질문게시판 > atmega 128 lcd와 온도센서 합친코드
TODAY659 TOTAL2,583,771
BASIC4MCU | 질문게시판 | atmega 128 lcd와 온도센서 합친코드
작성자 코딩응애 작성일2018-12-10 18:34 조회6,612회 댓글1건
첨부파일
#define F_CPU 16000000
#include <stdio.h>
#include "UART1.h"
FILE OUTPUT\
=FDEV_SETUP_STREAM(UART1_transmit,NULL,_FDEV_SETUP_WRITE);
FILE INPUT\
=FDEV_SETUP_STREAM(NULL,UART1_receive,_FDEV_SETUP_READ);
#define FUNCSET 0x28 //Function Set
#define ENTMODE 0x06 //Entry Mode Set
#define ALLCLR  0x01 //Clear Display
#define DISPON  0x0c //Display On
#define LINE2   0xC0 //Set DDRAM Address(0x40)
#define LINE3   0x94 //Set DDRAM Address(0x14)
#define LINE4   0xD4 //Set DDRAM Address(0x54)
#define PORT_DATA PORTD
#define DDR_DATA  DDRD
#define Byte unsigned char
volatile Byte flag=0,sec=0,min=0,hour=0;
void ADC_init(unsigned char channel)
 ADMUX|=(1<<REFS0); // AVCC를기준전압으로선택
 ADCSRA|=0x07; // 분주비설정
 ADCSRA|=(1<<ADEN); // ADC 활성화
 ADCSRA|=(1<<ADFR); // 프리러닝모드
 ADMUX|=((ADMUX&0xE0)|channel); // 채널선택
 ADCSRA|=(1<<ADSC); // 변환시작
int read_ADC(void)
 while(!(ADCSRA&(1<<ADIF))); // 변환종료대기
 return ADC; // 10비트값을반환
void LCD_CMD(unsigned char byte){
 PORT_DATA=(byte&0xF0)|4; _delay_us(1); PORT_DATA&=0xFB;
 PORT_DATA=(byte<<0x4)|4; _delay_us(1); PORT_DATA&=0xFB; _delay_ms(3);
void LCD_CHAR(unsigned char byte){
 PORT_DATA=(byte&0xF0)|5; _delay_us(1); PORT_DATA&=0xFB;
 PORT_DATA=(byte<<0x4)|5; _delay_us(1); PORT_DATA&=0xFB; _delay_us(50);
void LCD_STR(Byte*s){ while(*s)LCD_CHAR(*s++); }
void LCD_INIT(void){
 DDR_DATA=0xFF; _delay_ms(15); LCD_CMD(0x20); LCD_CMD(0x20); LCD_CMD(0x20);
 LCD_CMD(FUNCSET); LCD_CMD(DISPON); LCD_CMD(ALLCLR); LCD_CMD(ENTMODE);
ISR(TIMER1_COMPA_vect){
 if(++sec>59){ sec=0;
  if(++min>59){ min=0; if(++hour>23)hour=0; }
 flag=1;
int main(void){
 int read,temperature;
 float input_voltage;
 Byte str1[]="Current Time"; Byte str2[]=" 00:00:00";
 Byte str3[]="Temperature"; Byte str4[]=" 00C";
 LCD_INIT();
 LCD_STR(str1);
 LCD_CMD(LINE2); LCD_STR(str2);
 LCD_CMD(LINE3); LCD_STR(str3);
 LCD_CMD(LINE4); LCD_STR(str4);
 TCCR1B=0x0D; OCR1A=15624; TIMSK=0x10;
 stdout=&OUTPUT;
 stdin=&INPUT;
 UART1_init(); // UART 통신초기화
 ADC_init(3); // AD 변환기초기화.채널3 사용
 SREG=0x80;
  if(flag){ flag=0;
   LCD_CMD(LINE2);
   LCD_CHAR(' '); LCD_CHAR((hour/10)+'0'); LCD_CHAR((hour%10)+'0'); LCD_CHAR(':');
   LCD_CHAR((min /10)+'0'); LCD_CHAR((min%10)+'0'); LCD_CHAR(':');
   LCD_CHAR((sec /10)+'0'); LCD_CHAR((sec%10)+'0');
  read=read_ADC(); // ADC 값읽기
  // 0에서1023 사이의값을0V에서5V 사이값으로변환한다.
