질문게시판 > 답변 : atmega 128 소스합치기
인기검색어 > 아두이노 센서 ATMEGA128
최신글 질문게시판 동영상강좌 가입하기
▼ BASIC4MCU 후원업체 신제품 정보 ▼
▲ BASIC4MCU 후원업체 신제품 정보 ▲
BASIC4MCU > 질문게시판
작성자 master 작성일18-12-08 17:00 조회3,400회 댓글0건
// DateTime : 2018-12-08 오후 5:06:15
#define F_CPU 16000000
#include <avr/io.h>
#include <util/delay.h>
#include <avr/interrupt.h>
#include <stdio.h>
#include "UART1.h"
FILE OUTPUT\
=FDEV_SETUP_STREAM(UART1_transmit,NULL,_FDEV_SETUP_WRITE);
FILE INPUT\
=FDEV_SETUP_STREAM(NULL,UART1_receive,_FDEV_SETUP_READ);
#define FUNCSET 0x28 //Function Set
#define ENTMODE 0x06 //Entry Mode Set
#define ALLCLR  0x01 //Clear Display
#define DISPON  0x0c //Display On
#define LINE2   0xC0 //Set DDRAM Address(0x40)
#define LINE3   0x94 //Set DDRAM Address(0x14)
#define LINE4   0xD4 //Set DDRAM Address(0x54)
#define PORT_DATA PORTD
#define DDR_DATA  DDRD
#define Byte unsigned char
volatile Byte flag=0,sec=0,min=0,hour=0,temperature=0;
voidADC_init(unsigned char channel)
  ADMUX|=(1<<REFS0); // AVCC를기준전압으로선택
  ADCSRA|=0x07// 분주비설정
  ADCSRA|=(1<<ADEN); // ADC 활성화
  ADCSRA|=(1<<ADFR); // 프리러닝모드
  ADMUX|=((ADMUX&0xE0)|channel); // 채널선택
  ADCSRA|=(1<<ADSC); // 변환시작
intread_ADC(void)
  while(!(ADCSRA&(1<<ADIF))); // 변환종료대기
  return ADC// 10비트값을반환
void LCD_CMD(unsigned char byte){
  PORT_DATA=(byte&0xF0)|4_delay_us(1); PORT_DATA&=0xFB;
  PORT_DATA=(byte<<0x4)|4_delay_us(1); PORT_DATA&=0xFB_delay_ms(3);
void LCD_CHAR(unsigned char byte){
  PORT_DATA=(byte&0xF0)|5_delay_us(1); PORT_DATA&=0xFB;
  PORT_DATA=(byte<<0x4)|5_delay_us(1); PORT_DATA&=0xFB_delay_us(50);
void LCD_STR(Byte*s){ while(*s)LCD_CHAR(*s++); }
void LCD_INIT(void){
  DDR_DATA=0xFF_delay_ms(15); LCD_CMD(0x20); LCD_CMD(0x20); LCD_CMD(0x20);
  LCD_CMD(FUNCSET); LCD_CMD(DISPON); LCD_CMD(ALLCLR); LCD_CMD(ENTMODE);
ISR(TIMER1_COMPA_vect){
  if(++sec>59){ sec=0;
    if(++min>59){ min=0if(++hour>23)hour=0; }
  flag=1;
int main(void){
  int read,temperature;
  float input_voltage;
  Byte str1[]="Current Time"Byte str2[]=" 00: 00: 00";
  Byte str3[]="Temperature"Byte str4[]=" 00 C";
  LCD_INIT();
  LCD_STR(str1);
  LCD_CMD(LINE2); LCD_STR(str2);
  TCCR1B=0x0DOCR1A=15624TIMSK=0x10;
  stdout=&OUTPUT;
  stdin=&INPUT;
  UART1_init(); // UART 통신초기화
  ADC_init(3); // AD 변환기초기화.채널3 사용
  SREG=0x80;
    if(flag){ flag=0;
      LCD_CMD(LINE2);
      LCD_CHAR(' '); LCD_CHAR((hour/10)+'0'); LCD_CHAR((hour%10)+'0'); LCD_CHAR(': ');
      LCD_CHAR((min /10)+'0'); LCD_CHAR((min%10)+'0'); LCD_CHAR(': ');
      LCD_CHAR((sec /10)+'0'); LCD_CHAR((sec%10)+'0');
      LCD_CMD(LINE4);
      LCD_CHAR(' '); LCD_CHAR(temperature); LCD_CHAR(' C');
    read=read_ADC(); // ADC 값읽기
    // 0에서1023 사이의값을0V에서5V 사이값으로변환한다.
    input_voltage=read*5.0/1023.0;
    // 10mV에1℃이므로100을곱해서현재온도를얻는다.
    temperature=(int)(input_voltage*100.0);
    printf("%d\r\n",temperature);
    _delay_ms(1000); // 1초에한번읽음
  • 카카오톡으로 보내기
댓글 : 0
조회수 : 3,400
BASIC4MCU > 질문게시판 목록
제목 날짜
질문 앱인벤터 list index too large 오류 질… 첨부파일PT규 새글 22-07-07
질문 Atmega IO핀 출력 상태 질문이요.. 댓글[3] chelsea 새글 22-07-06
답변 답변 : Atmega IO핀 출력 상태 질문이요.. 댓글[6] master 새글 22-07-06
질문 아두이노 센서 쉴드 v5.0 과 음성인식 모듈(V2)통… 댓글[6] 첨부파일AutoSun  22-07-05
질문 초음파 센서를 사용한 dc모터 제어에 관해 질문 있습니… 첨부파일뉴비에오  22-07-04
답변 답변 : 초음파 센서를 사용한 dc모터 제어에 관해 질… 댓글[2] master  22-07-05
질문 아두이노 Sensor Shield 5.0 시리얼 통신 … 댓글[2] AutoSun  22-07-04
질문 Atmega 코드 좀 봐주세요. 댓글[1] 첨부파일chelsea  22-07-04
PC버전
