질문게시판 > 답변 : (초보)아두이노, 프로세싱 코드
TODAY1,583 TOTAL2,159,482
BASIC4MCU | 질문게시판 | 답변 : (초보)아두이노, 프로세싱 코드
작성자 master 작성일2018-12-16 18:29 조회3,248회 댓글0건
// DateTime : 2018-12-16 오후 6:34:17
//--------------------------------프로세싱 코드
import processing.serial.*;
Serial myPort;
int val=0;
ArrayList<Particle>particles;
PImage[]bullets;
PImage red_bullet;
PImage green_bullet;
PImage blue_bullet;
final float GRAVITY=200;
  frameRate(60);
  noStroke();
  size(1920,1080,P3D);
  String portName=Serial.list()[0];
  myPort=new Serial(this,portName,9600);
  myPort.bufferUntil(ln);
  red_bullet=loadImage("a.png");
  green_bullet=loadImage("a2.png");
  blue_bullet=loadImage("a3.png");
  bullets=new PImage[]{ red_bullet,green_bullet,blue_bullet};
  PVector GravityVector=new PVector(0,GRAVITY);
  PVector rocket_vel=PVector.fromAngle(-PI/3.0);
  rocket_vel.mult(150.0);
  particles=new ArrayList<Particle>();
  for(float i=0i<100i++)createRocket(i*0.5);
void draw(){
  if(val==1){ val=0;
    background(0);
    blendMode(ADD);
    color black=color(0,0,0);
    for(int i=0i<8i++){
      for(Particle pparticles){
        float t=get_t()-i*0.02;
        if(t>=p.initial_t&&t<p.end_t){
          PVector velVector=new PVector(p.x.vel(t),p.y.vel(t));
          pushMatrix();
          translate(p.x.pos(t),p.y.pos(t));
          rotate(velVector.heading()-PI*0);
          scale(0.2,0.2);
          drawSpark(p.image);
          popMatrix();
  else if(val==2){ val=0background(255); }
float get_t(){
  return frameCount/60.0;
void createRocket(float time){
  PVector initial_pos=new PVector((width/2.0),height);
  float burn_time=1.5+random(0.4);
  float glide_time=1.0+random(0.5);
  float thrust_mag=400;
  PVector thrust_vector=PVector.fromAngle(3.0*PI/2.0+random(-0.2,0.2));
  thrust_vector.setMag(thrust_mag);
  PVector rocket_accel=new PVector(0,GRAVITY);
  rocket_accel.add(thrust_vector);
  Particle rocket_with_thrust=new Particle(initial_pos,new PVector(0,0),rocket_accel,time,time+burn_time,color(255,100,100),red_bullet);
  Particle rocket_without_thrust=new Particle(rocket_with_thrust.pos(time+burn_time),rocket_with_thrust.vel(time+burn_time),new PVector(0,GRAVITY),time+burn_time,time+burn_time+glide_time,color(255,100,100),red_bullet);
  particles.add(rocket_with_thrust);
  particles.add(rocket_without_thrust);
  createExplosion(rocket_without_thrust.pos(time+burn_time+glide_time),rocket_without_thrust.vel(time+burn_time+glide_time),time+burn_time+glide_time,bullets[int(random(3))]);
void createExplosion(PVector position,PVector rocketVector,float time,PImage image){
  for(int i=0i<80i++){
    float explosion_vel=150;
    PVector vel;
    vel=PVector.random3D();
    vel.mult(explosion_vel);
    vel.add(rocketVector);
    particles.add(new Particle(position,vel,new PVector(0,GRAVITY),time,time+1.0+random(0.2)+random(0.2)+random(0.2),color(255,100,100),image));
void drawSpark(PImage image){
  image(image,-32,-32);
class Particle{
  color baseColor;
  Motion x;
  Motion y;
  float initial_t;
  float end_t;
  PImage image;
  Particle(PVector position,PVector velocity,PVector accel,float initial_t,float end_t,color baseColor,PImage image){
    this.x=new Motion(position.x,velocity.x,accel.x,initial_t);
    this.y=new Motion(position.y,velocity.y,accel.y,initial_t);
    this.initial_t=initial_t;
    this.end_t=end_t;
    this.baseColor=baseColor;
    this.image=image;
  PVector pos(float t){ return new PVector(this.x.pos(t),this.y.pos(t)); }
  PVector vel(float t){ return new PVector(this.x.vel(t),this.y.vel(t)); }
  PVector accel(){ return new PVector(this.x.accel,this.y.accel); }
class Motion{
  float initial_pos;
  float initial_vel;
  float accel;
  float initial_t;
  float t0_pos;
  float t0_vel;
  Motion(float initial_pos,float initial_vel,float accel,float initial_t){
    this.accel=accel;
    this.t0_vel=0;
    this.t0_vel=initial_vel-vel(initial_t);
    this.t0_pos=0;
    this.t0_pos=initial_pos-pos(initial_t);
  public float vel(float t){ return this.accel*t+this.t0_vel; }
  public float pos(float t){ return 0.5*this.accel*pow(t,2)+this.t0_vel*t+this.t0_pos; }
void serialEvent(Serial myPort){
  val=myPort.read();
//--------------------------------아두이노 코드
int switchPin=2;
byte flag=0,data=0;
  pinMode(switchPin,INPUT);
  if(digitalRead(switchPin)){
    if(flag==0){ flag=1;
      data^=1;
      if(data)Serial.write(byte(1));
      else    Serial.write(byte(2));
  elseflag=0; }
이 코드로 돌려보세요
한번 누르면 1 전송하고, 또 한번 누르면 2 전송하는 것을 반복합니다.
