// FILE: dht.cpp
// AUTHOR: Rob Tillaart
// VERSION: 0.1.07
// PURPOSE: DHT Temperature&Humidity Sensor library for Arduino
// URL: http: //arduino.cc/playground/Main/DHTLib
// HISTORY:
// 0.1.07 added support for DHT21
// 0.1.06 minimize footprint(2012-12-27)
// 0.1.05 fixed negative temperature bug(thanks to Roseman)
// 0.1.04 improved readability of code using DHTLIB_OK in code
// 0.1.03 added error values for temp and humidity when read failed
// 0.1.02 added error codes
// 0.1.01 added support for Arduino 1.0,fixed typos(31/12/2011)
// 0.1.0 by Rob Tillaart(01/04/2011)
// inspired by DHT11 library
// Released to the public domain
#include "dht.h"
#define TIMEOUT 10000
// PUBLIC
// return values:
// DHTLIB_OK
// DHTLIB_ERROR_CHECKSUM
// DHTLIB_ERROR_TIMEOUT
int dht:: read11(uint8_t pin){
// READ VALUES
int rv=read(pin);
if(rv!=DHTLIB_OK){
humidity =DHTLIB_INVALID_VALUE; // invalid value,or is NaN prefered?
temperature=DHTLIB_INVALID_VALUE; // invalid value
return rv;
// CONVERT AND STORE
humidity =bits[0]; // bit[1]==0;
temperature=bits[2]; // bits[3]==0;
// TEST CHECKSUM
// bits[1]&&bits[3]both 0
uint8_t sum=bits[0]+bits[2];
if(bits[4]!=sum)return DHTLIB_ERROR_CHECKSUM;
return DHTLIB_OK;
// return values:
// DHTLIB_OK
int dht:: read21(uint8_t pin){
return read22(pin); // dataformat identical to DHT22
// return values:
// DHTLIB_OK
int dht:: read22(uint8_t pin){
// READ VALUES
int rv=read(pin);
if(rv!=DHTLIB_OK){
return rv; // propagate error value
humidity=word(bits[0],bits[1])*0.1;
if(bits[2]&0x80){ temperature=-0.1*word(bits[2]&0x7F,bits[3]); } // negative temperature
else { temperature= 0.1*word(bits[2],bits[3]); }
// TEST CHECKSUM
uint8_t sum=bits[0]+bits[1]+bits[2]+bits[3];
return DHTLIB_OK;
// PRIVATE
// return values:
// DHTLIB_OK
int dht:: read(uint8_t pin){
// INIT BUFFERVAR TO RECEIVE DATA
uint8_t cnt=7;
uint8_t idx=0;
// EMPTY BUFFER
for(uint8_t i=0; i<5; i++)bits[i]=0;
// REQUEST SAMPLE
pinMode(pin,OUTPUT);
digitalWrite(pin,LOW ); delay(20);
digitalWrite(pin,HIGH); delayMicroseconds(40);
pinMode(pin,INPUT);
// GET ACKNOWLEDGE or TIMEOUT
unsigned int loopCnt=TIMEOUT;
while(digitalRead(pin)==LOW){ if(loopCnt--==0)return DHTLIB_ERROR_TIMEOUT; }
loopCnt=TIMEOUT;
while(digitalRead(pin)==HIGH){ if(loopCnt--==0)return DHTLIB_ERROR_TIMEOUT; }
// READ THE OUTPUT-40 BITS=>5 BYTES
for(uint8_t i=0;i<40;i++){
loopCnt=TIMEOUT;
unsigned long t=micros();
loopCnt=TIMEOUT;
if((micros()-t)>40)bits[idx]|=(1<<cnt);
if(cnt==0){ cnt=7; idx++; } // next byte?
else { cnt--; }
return DHTLIB_OK;
// END OF FILE
