질문게시판 > 답변 : atmega 128 코드 합치기
TODAY413 TOTAL2,171,612
BASIC4MCU | 질문게시판 | 답변 : atmega 128 코드 합치기
작성자 master 작성일2018-12-12 12:58 조회3,359회 댓글0건
// DateTime : 2018-12-12 오후 1:04:07
#define F_CPU 16000000
#include <avr/io.h>
#include <util/delay.h>
#include <avr/interrupt.h>
#include <stdio.h>
#include "UART1.h"
FILE OUTPUT\
=FDEV_SETUP_STREAM(UART1_transmit,NULL,_FDEV_SETUP_WRITE);
FILE INPUT\
=FDEV_SETUP_STREAM(NULL,UART1_receive,_FDEV_SETUP_READ);
#define FUNCSET 0x28 //Function Set
#define ENTMODE 0x06 //Entry Mode Set
#define ALLCLR  0x01 //Clear Display
#define DISPON  0x0c //Display On
#define LINE2  0xC0 //Set DDRAM Address(0x40)
#define LINE3  0x94 //Set DDRAM Address(0x14)
#define LINE4  0xD4 //Set DDRAM Address(0x54)
#define PORT_DATA PORTC
#define DDR_DATA  DDRC
#define Byte unsigned char
volatile Byte flag=0,sec=0,min=0,hour=0;
void LCD_CMD(unsigned char byte){
  PORT_DATA=(byte&0xF0)|4_delay_us(1); PORT_DATA&=0xFB;
  PORT_DATA=(byte<<0x4)|4_delay_us(1); PORT_DATA&=0xFB_delay_ms(3);
void LCD_CHAR(unsigned char byte){
  PORT_DATA=(byte&0xF0)|5_delay_us(1); PORT_DATA&=0xFB;
  PORT_DATA=(byte<<0x4)|5_delay_us(1); PORT_DATA&=0xFB_delay_us(50);
void LCD_STR(Byte*s){ while(*s)LCD_CHAR(*s++); }
void LCD_INIT(void){
  DDR_DATA=0xFF_delay_ms(15); LCD_CMD(0x20); LCD_CMD(0x20); LCD_CMD(0x20);
  LCD_CMD(FUNCSET); LCD_CMD(DISPON); LCD_CMD(ALLCLR); LCD_CMD(ENTMODE);
ISR(TIMER1_COMPA_vect){
  if(++sec>59){ sec=0;
    if(++min>59){ min=0if(++hour>23)hour=0; }
  flag=1;
int main(void){
  int read,temperature,dim=0;
  float input_voltage;
  Byte str1[]="Current Time"Byte str2[]=" 00: 00: 00";
  Byte str3[]="Temperature"Byte str4[]=" 00C";
  LCD_INIT();
  LCD_STR(str1);
  LCD_CMD(LINE2); LCD_STR(str2);
  LCD_CMD(LINE3); LCD_STR(str3);
  LCD_CMD(LINE4); LCD_STR(str4);
  TCCR1B=0x0DOCR1A=15624TIMSK=0x10;
  stdout=&OUTPUT;
  stdin=&INPUT;
  UART1_init();
  DDRB|=(1<<PB5);
  TCCR1A=(1<<WGM11)|(1<<COM1A1); TCCR1B=(1<<CS12);
  ADMUX=0x40ADCSRA=0xE7;
  SREG=0x80;
    if(flag){ flag=0;
      LCD_CMD(LINE2);
      LCD_CHAR(' '); LCD_CHAR((hour/10)+'0'); LCD_CHAR((hour%10)+'0'); LCD_CHAR(': ');
      LCD_CHAR((min /10)+'0'); LCD_CHAR((min%10)+'0'); LCD_CHAR(': ');
      LCD_CHAR((sec /10)+'0'); LCD_CHAR((sec%10)+'0');
      ADMUX=0x43delay_ms(1); read=ADC;
      input_voltage=read*500.0/1023.0// 10mV에1℃이므로100을곱해서현재온도를얻는다.
      temperature=(int)input_voltage;
      LCD_CMD(LINE4);
      LCD_CHAR(' '); LCD_CHAR((temperature/10)+'0'); LCD_CHAR((temperature%10)+'0'); LCD_CHAR('C');
      if(read<100){ dim=200; }
      else        { dim=10;  }
      OCR1A=dim;
      _delay_ms(10);
조회수 3,359
공지 사이트 이용 안내댓글[24] master 17-10-29 29789
질문 atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데.. 새글 aasdw 06:28 8
질문 아두이노 간단한 프로그램 새글 행복지수업 22-05-25 20
질문 atmega128 타이머 작성시 키패트 입력으로 인터럽트 사용에 대하여 질문이 있습니다. 이미지새글 마프하나 22-05-25 26
질문 아두이노 스텝모터 리미트 문의드립니다.댓글[2] 이미지새글첨부파일 스트렌져 22-05-24 27
질문 서보모터 제어에 관하여 궁금합니다댓글[3] 이미지첨부파일 오소로롯 22-05-24 46
질문 atmega 128 타이머 작성 중 질문 드립니다.댓글[8] 이미지 마프하나 22-05-23 59
질문 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 어떻게 해…댓글[1] 졸작부수다 22-05-23 183
질문 보드레이트 질문댓글[1] 죠르디 22-05-23 31
질문 atmega 128 블루투스 질문 입니다댓글[1] yhj2644 22-05-23 48
질문 아트메가 공부중에 질문있습니다..댓글[1] suid82 22-05-23 37
질문 Atmega128 UART통신 echo 반복 질문댓글[2] ming2ming 22-05-23 51
질문 아두이노의 지속 시간에 대해 질문합니다. merry 22-05-23 47
답변 답변글 답변 : 아두이노의 지속 시간에 대해 질문합니다. master 22-05-23 34
질문 초음파+스텝모터 도꺼비 22-05-22 35
답변 답변글 답변 : 초음파+스텝모터 master 22-05-23 36
질문 아두이노 인터럽트 질문있습니다.댓글[1] 띵꽁 22-05-22 47
답변 답변글 답변 : 아두이노 인터럽트 질문있습니다.댓글[3] master 22-05-22 45
질문 atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[4] 이미지 마프하나 22-05-22 66
답변 답변글 답변 : atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[1] 이미지 master 22-05-23 47
질문 서보모터제어 해당코드에서 어떤걸 추가해야할까요댓글[3] 이미지첨부파일 오소로롯 22-05-22 46
질문 Atmega128 UART통신에서 ECHO 관련 질문드립니다. dsfdfsa 22-05-22 52
