질문게시판 > 답변 : atmega 128 lcd와 온도센서 합친코드
TODAY261 TOTAL2,579,430
BASIC4MCU | 질문게시판 | 답변 : atmega 128 lcd와 온도센서 합친코드
작성자 master 작성일2018-12-10 20:41 조회6,422회 댓글0건
// DateTime : 2018-12-10 오후 8:47:09
#define F_CPU 16000000
#include <avr/io.h>
#include <util/delay.h>
#include <avr/interrupt.h>
#include <stdio.h>
#define FUNCSET 0x28 //Function Set
#define ENTMODE 0x06 //Entry Mode Set
#define ALLCLR  0x01 //Clear Display
#define DISPON  0x0c //Display On
#define LINE1   0x80 //Set DDRAM Address(0x00)
#define LINE2   0xC0 //Set DDRAM Address(0x40)
#define LINE3   0x94 //Set DDRAM Address(0x14)
#define LINE4   0xD4 //Set DDRAM Address(0x54)
#define PORT_DATA PORTD
#define DDR_DATA  DDRD
#define Byte unsigned char
volatile Byte flag=0,sec=0,min=0,hour=0;
void LCD_CMD(unsigned char byte){
  PORT_DATA=(byte&0xF0)|4_delay_us(1); PORT_DATA&=0xFB;
  PORT_DATA=(byte<<0x4)|4_delay_us(1); PORT_DATA&=0xFB_delay_ms(3);
void LCD_CHAR(unsigned char byte){
  PORT_DATA=(byte&0xF0)|5_delay_us(1); PORT_DATA&=0xFB;
  PORT_DATA=(byte<<0x4)|5_delay_us(1); PORT_DATA&=0xFB_delay_us(50);
void LCD_STR(Byte *s){ while(*s)LCD_CHAR(*s++); }
void LCD_INIT(void){
  DDR_DATA=0xFF_delay_ms(15); LCD_CMD(0x20); LCD_CMD(0x20); LCD_CMD(0x20);
  LCD_CMD(FUNCSET); LCD_CMD(DISPON); LCD_CMD(ALLCLR); LCD_CMD(ENTMODE);
void TX1_char(char c){ while(!(UCSR1A&0x20)); UDR1=c; }
void TX1_STR(char *s){ while(*s)TX1_char(*s++); }
ISR(TIMER1_COMPA_vect){
  if(++sec>59){ sec=0;
    if(++min>59){ min=0if(++hour>23)hour=0; }
  flag=1;
int main(void){
  int ichar str[30];
  LCD_INIT();
  LCD_CMD(LINE1); LCD_STR("Current Time");
  LCD_CMD(LINE2); LCD_STR(str2);
  LCD_CMD(LINE3); LCD_STR("Temperature");
  LCD_CMD(LINE4); LCD_STR(str4);
  TCCR1B=0x0DOCR1A=15624TIMSK=0x10;
  UCSR0B=0x18UBRR0L=103// 9600
  ADMUX=0x43;  ADCSRA=0xE7;
  SREG=0x80;
    if(flag){ flag=0;
      sprintf(str,"%02d:%02d:%02d",hour,min,sec);
      LCD_CMD(LINE2); LCD_STR(str);
      TX1_STR(str); TX1_STR("\r\n");
      i=ADC;
      i=(int)((float)i*500.0/1023.0);
      sprintf(str,"%d C",i);
      LCD_CMD(LINE4); LCD_STR(str);
조회수 6,422
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 17026
질문 모터 작동 시, 일부 모듈이 꺼지는 현상에 대해 질문드립니다. 이미지새글 그렇찌 23-03-22 12
질문 ESP로 원격 모터제어를 할 수 있나용? 새글 비차 23-03-22 7
질문 HC06을 마스터로 설정하면 HC06끼리만 통신되나요?댓글[4] 비차 23-03-21 22
질문 아두이노 3LED 버튼 관련 질문댓글[1] 이츤 23-03-16 33
질문 스텝모터 코딩 질문입니다..댓글[2] 무야더싱 23-02-25 121
질문 아두이노 나노33 IOT 의 BLE 연결 문제 이미지 가루밀 23-02-24 70
답변 답변글 답변 : 블루투스에서 아두이노로 신호전달에 대하여 master 23-02-14 113
질문 ATmega328p + pca9685 + 서보모터 토비 23-02-08 154