조회수 3,248
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 9620
공지 사이트 이용 안내댓글[24] master 17-10-29 29575
질문 컴퓨터 usb연결시 정상 작동하나 9V건전지 외부전원 연결 시 작동하지 않는 문제댓글[1] 이미지새글첨부파일 보겐을운용 17:26 12
질문 아두이노 dac 연결댓글[1] 이미지새글첨부파일 kodory 16:28 16
질문 아두이노 millis ->atmega128에서 사용하고 싶습니다. 새글 akmong413 16:22 15
답변 답변글 답변 : 아두이노 millis ->atmega128에서 사용하고 싶습니다. 새글 master 17:27 9
질문 아트메가 모터드라이브와 초음파 센서 연동 질문입니다댓글[1] 새글 123424135123q 00:54 18
질문 스텝모터 드라이버 선정 질문드립니다. 새글 아흐흑 22-05-18 18
답변 답변글 답변 : 스텝모터 드라이버 선정 질문드립니다.댓글[1] 이미지새글 master 06:56 15
질문 아두이노로 모터+드라이버 제어댓글[6] 새글 모토 22-05-18 33
질문 온도센서로 서보모터 제어 코딩댓글[1] 새글 진수네1조 22-05-18 38
질문 라즈베리파이 웹캠 데이터 아두이노 전송 (초보)댓글[1] 전자과 22-05-17 34
질문 아두이노 코딩 도와주세요 (초음파센서와 금속감지센서로 서보모터 제어하기) 이현주 22-05-17 57
답변 답변글 답변 : 아두이노 코딩 도와주세요 (초음파센서와 금속감지센서로 서보모터 제어하기) 새글 master 22-05-18 109
질문 아두이노 우노 2개와 앱인벤터끼리의 블루투스 통신 방법댓글[3] 이미지첨부파일 pyoleo 22-05-17 80
질문 졸업작품 첨부파일 ejdog 22-05-16 72
질문 PCB의 커넥터 연결관련 이슈같은데.. 원인을 정확히 모르겠습니다.댓글[2] 이미지 설계못해서개털림 22-05-16 61
질문 STM32F767 사용중인데 발열이 발생합니다.댓글[5] 존클라프 22-05-16 60
질문 리니어 레일 거리 조절댓글[1] 면수 22-05-16 52
질문 아두이노 심전도 센서 BPM 계산댓글[3] 쥬쥬 22-05-16 69
질문 아두이노 서로 다른 전압을 가진 부품 제어 이미지 chovo 22-05-16 49
질문 앱인벤터 질문입니다.댓글[2] 이미지 귀끠우유 22-05-16 55
질문 아두이노 우노끼리 블루투스 통신댓글[1] 첨부파일 pyoleo 22-05-16 61
질문 마이크로 받은 입력을 주파수로 변경댓글[3] 생늧판출 22-05-16 39
질문 while문 안 if문 빠져나오는 방법 kyho3855 22-05-15 33
답변 답변글 답변 : while문 안 if문 빠져나오는 방법댓글[1] master 22-05-16 43
질문 초음파센서로 속도구하기(코드 합치는법) 쥰니 22-05-15 65
답변 답변글 답변 : 초음파센서로 속도구하기(코드 합치는법)댓글[1] master 22-05-16 56
질문 360서보모터 질문입니다댓글[1] 한잔해2 22-05-14 93
질문 아두이노 초보 24V DC 제품 제어댓글[2] 제로펲시 22-05-13 96
