80);if(i<500){ PORTB&=~0x10; sprintf(str,"Detecting %4d",i); } // 가변저항else { PORTB|=0x10; sprintf(str,"alarming %4d",i);PORTG|=8; _delay_ms(50); PORTG&=~8; // alarm 부저}LCD_str(str);//ADMUX=0x47; _delay_ms(1); i=ADC; // PF7LCD_cmd(0xc0);if(i<600){ PORTB&=~0x40; sprintf(str,"Dark %4d",i); }else { PORTB|=0x40; sprintf(str,"Light %4d",i); }LCD_str(str);//_delay_ms(50);}}
LCD 동작 확인하고
스위치와 부저 LED 등은 어려운 것이 아니니 직접 만들어보세요
댓글 2
조회수 4,815답이없넹님의 댓글
답이없넹 작성일네 LED도 있긴 한데 주신 소스에서 ERROR가 뜨네요 ...
컴파일 오류 수정했습니다.
