질문게시판 > 아두이노 코드를 atmega128코드로 변환하고싶습니다!
인기검색어 > 아두이노 센서 ATMEGA128
최신글 질문게시판 동영상강좌 가입하기
▼ BASIC4MCU 후원업체 신제품 정보 ▼
▲ BASIC4MCU 후원업체 신제품 정보 ▲
BASIC4MCU > 질문게시판
작성자 은리스탈 작성일18-12-10 10:09 조회17,082회 댓글5건
첨부파일
/*  Pulse Sensor Amped 1.5    by Joel Murphy and Yury Gitman   http://www.pulsesensor.com
----------------------  Notes ----------------------  ----------------------
This code:
1) Blinks an LED to User's Live Heartbeat   PIN 13
2) Fades an LED to User's Live HeartBeat    PIN 5
3) Determines BPM
4) Prints All of the Above to Serial
Read Me:
https://github.com/WorldFamousElectronics/PulseSensor_Amped_Arduino/blob/master/README.md
#define PROCESSING_VISUALIZER 1
#define SERIAL_PLOTTER  2
//  Variables
int pulsePin = 0;                 // Pulse Sensor purple wire connected to analog pin 0
int blinkPin = 13;                // pin to blink led at each beat
int fadePin = 5;                  // pin to do fancy classy fading blink at each beat
int fadeRate = 0;                 // used to fade LED on with PWM on fadePin
// Volatile Variables, used in the interrupt service routine!
volatile int BPM;                   // int that holds raw Analog in 0. updated every 2mS
volatile int Signal;                // holds the incoming raw data
volatile int IBI = 600;             // int that holds the time interval between beats! Must be seeded!
volatile boolean Pulse = false;     // "True" when User's live heartbeat is detected. "False" when not a "live beat".
volatile boolean QS = false;        // becomes true when Arduoino finds a beat.
// SET THE SERIAL OUTPUT TYPE TO YOUR NEEDS
// PROCESSING_VISUALIZER works with Pulse Sensor Processing Visualizer
//      https://github.com/WorldFamousElectronics/PulseSensor_Amped_Processing_Visualizer
// SERIAL_PLOTTER outputs sensor data for viewing with the Arduino Serial Plotter
//      run the Serial Plotter at 115200 baud: Tools/Serial Plotter or Command+L
static int outputType = SERIAL_PLOTTER;
  pinMode(blinkPin,OUTPUT);         // pin that will blink to your heartbeat!
  pinMode(fadePin,OUTPUT);          // pin that will fade to your heartbeat!
  Serial.begin(115200);             // we agree to talk fast!
  interruptSetup();                 // sets up to read Pulse Sensor signal every 2mS
   // IF YOU ARE POWERING The Pulse Sensor AT VOLTAGE LESS THAN THE BOARD VOLTAGE,
   // UN-COMMENT THE NEXT LINE AND APPLY THAT VOLTAGE TO THE A-REF PIN
//   analogReference(EXTERNAL);
//  Where the Magic Happens
    serialOutput() ;
  if (QS == true){     // A Heartbeat Was Found
                       // BPM and IBI have been Determined
                       // Quantified Self "QS" true when arduino finds a heartbeat
        fadeRate = 255;         // Makes the LED Fade Effect Happen
                                // Set 'fadeRate' Variable to 255 to fade LED with pulse
        serialOutputWhenBeatHappens();   // A Beat Happened, Output that to serial.
        QS = false;                      // reset the Quantified Self flag for next time
  ledFadeToBeat();                      // Makes the LED Fade Effect Happen
  delay(20);                             //  take a break
void ledFadeToBeat(){
    fadeRate -= 15;                         //  set LED fade value
    fadeRate = constrain(fadeRate,0,255);   //  keep LED fade value from going into negative numbers!
