질문게시판 > 답변 : atmega128 소스 코드 질문
TODAY417 TOTAL2,171,616
BASIC4MCU | 질문게시판 | 답변 : atmega128 소스 코드 질문
작성자 master 작성일2018-12-14 18:40 조회3,531회 댓글0건
// DateTime : 2018-12-14 오후 6:45:24
/*Baseball서버(win)*/
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <winsock2.h>
#include <windows.h>
#pragma comment(lib,"ws2_32.lib")
#define BUFSIZE 1024
void errorhandling(char *message){ fputs(message,stderr); fputc('\n',stderr); exit(1); }
int main(int argc,char **argv){
  WSADATA wsaData;
  SOCKET hServSock;
  SOCKET hClntSock;
  SOCKADDR_IN servAddr;
  SOCKADDR_IN clntAddr;
  char   message[BUFSIZE];
  int    ClntSize;
  int    len;
  char   szPort[15];
  HANDLE m_handle=NULL;
  DCB    dcb;
  OVERLAPPED osWrite,osRead;
  char   ch;
  char   ch1[3]={0,};
  char   recvBaseball[2]={0,};
  int    cnt=0;
  DWORD  checkCnt=0;
  /*int i; for(i=0; i<3; i++){ printf("보낼 숫자: "); scanf("%d",&ch[i]); printf("%d",ch[i]); }*/
  if(WSAStartup(MAKEWORD(2,2),&wsaData)!=0)errorhandling("WSAStartup()error!");
  puts("스타트업");
  hServSock=socket(PF_INET,SOCK_STREAM,0);
  if(hServSock==INVALID_SOCKET)errorhandling("socket()error");
  puts("소켓생성");
  memset(&servAddr,0,sizeof(servAddr));
  servAddr.sin_family=AF_INET;
  servAddr.sin_addr.s_addr=htonl(INADDR_ANY);
  servAddr.sin_port=htons(7000);
  if(bind(hServSock,(SOCKADDR*)&servAddr,sizeof(servAddr))==SOCKET_ERROR)errorhandling("bind()error");
  puts("bind");
  if(listen(hServSock,5)==SOCKET_ERROR)errorhandling("listen()error");
  puts("listen");
  ClntSize=sizeof(clntAddr);
  hClntSock=accept(hServSock,(SOCKADDR*)&clntAddr,&ClntSize);
  if(hClntSock==INVALID_SOCKET)errorhandling("accept()error");
  printf("서버 on");
  wsprintf(szPort,"COM%d",1);
  m_handle=CreateFile(szPort,GENERIC_READ|GENERIC_WRITE,0,NULL,OPEN_EXISTING,FILE_ATTRIBUTE_NORMAL,NULL);
  if(m_handle==INVALID_HANDLE_VALUE){ printf("핸들값이 올바르지 않습니다.\n"); return 1; }
  dcb.DCBlength=sizeof(DCB);
  GetCommState(m_handle,&dcb);
  dcb.BaudRate=19200dcb.ByteSize=8dcb.Parity=0dcb.StopBits=0;
  SetCommState(m_handle,&dcb);
  osWrite.Offset=osRead.Offset=0;
  osWrite.OffsetHigh=osRead.OffsetHigh=0;
  osWrite.hEvent=osRead.hEvent=CreateEvent(NULL,TRUE,FALSE,NULL);
    static int check;
    int i;
    len=recv(hClntSock,(char*)&ch,1,0);
    if(len==1){
      printf("받은 값 확인:%d\n",ch);
      //WriteFile(m_handle,(CONST void far*)&ch,sizeof(ch),NULL,&osWrite); //printf("Send to DK128:%d\n",ch);
    else continue;
    check+=len;
    if(check==3){
        for(i=0i<3i++){
          ch=0;
          ReadFile(m_handle,(char*)&ch,1,&checkCnt,&osRead);
          printf("입력:%d \n",ch);
          send(hClntSock,(char*)&ch,1,0);
        memset(recvBaseball,0,sizeof(recvBaseball));
        len=recv(hClntSock,recvBaseball,2,0);
        printf(" recv Byte(%d)\n",len);
        printf(" 스트라이크:%d \n",recvBaseball[0]);
        printf(" 볼:%d \n",recvBaseball[1]);
        if(recvBaseball[0]==3){ puts("축하합니다.~~"); exit(0); }
