질문게시판 > 답변 : ATMEGA128A 질문있습니다 수정자료
TODAY131 TOTAL2,579,300
BASIC4MCU | 질문게시판 | 답변 : ATMEGA128A 질문있습니다 수정자료
작성자 master 작성일2018-12-16 08:04 조회9,037회 댓글2건
// DateTime : 2018-12-16 오전 8:07:00
#include <io.h>
typedef enum{ra_1,si_1,do_2,re_2,mi_2,fa_2,sol_2,ra_2,highmelody_code//high: 불가청 음역대 쉼표 표시
typedef enum{tf,f,sf,o,tspeed_code// 1/4,1/2,3/4,1,2
const char clock_set[]={0x6F,0x6E,0x6E,0x6E,0x6E,0x6E,0x6E,0x6E,0x6A};
const char ocr0_set[] ={142,253,238,212,189,179,159,142,1};
const int  timer[]    ={188,375,563,750,1500}; // 단위: ms
const char led[]      ={0x01,0x03,0x07,0x0f,0xff};
const char oct[]      ={0x06,0x06,0x5b,0x5b,0x5b,0x5b,0x5b,0x5b,0x00};
const char scale[]    ={0x77,0x39,0x06,0x4f,0x6d,0x7d,0x7f,0x77,0x00};
typedef structmelody_code melody;  speed_code speed;} MUSIC_CODE;
#define LENGTH  99
const MUSIC_CODE musicCode1[LENGTH]={
  {sol_2,o},{mi_2,o},{do_2,o},{high,o},{re_2,sf},{mi_2,tf},{fa_2,f},{re_2,f},{si_1,o},{high,o}, // 즐겁게 춤을추다가
  {do_2,o},{do_2,f},{do_2,f},{mi_2,o},{mi_2,o},{sol_2,f},{high,f},{high,o},{high,t},            // 그대로 멈춰라
  {ra_1,o},{ra_1,f},{ra_1,f},{si_1,o},{si_1,o},{do_2,f},{high,f},{high,o},{high,t},             // 그대로 멈춰라
  {ra_2,o},{ra_2,o},{ra_2,f},{ra_2,f},{ra_2,f},{ra_2,f},                                        // 눈도 감지말고
  {sol_2,o},{sol_2,f},{sol_2,f},{sol_2,o},{sol_2,o},                                            // 웃지도 말고
  {fa_2,o},{fa_2,f},{fa_2,f},{fa_2,o},{fa_2,o},                                                 // 울지도 말고
  {mi_2,f},{mi_2,f},{fa_2,f},{fa_2,f},{sol_2,f},{high,f},{high,o},                              // 움직이지마
  {sol_2,o},{mi_2,o},{do_2,o},{high,o},{re_2,sf},{mi_2,tf},{fa_2,f},{re_2,tf},{si_1,o},{high,o},// 즐겁게 춤을추다가
  {do_2,o},{do_2,tf},{do_2,f},{mi_2,o},{mi_2,o},{sol_2,f},{high,f},{high,o},{high,t},           // 그대로 멈춰라
  {ra_1,o},{ra_1,f},{ra_1,f},{si_1,o},{si_1,o},{do_2,f},{high,f},{high,o},{high,t}              // 그대로 멈춰라
int ms=0;
interrupt[TIM2_COMP]void isr_timer2_comp(){
  ms++;
void main(){
  int k;
  DDRB=0x10;  DDRA=0XFF;  DDRC=0xFFDDRG=0x0F;
  TCCR2=0x0BOCR2=249;  TIMSK=0x80//16000000/64/(1+249),1ms
  SREG=0x80;
    for(k=0;k<=98;k++){
      ms=0;
      while(timer[musicCode1[k].speed]>ms){                     // 박자 조절
        OCR0=ocr0_set[musicCode1[k].melody];
        TCCR0=clock_set[musicCode1[k].melody];
        PORTA=led[musicCode1[k].speed];                         // led 박자 길이 표시
        if(ms&1){ PORTC=oct[musicCode1[k].melody];   PORTG=8; } // 옥타브 표시
        else    { PORTC=scale[musicCode1[k].melody]; PORTG=1; } // 음계 표시
몇가지 오류를 체크 했지만 정상동작할런지는 모르겠습니다.
원본 소스 출처에서 정상동작하는 소스인지 확인 해보세요
16비트 타이머로 만든 멜로디 예제를 공부해서 만드는 것이 빠를 수도 있겠습니다.
https://www.basic4mcu.com/bbs/board.php?bo_table=gesiyo9&wr_id=138
게시판에 몇개의 글이 더 있습니다.
조회수 9,037
헤헿헿님의 댓글
헤헿헿 작성일
감사합니다 드디어 해결됬네요 ㅠ
if(ms & 1) 에서 &가 어떻게 동작하는지만 마지막으로 설명해주실 수 있나요
ms&1
ms가 1이면 결과는 1
ms가 0이면 결과는 0
ms가 홀수면 옥타브표시
짝수면 음계표시
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 17024
질문 모터 작동 시, 일부 모듈이 꺼지는 현상에 대해 질문드립니다. 이미지새글 그렇찌 23-03-22 3
질문 ESP로 원격 모터제어를 할 수 있나용? 새글 비차 23-03-22 5
질문 HC06을 마스터로 설정하면 HC06끼리만 통신되나요?댓글[4] 새글 비차 23-03-21 22
질문 아두이노 3LED 버튼 관련 질문댓글[1] 이츤 23-03-16 32
질문 스텝모터 코딩 질문입니다..댓글[2] 무야더싱 23-02-25 120
질문 아두이노 나노33 IOT 의 BLE 연결 문제 이미지 가루밀 23-02-24 69
답변 답변글 답변 : 블루투스에서 아두이노로 신호전달에 대하여 master 23-02-14 112
질문 ATmega328p + pca9685 + 서보모터 토비 23-02-08 153