    analogWrite(fadePin,fadeRate);          //  fade LED
아두이노 보드에 심박센서를 이용한 심박 측정기를 만드는 소스코드입니다. 제가  ATmega128 보드를 사용하고 싶은데 소스코드를 어떻게 바꿔야할지 모르겠습니다. 제가 가진 ATmega128 보드엔 D포트와 E포트 두가지만 사용이 가능합니다. LCD는 부착 되어있습니다. 위의 소스코드와 첨부한 소스코드를 한번 봐주시고 맞는지와 변환한 소스코드를 알려주시면 감사하겠습니다ㅠ
  • 카카오톡으로 보내기
댓글 : 5
조회수 : 17,082
https://www.google.co.kr/search?q=atmega128+%EC%8B%AC%EB%B0%95%EC%84%BC%EC%84%9C&oq=atmega128+%EC%8B%AC%EB%B0%95%EC%84%BC%EC%84%9C&aqs=chrome..69i57.5628j0j7&sourceid=chrome&ie=UTF-8
ATmega128로된 예제소스를 찾아서 공부하세요
은리스탈님의 댓글
은리스탈 댓글의 댓글작성일
다 찾아보고 해도 ATmega128로 된 오픈소스가 없어서 공부를 못하고 있습니다..ㅠ 도와주세요ㅠ
BPM값을 읽었다고 치고
AVR 모듈에 표시는 어떻게 할건가요?
나머지 부분은 할 수 있나요?
아나로그 값을 읽으려면 포트F를 사용해야 합니다.
은리스탈님의 댓글
은리스탈 댓글의 댓글작성일
ADC 포트가 하나 있는데 그 부분을 사용하면 가능할까요?
master 댓글의 댓글작성일
회로도 및 예제소스 등
가지고 있는 모든 자료를 첨부하셔야지 체크가 가능합니다.
BASIC4MCU > 질문게시판 목록
제목 날짜
질문 atmega128 uart 질문입니다. 댓글[1] bme12 새글 01:03
질문 라즈베리파이에 풀 프레임 이미지센서 활용에 대한 질문이… 첨부파일KYLO 새글 23-06-04
질문 아두이노 시리얼 번호를 이용해 led 제어 wnion 새글 23-06-04
질문 ATMEGA128 혹시 여기서 왜 인터럽트 기능이 안되… IEEE 새글 23-06-04
질문 stm32f767을 이용해서 자이로가속도 센서의 값 받… rlchwjswk 새글 23-06-03
질문 아두이노 모터제어 관련해서 질문드립니다! 댓글[1] 첨부파일아두이노어렵잖아 새글 23-06-03
질문 atmega128 디지털조도센서 코드오류 댓글[1] 까미  23-06-02
질문 atmega128 디지털 조도 센서 댓글[1] 까미  23-06-02
질문 적외선리모콘으로 부저를제어 하는방법 질문입니다. 댓글[4] Tell  23-06-02
질문 lora 무선 모듈에 관한 질문입니다. 댓글[1] 로이스10  23-06-01
질문 적외선 송수신기 DC모터2개 제어 질문입니다. 댓글[5] Tell  23-06-01
질문 스텝모터 제어 코드 질문 댓글[5] pmh11  23-05-31
질문 초음파 센서를 이용한 인원 카운팅 댓글[1] 초음파야  23-05-31
질문 모터 Hall 스위치 연결 문의 댓글[1] 오후  23-05-31
질문 아두이노 lcd 문자 스크롤디스플레이 wnion  23-05-31
답변 답변 : 아두이노 lcd 문자 스크롤디스플레이 댓글[1] master  23-05-31
질문 아두이노 타이머 인터럽트 미ㅏㄴㅇ  23-05-30
답변 답변 : 아두이노 타이머 인터럽트 댓글[6] master  23-05-30
질문 THC-Soil Sensor with TTL 모듈 아두… 댓글[1] ppiickle  23-05-30
질문 stm32 psd센서구동 질문 댓글[2] 수포자  23-05-29
질문 앱인벤터 아두이노 보드 LCD 글씨 나타내기 질문 댓글[7] 당찬병아리  23-05-29
질문 atmega128 led와 fan 댓글[3] 이라  23-05-28
질문 stm32f767 스텝모터 속도 질문있습니다 123132  23-05-27
답변 답변 : stm32f767 스텝모터 속도 질문있습니다 master  23-05-28
질문 아트메가 128 코딩 오류 질문입니다. 댓글[1] 태태킴  23-05-27
질문 스텝모터 제어하는 소스파일인데 질문있습니다. Bs드리프터  23-05-27
답변 답변 : 스텝모터 제어하는 소스파일인데 질문있습니다. master  23-05-27
질문 모터 컨트롤러와 웜기어 모터 연결 문의 드립니다 댓글[1] 오후에  23-05-27
PC버전