  //send(hClntSock,ch,sizeof(ch),0);
  CloseHandle(m_handle);
  closesocket(hClntSock);
  WSACleanup();
  return 0;
// DateTime : 2018-12-14 오후 6:45:48
/*Baseball서버(avr)*/
#include <mega128.h
#include <delay.h>
#include <stdio.h>
#include <stdlib.h>
#define CPU_CLOCK     16000000
#define TICKS_PER_SEC 1000
#define PRE           64
#define BAUD_RATE     19200
#define BAUD_RATE_L   (CPU_CLOCK/(16l*BAUD_RATE))-1
#define BAUD_RATE_H   ((CPU_CLOCK/(16l*BAUD_RATE))-1)>>8
#define BS            8
#define CR            13
#define BITMASK0 0XFE
#define BITMASK1 0XFD
#define BITMASK2 0XFB
#define BITMASK3 0XF7
#define BITMASK4 0XEF6
#define BITMASK5 0XdF
#define BITMASK6 0XbF
#define BITMASK7 0X7F
#define MENU_SIZE    5 // 길이 정의
typedef unsigned int  U16;
typedef unsigned char U08;
volatile unsigned char Rotation[]={0XFE,0XFD,0XFB,0XF7,0XEF,0XdF,0XbF,0X7F};
volatile unsigned int g_time;
void sleep(unsigned int time){ g_time=0while(time>g_time); }
//unsigned char uart_recv_byte(void){ while(!(UCSR1A&(1<<RXC1))); return UDR1; }
void uart_send_byte(unsigned char byte){ while(!(UCSR1A&(1<<UDRE1))); UDR1=byte; } //1 byte 전송 함수
//void uart_send_string(unsigned char *str,unsigned char len){ //문자열 전송 함수
//  int i;
//  for(i=0; i<len; i++){ if(!(*(str+i)))break; uart_send_byte(*(str+i)); }
//  uart_send_byte('\n'); uart_send_byte('\r');
//void uart_send_arr(unsigned char **str,unsigned int cnt){ //문자열 전송 함수
//  int i,j;
//  for(i=0; i<cnt; i++){
//    for(j=0; str[i][j]!='\0'; j++){ uart_send_byte(str[i][j]); }
//    if(i==cnt-1)break;
//void led_1(void){
//  unsigned char rate=0xff;
//  volatile unsigned int i;
//  for(i=0; i<9; i++){ PORTF=(rate<<i); sleep(200); }
//  for(i=7; i>0;--i){ PORTF=(rate<<i); sleep(300); }
//  PORTF=0XFF;
//void led_2(void){
//  unsigned int i;
//  for(i=0; i<9; i++){ PORTF=(rate<<i); sleep(100); }
//  for(i=8; i>0; i--){ PORTF=(rate>>i); sleep(100); }
//  PORTF=0XFF;
//void lineDwon(void){ uart_send_byte('\n'); uart_send_byte('\r'); }
void Dodugi(void){
  //PORTC=0X00;
  volatile unsigned char random=0;
  volatile unsigned char button=0;
  volatile unsigned char cnt=1;
  //volatile unsigned char check=0;
  PORTE=(cnt<<4)|cnt;
    random=rand()%8;
    PORTF=Rotation[random];
    sleep(700);
    button=PINC;
    if(button==Rotation[random]){
      cnt++;
      lineDwon();
      uart_send_byte(cnt);
      PORTE=(cnt<<4)|cnt;
      if(cnt==9)cnt=0;
  PORTF=0XFF;
void vaseball(void){
  //unsigned char Rotation[]={0XFE,0XFD,0XFB,0XF7,0XEF,0XdF,0XbF,0X7F};
  unsigned int  cnt=0;
  unsigned char i,button,state=0xFF;
    button=PINC// 입력 대기
    if(button<0xFF){
      sleep(500); // 잠시 대기한다.
      state=~(state^button);
      for(i=0;i<8;i++){
        if(Rotation[i]==button){ uart_send_byte(i); break; }
      PORTF=state;
      cnt++;
    if(cnt==3){ sleep(1000); cnt=0; }
    //state=~(state^button); // 버튼값을 연산하여 눌러진 모든 값을 LED에 찍는다.
