질문게시판 > atmega128 lcd 질문입니다ㅜ
TODAY165 TOTAL2,271,632
BASIC4MCU | 질문게시판 | atmega128 lcd 질문입니다ㅜ
작성자 코딩응애 작성일2018-12-07 17:15 조회5,431회 댓글0건
시 분 초 나오는 타이머가 나오게 4bit 4줄짜리 LCD를 구동하려는데
#define F_CPU 16000000
#define FUNCSET 0x28 //Function Set
#define ENTMODE 0x06 //Entry Mode Set
#define ALLCLR 0x01 //Clear Display
#define DISPON 0x0c //Display On
#define LINE2 0xC0 //Set DDRAM Address (0x40)
#define LINE3 0x94 //Set DDRAM Address (0x14)
#define LINE4 0xD4 //Set DDRAM Address (0x54)
#define PORT_DATA PORTD
#define DDR_DATA DDRD
#define Byte unsigned char
volatile Byte flag=0,sec=0,min=0,hour=24;
//인스트럭션 쓰기 함수
void LCD_write_command(unsigned char byte){
 _delay_ms(2);
 //인스트럭션 상위 바이트
 PORT_DATA = (byte & 0xF0); //데이터
 PORT_DATA &= 0xFE; //RS = 0
 PORT_DATA &= 0xFD; //RW = 0
 _delay_us(1);
 PORT_DATA |= 0x04; //E = 1
 _delay_us(1);
 PORT_DATA &= 0xFB; //E = 0
 //인스트럭션 하위 바이트
 PORT_DATA = ((byte<<4) & 0xF0);//데이터
 _delay_us(1);
 _delay_us(1);
void LCD_write_data(unsigned char byte){
 _delay_ms(2);
 //데이터 상위 바이트
 PORT_DATA |= 0x01; //RS = 1
 _delay_us(1);
 _delay_us(1);
 _delay_us(1);
 _delay_us(1);
//문자열 출력 함수
void LCD_write_string(char *string){
 uint8_t i;
 for(i=0; string[i]; i++){ //종료 문자를 만날 때 까지
  LCD_write_data(string[i]);
void LCD_init(void){
 DDR_DATA = 0xFF; //출력 포트 설정
 _delay_ms(15);
 LCD_write_command(0x20);
 _delay_ms(5);
 _delay_us(100);
 LCD_write_command(FUNCSET);
 LCD_write_command(DISPON);
 LCD_write_command(ALLCLR);
 LCD_write_command(ENTMODE);
ISR(TIMER0_COMP_vect){
 if(++sec>59) sec=0;
 if(++min>59) min=0;
 if(++hour>23) hour=0;
 flag=1;
void LCD_CHAR(Byte c){ LCD_write_data(c); }
void LCD_STR(Byte *s){ while(*s)LCD_CHAR(*s++); }
int main(void){
 Byte str1[]="Current Time"; Byte str2[]="00:00:00";
 LCD_init(); //LCD 초기화
 LCD_STR(str1); //문자열 출력
 LCD_write_command(LINE2); //2번째줄
 LCD_STR(str2);
 TCCR1B=0x0D;  OCR1A=15624; TIMSK=0x10;
 SREG=0x80;
  if(flag){flag=0;
  LCD_init(); LCD_CHAR((hour/10)+'0'); LCD_CHAR((hour%10)+'0');
  LCD_init();
  LCD_write_string("   "); LCD_CHAR((min /10)+'0'); LCD_CHAR((min %10)+'0');
  LCD_init();
 LCD_write_string("      "); LCD_CHAR((sec /10)+'0'); LCD_CHAR((sec %10)+'0');};
 return 0; }
build는 되는데 시간이 가지않습니다.
모두 D포트에 연결되어 있습니다ㅠㅠ
조회수 5,431
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 11837
공지 사이트 이용 안내댓글[25] master 17-10-29 31143
질문 lcd 1602에 특수문자를 출력하는 방법을 알고싶습니다.댓글[3] 새글 dndktn 22-08-12 20
질문 stm32 wifi 파일전송댓글[2] 새글 하리 22-08-11 17
질문 회로 구성 수정댓글[2] 새글첨부파일 픽공부 22-08-11 19
질문 아두이노 와이파이통신 질문 있습니다댓글[1] 새글 학생 22-08-11 19
질문 포토다이오드와의 연결 질문합니다.댓글[7] 이미지첨부파일 박윤모 22-08-10 23
질문 회로 구성댓글[4] 픽공부 22-08-10 25
질문 아두이노 센서, 와이파이, 블루투스 연결댓글[1] pattern 22-08-10 30
질문 PIC 블루투스 연결댓글[19] 픽공부 22-08-09 31
질문 PIC18F452 블루투스 연결댓글[4] 마이컴 22-08-08 29
질문 아두이노 코드 해석을 못하겠습니다...댓글[2] 김가헌 22-08-08 35
질문 아두이노 코드를 avr로 변환해 주세요 ...ㅠ댓글[3] 옹냥냥 22-08-08 30
질문 아두이노 녹음-스피커모듈 관련 질문있습니다 ㅠㅠ댓글[2] 방귀뿡뿡 22-08-08 25
질문 Serial EEPROM 실수값 저장..댓글[2] 이미지첨부파일 광이 22-08-07 23
질문 STM32 Live Expression 값들이 깜빡이는 현상댓글[3] 둠둠 22-08-05 103
질문 아두이노 ESP32 wifi module댓글[1] Yoon 22-08-03 173
질문 atmega128과 dht11, lcd를 연결했는데 0도라고 뜹니다.댓글[1] 고양이33 22-08-02 400
질문 ATMEGA 128 코드를 합치려고 하는데 어렵네요댓글[2] 고양이33 22-08-02 226
질문 서보모터 제어에 대해 질문있습니다.댓글[2] 첨부파일 뉴비에오 22-07-30 148
질문 적외선 통신 알려주실분있나요 ㅠㅠ댓글[1] hkjsj10 22-07-30 144
질문 아두이노 관련 궁금합니다.댓글[1] 뱝뱝 22-07-28 135
질문 아두이노 우노 MCP4725댓글[3] 이미지 opqr 22-07-27 281
질문 레오나르도 인체감지센서 알림 안옴 면지지 22-07-24 198
답변 답변글 답변 : 레오나르도 인체감지센서 알림 안옴 master 22-07-25 134
질문 Uno에서 엔코더값 놓치는 이유가 뭘까요...댓글[3] MAKTUB 22-07-24 144
질문 아두이노 압력센서 연동 질문댓글[4] dbice 22-07-23 236
질문 아두이노 버튼 누르기 문의댓글[1] 김형근 22-07-23 169
질문 HM10 다중페어링댓글[1] ㅎㅋㅎㅋㅎ 22-07-22 194
질문 모터드라이브 선정댓글[6] 이미지 조숩인 22-07-22 272