  input_voltage=read*5.0/1023.0;
  // 10mV에1℃이므로100을곱해서현재온도를얻는다.
  temperature=(int)(input_voltage*100.0);
  LCD_CMD(LINE4);
  LCD_CHAR(' '); LCD_CHAR(temperature); LCD_CHAR('   C');
 printf("%d\r\n", temperature);
  _delay_ms(1000); // 1초에한번읽음
 return 0;
lcd에 시간 재주는 기능이랑 온도까지 뜨게하려고 코드를 합쳤는데
시간만 재는 코드는 작동이 되는데
두개를 합치니까 둘다 아무것도 작동이 안됩니다  ㅜ ㅜ 뭐가 문제일까요 ㅠㅠㅠ
조회수 6,612
답변을 적어드리면 답변소스를 기반으로 수정을 하셔야하는데
자꾸 원래 소스를 가지고 작업을 합니다.
이래서는 답변을 달아드리지 못합니다.
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 17141
공지 사이트 이용 안내댓글[28] master 17-10-29 33557
질문 아두이노 코딩 에러 질문댓글[1] 이미지새글첨부파일 박무농 23-03-25 23
질문 아두이노를 이용한 타이머, 태양전지 제어댓글[1] 새글 박무농 23-03-25 24
질문 sd카드 이미지 전송댓글[1] 던지기마스터 23-03-24 12
질문 초음파센서를 이용한 모터제어 질문있습니다.댓글[3] 이미지첨부파일 뉴비에오 23-03-24 32
질문 부품 관련 문의댓글[1] 타코 23-03-23 21
질문 모터 작동 시, 일부 모듈이 꺼지는 현상에 대해 질문드립니다. 이미지 그렇찌 23-03-22 30
답변 답변글 답변 : 모터 작동 시, 일부 모듈이 꺼지는 현상에 대해 질문드립니다. 이미지 master 23-03-23 19
질문 ESP로 원격 모터제어를 할 수 있나용?댓글[1] 비차 23-03-22 24
질문 HC06을 마스터로 설정하면 HC06끼리만 통신되나요?댓글[4] 비차 23-03-21 32
질문 atmega128 압력센서 관련 질문입니다댓글[1] 공린이 23-03-19 61
질문 아두이노 스텝모터 각도제어 질문댓글[3] master 23-03-17 62
질문 아두이노와 파이썬(중점좌표) 시리얼 통신 질문드립니다.댓글[1] 이미지첨부파일 아두이노어렵잖아 23-03-16 48
질문 hm-10 다중연결 질문있습니다.댓글[1] 첨부파일 뉴비에오 23-03-14 44
질문 while loop 실행 속도댓글[1] 412904 23-03-12 64
질문 AND 연산 질문드립니다.댓글[1] 412904 23-03-11 69
질문 아두이노 테트리스 게임댓글[1] 첨부파일 지욱애 23-03-02 155
질문 아두이노우노 블루투스 2개 연결댓글[1] dsfadfs 23-02-28 114
질문 스텝모터 코딩 질문입니다..댓글[2] 무야더싱 23-02-25 135
질문 아두이노 나노33 IOT 의 BLE 연결 문제 이미지 가루밀 23-02-24 78
질문 HM-10 모듈 사용하는데 질문있습니다.댓글[2] 뉴비에오 23-02-21 134
질문 아두이노 블루투스 관련 질문입니다. 생물공학도 23-02-21 104
답변 답변글 답변 : 아두이노 블루투스 관련 질문입니다. master 23-02-21 104
질문 자율주행 로봇을 만드는데 질문있습니다.댓글[2] 뉴비에오 23-02-18 165
질문 블루투스에서 아두이노로 신호전달에 대하여(2)댓글[1] 이미지첨부파일 밍경 23-02-14 194