    // LED 출력한다.
  //uart_send_byte('e');
//int check(unsigned char *pBuf,unsigned char ch,unsigned int cnt){
//  unsigned int i;
//  for(i=0; i<=cnt; i++){ // 버퍼에 저장된 값과 현재 값을 비교
//    if(pBuf[i]==ch)return-1; // 비교했을 때 같다면 처음부터 시작
//  return 0;
interrupt [TIM0_OVFvoid timer0_ovf_isr(void){ g_time++; TCNT0=256-(CPU_CLOCK/TICKS_PER_SEC/64); }
void main(void){
//U08 *p_szMenu[MENU_SIZE]={ "=메뉴를 선택하세요="," 1.LED 가지고 놀기"," 2.FND 가지고 놀기"," 3.두더지게임"," 메뉴 선택: "};
  PORTF=0XFFDDRF=0xFF// LED  열기
  PORTE=0XFFDDRE=0XFF// FND  열기
  DDRC=0x00;
  UBRR1L=(unsigned char)BAUD_RATE_L//baud rate 설정
  UBRR1H=(unsigned char)BAUD_RATE_H//no parity,1 stop bit,8bit 설정
  UCSR1B=0x18;  // rx/tx 설정,8bit 설정
  TCCR0=0x04;    // setTCCR0();
  TCNT0=256-(CPU_CLOCK/TICKS_PER_SEC/64); // initTCNT0();
  TIMSK=(0<<OCIE0)|(1<<TOIE0);            // setTIMSK();
  SREG=0x80;
  // uart_send_arr(p_szMenu,MENU_SIZE);
  vaseball();
조회수 3,531
공지 사이트 이용 안내댓글[24] master 17-10-29 29789
질문 atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데.. 새글 aasdw 06:28 9
질문 아두이노 간단한 프로그램 새글 행복지수업 22-05-25 20
질문 atmega128 타이머 작성시 키패트 입력으로 인터럽트 사용에 대하여 질문이 있습니다. 이미지새글 마프하나 22-05-25 26
질문 아두이노 스텝모터 리미트 문의드립니다.댓글[2] 이미지새글첨부파일 스트렌져 22-05-24 27
질문 서보모터 제어에 관하여 궁금합니다댓글[3] 이미지첨부파일 오소로롯 22-05-24 46
질문 atmega 128 타이머 작성 중 질문 드립니다.댓글[8] 이미지 마프하나 22-05-23 59
질문 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 어떻게 해…댓글[1] 졸작부수다 22-05-23 183
질문 보드레이트 질문댓글[1] 죠르디 22-05-23 31
질문 atmega 128 블루투스 질문 입니다댓글[1] yhj2644 22-05-23 48
질문 아트메가 공부중에 질문있습니다..댓글[1] suid82 22-05-23 37
질문 Atmega128 UART통신 echo 반복 질문댓글[2] ming2ming 22-05-23 51
질문 아두이노의 지속 시간에 대해 질문합니다. merry 22-05-23 47
답변 답변글 답변 : 아두이노의 지속 시간에 대해 질문합니다. master 22-05-23 34
질문 초음파+스텝모터 도꺼비 22-05-22 35
답변 답변글 답변 : 초음파+스텝모터 master 22-05-23 36
질문 아두이노 인터럽트 질문있습니다.댓글[1] 띵꽁 22-05-22 47
답변 답변글 답변 : 아두이노 인터럽트 질문있습니다.댓글[3] master 22-05-22 45
질문 atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[4] 이미지 마프하나 22-05-22 66
답변 답변글 답변 : atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[1] 이미지 master 22-05-23 47
질문 서보모터제어 해당코드에서 어떤걸 추가해야할까요댓글[3] 이미지첨부파일 오소로롯 22-05-22 46
질문 Atmega128 UART통신에서 ECHO 관련 질문드립니다. dsfdfsa 22-05-22 52
