질문게시판 > 답변 : Codevision소스로 변환
TODAY469 TOTAL2,696,348
BASIC4MCU | 질문게시판 | 답변 : Codevision소스로 변환
작성자 master 작성일2018-12-14 16:53 조회5,730회 댓글0건
// DateTime : 2018-12-14 오후 4:58:35
#include <mega128.h
#include <delay.h>
char sec_num[]="20021282"//비밀번호
char key_IN[8];
int arr_cnt=1,right=1,g=0,s=0,i=0;
void LCD_CMD(char b){
  PORTA=(b&0xF0)|4delay_us(1); PORTA.2=0;
  PORTA=(b<<0x4)|4delay_us(1); PORTA.2=0delay_ms(3);
void LCD_Char(char b){
  PORTA=(b&0xF0)|5delay_us(1); PORTA.2=0;
  PORTA=(b<<0x4)|5delay_us(1); PORTA.2=0delay_us(50);
void LCD_Str(char b,char *s){ LCD_CMD(b); while(*s)LCD_Char(*s++); }
void init_LCD(void){
  DDRA=0xFFdelay_ms(30); LCD_CMD(0x28); LCD_CMD(0x28);
  LCD_CMD(0x0C); LCD_CMD(6); LCD_CMD(2); LCD_CMD(1);
// 키스캔 함수
char Key(void){
  PORTC=0x01delay_us(1);
  if     (PINC.4)return 0x30// 0
  else if(PINC.5)return 0x34// 4
  else if(PINC.6)return 0x38// 8
  else if(PINC.7)return 0x41// A
  PORTC=0x02delay_us(1);
  if     (PINC.4)return 0x31// 1
  else if(PINC.5)return 0x35// 5
  else if(PINC.6)return 0x39// 9
  else if(PINC.7)return 0x42// B
  PORTC=0x04delay_us(1);
  if     (PINC.4)return 0x32// 2
  else if(PINC.5)return 0x36// 6
  else if(PINC.6)return 0x2a// *
  else if(PINC.7)return 0x43// C
  PORTC=0x08delay_us(1);
  if     (PINC.4)return 0x33// 3
  else if(PINC.5)return 0x37// 7
  else if(PINC.6)return 0x23// #
  else if(PINC.7)return 0x44// D
  return 0xff;
// 모터구동함수
void dc_motor(char dir,unsigned int speed){
  if(dir)PORTB|=0x40// 모터 방향 DIR(정방향)
  else   PORTB&=0xBF// 모터 방향 DIR(역방향)
  OCR1A=speed;
// 비밀번호 확인 함수
void sec_test(char b){
  if(arr_cnt==8){
    for(g=0g<8g++){ if(key_IN[g]==sec_num[g])right++; }
    if(right==8){
      LCD_CMD(0x01); LCD_Str(0x80,"OPEN"); dc_motor(0,0x3ff); delay_ms(500); OCR1A=0;
      LCD_CMD(0x01); LCD_Str(0x80,"Password");
      LCD_CMD(0x01); LCD_Str(0x80,"Retry"); delay_ms(500);
    arr_cnt=1right=1g=0s=0i=0;
  elsekey_IN[s]=bs++; arr_cnt++; }
interrupt[EXT_INT4]void ext_int4_isr(void){
  dc_motor(1,0x3ff); delay_ms(1000); OCR1A=0;
  EIFR|=0x10;
void main(void){
  char key=0xff;
  PORTB=0xFFDDRB=0xE0;
  DDRC=0x0f;
  init_LCD();  LCD_Str(0x80,"Password");
  TCCR1A=0x83TCCR1B=2;  // Phase correct PWM 10bit,8 prescaler // f=997Hz,T=1.003msec
  EICRB=0x03;  EIFR=0x10EIMSK|=0x10;
  SREG=0x80;
    key=Key();
    if(key!=0xff){
      LCD_CMD(0xC0+i); LCD_Char(key); // 리턴 키 값을 출력하는 함수.
      delay_ms(500);
      i++;
      sec_test(key); //비밀번호 확인 함수
조회수 5,730
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 19704
공지 사이트 이용 안내댓글[28] master 17-10-29 34155
질문 atmega128 uart 질문입니다. bme12 23-06-05 25
질문 ATMEGA128 혹시 여기서 왜 인터럽트 기능이 안되는지 알 수 있나요 IEEE 23-06-04 34
질문 lora 무선 모듈에 관한 질문입니다.댓글[1] 로이스10 23-06-01 23
질문 초음파 센서를 이용한 인원 카운팅댓글[1] 초음파야 23-05-31 39
답변 답변글 답변 : 아두이노 타이머 인터럽트댓글[7] master 23-05-30 56
질문 앱인벤터 아두이노 보드 LCD 글씨 나타내기 질문댓글[7] 이미지 당찬병아리 23-05-29 52
질문 atmega128 led와 fan댓글[3] 이라 23-05-28 56
